RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Redcat Racing Tornado Thread - 2/7/2007 7:59 PM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
230-270
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to TORNADO BB)
       Post #: 51
RE: Redcat Racing Tornado Thread - 2/8/2007 5:14 AM
arlo1
Score: 100
Last Login: 5/5/2008
Status: offline
I have a lazer temp gun what part of the engine or heat sink do you read or aim at?
Tornado bb.
Hide Signatures
(in reply to ehroof)
       Post #: 52
RE: Redcat Racing Tornado Thread - 2/8/2007 5:34 AM
rclynx
Score: 100
Last Login: 7/25/2011
Status: offline
I aim straight down at the glow plug
HOT)
Custom Cars bring out the stars / Home of the RCLYNX, RC IMPROVEMENT, MOD, SALES & SERVICE Dealer;XTM, CEN, HPI & much more
Hide Signatures
(in reply to arlo1)
       Post #: 53
RE: Redcat Racing Tornado Thread - 2/8/2007 5:36 AM
arlo1
Score: 100
Status: offline
cool thanks. or would it be best to just to find the hotest reading on the top of the engine?
Tornado bb.
Hide Signatures
(in reply to rclynx)
       Post #: 54
RE: Redcat Racing Tornado Thread - 2/8/2007 3:39 PM
rclynx
Score: 100
Status: offline
yes and yea
Hide Signatures
(in reply to arlo1)
       Post #: 55
RE: Redcat Racing Tornado Thread - 2/9/2007 4:52 AM
slide150
Score: 100
Last Login: 12/10/2007
Status: offline
what suspension pieces do i need to convert my suspension to the tornado bb
Better Smokin than Broken ......tornado equivelent
Hide Signatures
(in reply to Chubbysdad)
       Post #: 56
RE: Redcat Racing Tornado Thread - 2/9/2007 5:25 AM
ehroof
Score: 105
Status: offline
it cant be done, i tried last year, topspeedtoys sent me the parts to convert it but it was just not possible, i still needed more parts to try to do it, its not worth it, your better off buying a car with the pivot ball suspension.
Hide Signatures
(in reply to slide150)
       Post #: 57
RE: Redcat Racing Tornado Thread - 2/10/2007 3:19 AM
frekbynature2002
Score: 100
Last Login: 4/18/2007
Status: offline
Is there a starter that can be used on the BB instead of a pull? If so, how does it assemble and what do I need
Hide Signatures
       Post #: 58
RE: Redcat Racing Tornado Thread - 2/10/2007 3:25 AM
ehroof
Score: 105
Status: offline
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMVE0&P=7 this replaces the pullstart, its a direct bolt on, take the pull start off and put this on, you will need a 7.2 volt battery with a charger for the battery in order to use it.
Hide Signatures
(in reply to frekbynature2002)
       Post #: 59
RE: Redcat Racing Tornado Thread - 2/10/2007 5:53 PM
frekbynature2002
Score: 100
Status: offline
another question. I let someone use while I was at work. I get home and the car wouldn't start. So I called Redcat to set all adjustments back to original(they were changed). Still wouldn't run, I pulled out the Idle screw found it was damaged and burred. Replaced with a HPI one. I got the car where it will start(hard to do) but will not stay running, when I apply the brake it stalls. Would it be a carb problem now and is ther a HPI carb I can use? I can't get it to adjust correctly and there is alot of fuel/oil that pours out of the muffler when I angle the car. Please help, I wanted to go run it today.
Hide Signatures
       Post #: 60
RE: Redcat Racing Tornado Thread - 2/10/2007 5:59 PM
ehroof
Score: 105
Status: offline
sounds like throttel linkage adjustment, look at the carb opening when you hit the brake, if it closes the opening then the linkage needs to be adjusted, if not it can be the clutch spring, check out the clutch upgrade sticky. the tuned pipe holds oil so when you tip the car to the side it drips out. also try 2 1/2 out on the high needle and flush with the collar on the low needle.
Hide Signatures
       Post #: 61
RE: Redcat Racing Tornado Thread - 2/10/2007 6:10 PM
frekbynature2002
Score: 100
Status: offline
I'll try the high, the low is flush. I got the HPI clutch bell and pinnon gears and clutch(2pc) from tower. how hard is it to change. I can't find anything such as a print of assembly
Hide Signatures
       Post #: 62
RE: Redcat Racing Tornado Thread - 2/10/2007 6:13 PM
ehroof
Score: 105
Status: offline
when you are ready to do it let me know an i will help you out and post pictures, dont change the clutch bell unless you change the clutch spring, it will go bad eventually and you will have to remove the engine again, it sounds like the spring is your problem.
Hide Signatures
       Post #: 63
RE: Redcat Racing Tornado Thread - 2/10/2007 6:16 PM
frekbynature2002
Score: 100
Status: offline
ok, I plan on chaging it all anyway. I got the new clutch/springs and gears. I am planning on changing in a few minutes. Thanks for your help
Hide Signatures
       Post #: 64
RE: Redcat Racing Tornado Thread - 2/10/2007 6:26 PM
frekbynature2002
Score: 100
Status: offline
also I worked the throttle back and fourth with the reciever, it looks as it gets stuck, jumps in the same area everytime. like there is something catching them gets past that point and goes to brake. But rotory doesn't return open when in neutral
Hide Signatures
       Post #: 65
RE: Redcat Racing Tornado Thread - 2/10/2007 9:13 PM
ehroof
Score: 105
Status: offline
you need to raise the idle screw so it keeps it open
Hide Signatures
       Post #: 66
RE: Redcat Racing Tornado Thread - 2/10/2007 11:00 PM
frekbynature2002
Score: 100
Status: offline
ok, now when i apply the brake, it stalls. other than that it runs. and I checked temp, its about 219
Hide Signatures
       Post #: 67
RE: Redcat Racing Tornado Thread - 2/10/2007 11:06 PM
ehroof
Score: 105
Status: offline
you have to raise the idle screw, when you apply the brake its closing the carb, turn it clockwise until its stops stalling when you hit the brake.
Hide Signatures
       Post #: 68
RE: Redcat Racing Tornado Thread - 2/10/2007 11:15 PM
frekbynature2002
Score: 100
Status: offline
ok, feel stupid. you can tell I'm a noob. Does the brake suppose to be loose(dangling sorta) or tight. how do I get to the 1 screw to tighten if needed
Hide Signatures
       Post #: 69
RE: Redcat Racing Tornado Thread - 2/11/2007 1:06 AM
ehroof
Score: 105
Status: offline
it should be a little loose not tight, there are 2 screws that hold the pads, allen heads, one on each side of the pad
< Message edited by ehroof -- 2/11/2007 1:07 AM >
Hide Signatures
       Post #: 70
RE: Redcat Racing Tornado Thread - 2/11/2007 1:49 AM
frekbynature2002
Score: 100
Status: offline
how does the clutch springs go, I have the 2 pc not the traxxes. I found the original spring missing, the bell gears were strip and the high/low gears strip
Hide Signatures
       Post #: 71
RE: Redcat Racing Tornado Thread - 2/11/2007 1:51 AM
frekbynature2002
Score: 100
Status: offline
this is the clutch http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCFR3&P=M
Hide Signatures
       Post #: 72
RE: Redcat Racing Tornado Thread - 2/11/2007 1:59 AM
ehroof
Score: 105
Status: offline
this should help you out: http://www.hpiracing.com/graphics/instr/nit3evo/Nitro3EVO_25.jpg enlarge and you can see exactly how they go
Hide Signatures
       Post #: 73
RE: Redcat Racing Tornado Thread - 2/11/2007 3:06 AM
frekbynature2002
Score: 100
Status: offline
Ty very much
Hide Signatures
       Post #: 74
RE: Redcat Racing Tornado Thread - 2/11/2007 3:08 AM
ehroof
Score: 105
Status: offline
your welcome bro, let me know how it works out
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.375RCU1
