RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: Redcat Racing Tornado Thread - 3/11/2007 9:23 PM
frekbynature2002
Score: 100
Last Login: 4/18/2007
Status: offline
I found the problem. It was the wheel rubbing on the hub carrier. I tightened it so it wouldn't come off, but it was dragging, I unsnug a little to turn now is working fine, but the wheel comes off after 1/2hr run time. I also found grit in the dif from sand mixing with the grease. I also put back in the original clutch with the traxxes spring, runs great now. Only thing left is to replace the pipe, since I broke from a wipe-out, LOL.
Hide Signatures
(in reply to ehroof)
       Post #: 176
RE: Redcat Racing Tornado Thread - 3/11/2007 9:29 PM
slide150
Score: 100
Last Login: 12/10/2007
Status: offline
i agree with ed it sounds like a bad bearing pull the hub apart and check yoru bearing
_____________________________
Better Smokin than Broken ......tornado equivelent
Hide Signatures
       Post #: 177
RE: Redcat Racing Tornado Thread - 3/12/2007 5:59 AM
frekbynature2002
Score: 100
Status: offline
Is there a header you recommend, I found an associate 7730 tuned pipe at my local store. Barely hear it running. http://h1072224.hobbyshopnow.com/products/description.asp?prod=ASC7730
< Message edited by frekbynature2002 -- 3/12/2007 6:01 AM >
Hide Signatures
(in reply to slide150)
       Post #: 178
RE: Redcat Racing Tornado Thread - 3/12/2007 6:05 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
hpi rs4 header fits
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to frekbynature2002)
       Post #: 179
RE: Redcat Racing Tornado Thread - 3/12/2007 6:10 AM
frekbynature2002
Score: 100
Status: offline
thanks as always bro
Hide Signatures
       Post #: 180
RE: Redcat Racing Tornado Thread - 3/13/2007 5:21 AM
bad630
Score: 100
Last Login: 4/19/2007
Status: offline
When I pull the pull rope it's free but still working it's not catching to turn the motor is it the bearing?
Hide Signatures
       Post #: 181
RE: Redcat Racing Tornado Thread - 3/13/2007 5:26 AM
frekbynature2002
Score: 100
Status: offline
I just had the same problem, I removed the Pull start and had to shorten the coil by 1/4" and recoil. I put back on and it worked better than it did new. does the rope recoil but doesn't turn the motor
< Message edited by frekbynature2002 -- 3/13/2007 5:27 AM >
Hide Signatures
(in reply to bad630)
       Post #: 182
ehroof
Score: 105
Status: offline
sounds like the one way bearing, its not grabbing and turning over the motor even though your pulling the starter right?
Hide Signatures
       Post #: 183
RE: Redcat Racing Tornado Thread - 3/13/2007 5:45 AM
bigtom68
Score: 100
Last Login: 5/3/2007
Status: offline
i just had the same problem with my xp 2 days ago i found that all the screws became loose and as soon as i tightend them it was fine. my header has seem to loosen up as well. any good headers and do they use gaskets?
Hide Signatures
       Post #: 184
RE: Redcat Racing Tornado Thread - 3/13/2007 5:46 AM
bad630
Score: 100
Status: offline
Right,it will grab alittle, some times none at all like its missing.
Hide Signatures
       Post #: 185
RE: Redcat Racing Tornado Thread - 3/13/2007 5:50 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: bad630
its the one way bearing
Hide Signatures
       Post #: 186
RE: Redcat Racing Tornado Thread - 3/13/2007 5:51 AM
bad630
Score: 100
Status: offline
Pulled it off today and blew the sand out of it put it back together worked fine for 1 or 2 times now its free again catchs every now and then all screws tight.
Hide Signatures
       Post #: 187
RE: Redcat Racing Tornado Thread - 3/13/2007 5:52 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: bigtom68
hpi header and gasket and yes all headers use a gasket: http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBTB5&P=ML
gasket only: http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXN376&P=M
Hide Signatures
(in reply to bigtom68)
       Post #: 188
bad630
Score: 100
Status: offline
Tks
Hide Signatures
       Post #: 189
RE: Redcat Racing Tornado Thread - 3/13/2007 5:54 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: bad630
this one way will work: http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGEH3&P=7
Hide Signatures
       Post #: 190
RE: Redcat Racing Tornado Thread - 3/13/2007 9:01 AM
bad630
Score: 100
Status: offline
Is it better thanks again.
Hide Signatures
       Post #: 191
RE: Redcat Racing Tornado Thread - 3/13/2007 10:37 PM
streetskatertd
Score: 100
Last Login: 3/21/2008
Status: offline
quote:
Here are some pics of my tornado xp's:
1. upgrade your 2 speed clutch bell to: http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXCLR2&P=K + http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXDHM0&P=K + http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXCLR9&P=K
you may need to widdle away a little of the upper plate post so the gears clear it
2. if you want more low end touque use this clutch bell: http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXM730&P=K you will loose top end speed with this but have much low end take off
3. upgrade your single speed clutch bell to: http://www.clermontmotorsports.com/servlet/Detail?no=200 or this place: http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLST9&P=7
4. upgrade to this clutch spring traxxas 4146x : http://www2.towerhobbies.com/cgi-bin/wti0095p?FVSEARCH=4146x&FVPROFIL=++&search3=Go
is any of this stuff a direct fit?? no modification needed??
< Message edited by streetskatertd -- 3/13/2007 10:39 PM >
Hide Signatures
       Post #: 192
RE: Redcat Racing Tornado Thread - 3/13/2007 10:39 PM
ehroof
Score: 105
Status: offline
its all a direct fit, same as replacing the stock stuff, just better.
Hide Signatures
(in reply to streetskatertd)
       Post #: 193
RE: Redcat Racing Tornado Thread - 3/13/2007 10:44 PM
streetskatertd
Score: 100
Status: offline
sweet, thanks for the info
Hide Signatures
       Post #: 194
RE: Redcat Racing Tornado Thread - 3/13/2007 11:01 PM
ehroof
Score: 105
Status: offline
with the 13/18 bell you will need these: http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXM766 and http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXM861
Hide Signatures
       Post #: 195
RE: Redcat Racing Tornado Thread - 3/14/2007 11:52 PM
flyingace451
Score: 100
Last Login: 11/24/2009
Status: offline
How durable is this little buggy? Since it's such a sweet price, I'm thinking about it just to bash it around. And which model would you recomend? We used to hold races around here and I guess it'd be nice to have something for 1/10 scale just for kicks.
I push my buggies to the limit, so please let me know as precisely as possible how durable this thing is.
As I lay in bed at night I look up at the stars and think to myself, "Where the heck is the ceiling!?"
Hide Signatures
       Post #: 196
RE: Redcat Racing Tornado Thread - 3/15/2007 1:17 AM
kcrd2
Score: 100
Last Login: 11/16/2007
Status: offline
Hello to all....We have a problem with a Tornado XP (two speed) that my son got for a Christmas gift. It has been run maybe all of two hours combined. One day when he went to use it, it started out at high rpms and was going all by itself. He tried to adjust the needle valve to lower the rpms but then the motor would die and the wheels would still be moving. He took it in to a hobby store and they tried to adjust it also but they couldn't get it to work either. It still is at way high rpms and lowering that just causes it to die with the wheels still spinning. Any ideas?? Thanks in advance for any and all help or ideas anyone has. This is his first gas vehicle and he is extremely frustrated that it only worked for a little while and being beginners we don't have a clue what to do now.
Hide Signatures
(in reply to TORNADO BB)
       Post #: 197
RE: Redcat Racing Tornado Thread - 3/15/2007 1:24 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: flyingace451
Its durable, get the tornado xp or bb, its a two speed, you just have to upgrade you clutch spring and clutch bell. i have had mine for over a year and havent broken one part. I havent stripped out a gear since i upgraded to the hpi setup.
Hide Signatures
(in reply to flyingace451)
       Post #: 198
RE: Redcat Racing Tornado Thread - 3/15/2007 1:25 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: kcrd2
its the clutch spring, replace it with the traxxas 4146x spring, also i would suggest upgrading the clutch bell also
Hide Signatures
(in reply to kcrd2)
       Post #: 199
RE: Redcat Racing Tornado Thread - 3/15/2007 1:55 AM
kcrd2
Score: 100
Status: offline
Thanks so much for the speedy solution. My son will be excited to hear that when he gets home from school. Where is a good place to order the parts and are they easy for a 13 year old to install??
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.922RCU1
