RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: Redcat Racing Tornado Thread - 3/15/2007 2:22 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
here you go, with a little patience you can do it or he can, if there is a problem, just come here and we will help.
1. upgrade your 2 speed clutch bell to: http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXCLR2&P=K + http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXDHM0&P=K + http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXCLR9&P=K
you may need to widdle away a little of the upper plate post so the gears clear it
2.upgrade to this clutch spring traxxas 4146x : http://www2.towerhobbies.com/cgi-bin/wti0095p?FVSEARCH=4146x&FVPROFIL=++&search3=Go
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to kcrd2)
       Post #: 201
RE: Redcat Racing Tornado Thread - 3/15/2007 3:03 AM
flyingace451
Score: 100
Last Login: 11/24/2009
Status: offline
Those parts will take some time to install, but as long as you keep up with which screw goes where either you or your son could do it. A trick that helps me is to print out a parts explosion of the vehicle and place the parts and screws I take out to install stuff on their designated areas on the explosion. It helps me keep track of things, and keep in mind that you will have to remove other stuff in order to reach the clutch bell.
Alright thanks for the advice. This thing seems like it'd be fun to add to the collection. What kind of jumps can it take?
As I lay in bed at night I look up at the stars and think to myself, "Where the heck is the ceiling!?"
Hide Signatures
(in reply to ehroof)
       Post #: 202
RE: Redcat Racing Tornado Thread - 3/15/2007 3:48 AM
ehroof
Score: 105
Status: offline
it jumps nice, it doesnt land like a truck since its lower to the ground but its just real cool.
Hide Signatures
(in reply to flyingace451)
       Post #: 203
RE: Redcat Racing Tornado Thread - 3/16/2007 2:06 AM
daveschutt
Score: 100
Last Login: 4/16/2011
Status: offline
I AM PLANNING ON UPGRADING MY CLUTCH BELL SO I AM NOT ALWAYS SMOKING GEARS. I AM ALSO PUTTING ON DIRT HAWG 2 TIRES WICH MEASURE 3.5 INCHES IN DIAMATER. WOULD I BE BETTER WITH THE 13-18 OR 17-22 CLUTCH BELL?
CRAZYDAVE
Woah-what was that? i think it was a racoon-nope just another wimpy t max under my MGT!
Hide Signatures
       Post #: 204
RE: Redcat Racing Tornado Thread - 3/16/2007 2:13 AM
ehroof
Score: 105
Status: offline
the 13/18 will give ou much more low end but make sure you get the needle bearing and bushings for it too.
Hide Signatures
(in reply to daveschutt)
       Post #: 205
RE: Redcat Racing Tornado Thread - 3/16/2007 4:37 AM
daveschutt
Score: 100
Status: offline
THANK YOU!!!! I FOUND THAT IF YOU PUT SOME WHITE GREASE ON THE GEARS EVERY OTHER RUN IT WILL MAKE THEM LAST A LOT LONGER. ANOTHER TRANNY PROBLEM... THE CAR (TORNADO XP) WONT SHIFT!!!! I TRIED LOOSNING THE SCREW BUT MADE IT TOO LOOSE AND IT FELL OUT. ANY SUGGESTIONS????
CRAZYDAVE
Hide Signatures
       Post #: 206
RE: Redcat Racing Tornado Thread - 3/16/2007 4:48 AM
ehroof
Score: 105
Status: offline
you need to get a new 2 speed shifter, i did the same thing: http://www.clermontmotorsports.com/servlet/the-125/2-Way-Drive-Clutch/Detail
< Message edited by ehroof -- 3/16/2007 4:49 AM >
Hide Signatures
       Post #: 207
RE: Redcat Racing Tornado Thread - 3/18/2007 12:56 AM
frekbynature2002
Score: 100
Last Login: 4/18/2007
Status: offline
is there a different, better cooling head I can use on the VX .18
Hide Signatures
       Post #: 208
RE: Redcat Racing Tornado Thread - 3/18/2007 1:36 AM
daveschutt
Score: 100
Status: offline
I JUST BOUGHT A BUNCH OF 47T SPUR GEARS FOR MY XP , I WENT TO PUT THEM ON AND NOTICED THE CUTOUT FOR THE ONE WAY BEARING IS MUCH BIGGER. THE PART #S WERE CORRECT ON THE BAG AND THE GEARS WERE THE SAME SIZE. DID REDCAT CHANGE THESE. THE ONE WAY BEARING ON MY CAR APPEARS TO BE A 10MM AND THE CUTOUT ON THE NEW GEARS APPEARS TO BE 14MM. MY SUPPLIER INSISTS THESE ARE THE CORRECT PARTS. HELP!!!
Hide Signatures
(in reply to frekbynature2002)
       Post #: 209
RE: Redcat Racing Tornado Thread - 3/18/2007 2:16 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: frekbynature2002
an hpi .15 nitro star t head will fit
Hide Signatures
       Post #: 210
RE: Redcat Racing Tornado Thread - 3/18/2007 2:19 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: daveschutt
if its part #06032 it is the correct gear, i have them (i bought a few extra to have) and they all have the same size cutout for the one way
Hide Signatures
       Post #: 211
RE: Redcat Racing Tornado Thread - 3/18/2007 5:22 AM
daveschutt
Score: 100
Status: offline
thanks!!! what is the size of the cutout on your gears and does clermont sell these
Hide Signatures
       Post #: 212
RE: Redcat Racing Tornado Thread - 3/18/2007 6:01 AM
ehroof
Score: 105
Status: offline
10mm, its the smaller one way not the same as the pull start one, i think that one is 12mm
http://www.clermontmotorsports.com/servlet/the-159/47-tooth-throttle-gear/Detail
Hide Signatures
       Post #: 213
RE: Redcat Racing Tornado Thread - 3/18/2007 6:05 AM
daveschutt
Score: 100
Status: offline
thats weird. i wonder if redcat is changing them or if all of these were just packaged wrong. oh well i guess i'll just send them back and try to find the right ones. thanks again for all your help.
Hide Signatures
       Post #: 214
RE: Redcat Racing Tornado Thread - 3/18/2007 6:18 AM
ehroof
Score: 105
Status: offline
your welcome bro, by the way where is orchard park?
Hide Signatures
       Post #: 215
RE: Redcat Racing Tornado Thread - 3/18/2007 11:06 AM
kcrd2
Score: 100
Last Login: 11/16/2007
Status: offline
quote:
ORIGINAL: ehroof
Thanks for the parts information to order. Will the parts come with some type of instructions on how to install them or will my son just be able to figure it out??
Hide Signatures
       Post #: 216
RE: Redcat Racing Tornado Thread - 3/18/2007 5:54 PM
ehroof
Score: 105
Status: offline
he should be able to figure it out, if not just drop a line here on the forum or email me and i will help you guys out.
Hide Signatures
(in reply to kcrd2)
       Post #: 217
RE: Redcat Racing Tornado Thread - 3/18/2007 7:03 PM
daveschutt
Score: 100
Status: offline
ORCHARD PARK IS ABOUT 20 MILES SOUTH OF BUFFALO, WHERES HOWARD BEACH
Hide Signatures
       Post #: 218
RE: Redcat Racing Tornado Thread - 3/18/2007 7:16 PM
ehroof
Score: 105
Status: offline
nyc, queens/brooklyn border
Hide Signatures
       Post #: 219
RE: Redcat Racing Tornado Thread - 3/18/2007 7:43 PM
daveschutt
Score: 100
Status: offline
ehroof, i am thinking about buying a aluminium exhaust pipe. Does it make a difference or does it just give it a cool sound.
Hide Signatures
       Post #: 220
RE: Redcat Racing Tornado Thread - 3/18/2007 7:46 PM
ehroof
Score: 105
Status: offline
hey dave, it makes a big difference and it sounds better. you should change the header too.
Hide Signatures
       Post #: 221
RE: Redcat Racing Tornado Thread - 3/18/2007 9:49 PM
daveschutt
Score: 100
Status: offline
ehroof, Do you suggest the redcat aluminium exhaust pipe pipe? If not what pipe and header do you suggest. Thank you for your mad ninja skills!!!!
Hide Signatures
       Post #: 222
RE: Redcat Racing Tornado Thread - 3/18/2007 10:35 PM
ehroof
Score: 105
Status: offline
lol, i use this pipe and i am very happy with it, you can spend alot more money if you want but i find this to be a good setup.
Hpi header: http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBTB5&P=ML
Team associated pipe: http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBMH0&P=7
Hide Signatures
       Post #: 223
RE: Redcat Racing Tornado Thread - 3/19/2007 5:57 AM
daveschutt
Score: 100
Status: offline
do i need the header or will the associated pipe work with the stock header
Hide Signatures
       Post #: 224
RE: Redcat Racing Tornado Thread - 3/22/2007 11:02 PM
frekbynature2002
Score: 100
Status: offline
The car is not that responsive to the transmitter, I changed all the batteries so could the crystals be going bad. I also can't get it to run right like before, it either sounds like its flooding or not enough fuel. I tried adjusting but I have to adjust while I'm running it, longer I run it I have to make adjustments to be able to keep running.
< Message edited by frekbynature2002 -- 3/23/2007 10:45 AM >
Hide Signatures
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
