RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
Users viewing this topic: DniceRC
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: Redcat Racing Tornado Thread - 3/26/2007 5:40 AM
daveschutt
Score: 100
Last Login: 4/16/2011
Status: offline
I THOUGHT I WAS LOOSING MY MIND!!! AT LEAST SOMEONE ELSE SEEMS TO BE HAVING THE SAME PROBLEM WITH THE DIFFERENT SIZE BEARING CUT OUT ON THIER 47 TOOTH SPUR GEARS. ANY ONE KNOW WHERE I CAN GET THE GEARS WITH THE SMALLER CUTOUT? IF NOT DOES REDCAT HAVE A PART # FOR THE NEW BEARING. THANKS
_____________________________
Woah-what was that? i think it was a racoon-nope just another wimpy t max under my MGT!
Hide Signatures
(in reply to LorDDarknesS)
       Post #: 251
RE: Redcat Racing Tornado Thread - 3/26/2007 5:54 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
call redcat or go to their live support and find out about the bearing.
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to daveschutt)
       Post #: 252
RE: Redcat Racing Tornado Thread - 3/26/2007 9:38 AM
groovetrippin
Score: 100
Last Login: 5/17/2007
Status: offline
Whats up everyone,
Need some help.... Have a brand new out of the box Tornado BB and was following all the steps to break in the engine. Tested all the electronics with fresh batteries and the tested the engine.. Both worked like a champ. All of a sudden the controls just stopped working... Checked all the connections and made sure they were tight... Changed out the batt's for new ones and nothing... Let the car sit for about an hour and everything works again... Then 5 min's later the electronics just quit... This has happened now about 3 times. Any clue what's up? I am new so please break your answers down into plain english... Just kidding But please do.
-ash
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Tornado BB, IRC Vulcan
Hide Signatures
       Post #: 253
RE: Redcat Racing Tornado Thread - 3/26/2007 11:07 PM
LorDDarknesS
Score: 100
Last Login: 6/29/2007
Status: offline
ok i got it running without the power loss but while i was working on it i was putting pressure on the rubber boot that surrounds the low end needle and noticed air bubbles forming in the barrel of the carb. does this mean my carb is bad?
mate, eat, bash nitro, repeat
Hide Signatures
(in reply to groovetrippin)
       Post #: 254
RE: Redcat Racing Tornado Thread - 3/26/2007 11:12 PM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: groovetrippin
Whats up everyone,
-ash
sounds like you got a bad radios setup, call redcat and as long as its within 30 days they should give you a new one. actually you should upgrade it, for less than $50 you can get a decent futaba setup.
Hide Signatures
       Post #: 255
RE: Redcat Racing Tornado Thread - 3/26/2007 11:13 PM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: LorDDarknesS
what is the problem you are having? If its running good and not overheating, i wouldnt worry about it.
Hide Signatures
       Post #: 256
RE: Redcat Racing Tornado Thread - 3/26/2007 11:38 PM
LorDDarknesS
Score: 100
Status: offline
but it still stalls at low speed about 50% of time and then wont start the tuning range is good and it doesnt always happen but as long as i give it gas it runs like a raped ape with proper smoke and good heat
< Message edited by LorDDarknesS -- 3/26/2007 11:40 PM >
Hide Signatures
(in reply to ehroof)
       Post #: 257
RE: Redcat Racing Tornado Thread - 3/26/2007 11:43 PM
ehroof
Score: 105
Status: offline
either its the glow plug or the low end needle is set too rich.
Hide Signatures
       Post #: 258
RE: Redcat Racing Tornado Thread - 3/26/2007 11:58 PM
LorDDarknesS
Score: 100
Status: offline
brand new glow plug and i have been working through the entire spectrum of low end....but i'll keep trying also is there any literature out there for headers on a .18 (more power needed lol)
Hide Signatures
       Post #: 259
RE: Redcat Racing Tornado Thread - 3/27/2007 12:16 AM
kcrd2
Score: 100
Last Login: 11/16/2007
Status: offline
quote:
ORIGINAL: ehroof
here you go, with a little patience you can do it or he can, if there is a problem, just come here and we will help.
1. upgrade your 2 speed clutch bell to: http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXCLR2&P=K + http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXDHM0&P=K + http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXCLR9&P=K
you may need to widdle away a little of the upper plate post so the gears clear it
2.upgrade to this clutch spring traxxas 4146x : http://www2.towerhobbies.com/cgi-bin/wti0095p?FVSEARCH=4146x&FVPROFIL=++&search3=Go
Replaced these parts on the Tornado XP. Can you tell me what differences replacing these individual parts was supposed to make?? Just want to make sure that we are getting the right response with the replacements. Thanks.
Hide Signatures
       Post #: 260
RE: Redcat Racing Tornado Thread - 3/27/2007 2:36 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: kcrd2
quote:
ORIGINAL: ehroof
it will stop the spur gear from stripping in the first few tanks of fuel also the spring will last alot longer than the stock one, you may see some more top end since there is a tooth more on the new clutch bell you put in.
Hide Signatures
(in reply to kcrd2)
       Post #: 261
RE: Redcat Racing Tornado Thread - 3/27/2007 2:39 AM
ehroof
Score: 105
Status: offline
this header will fit nicely: http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBTB5&P=ML
try retuning the whole engine, start with 3 out on the high end and flush with the collar on the low end. Maybe you have something clogging the low end needle? take it out and try to clean it out inside, be careful with it.
Hide Signatures
       Post #: 262
RE: Redcat Racing Tornado Thread - 3/27/2007 5:46 AM
LorDDarknesS
Score: 100
Status: offline
when i first got some return imput from u i reset to 2 3/4 main and flush low end is there a manual out there that is at least moderately helpfull for doing a carb? i've torn down auto and quad carbs and know enough that i would rather not go in blind if i dont have to
Hide Signatures
       Post #: 263
RE: Redcat Racing Tornado Thread - 3/27/2007 6:14 AM
LorDDarknesS
Score: 100
Status: offline
noticing some air in the feed line so i took off my tank and lines and pressure tested them but they are good to go is that gonna effect my performance and if so what may the cause be?
Hide Signatures
       Post #: 264
RE: Redcat Racing Tornado Thread - 3/27/2007 6:31 AM
ehroof
Score: 105
Status: offline
make sure there's not a hole in the fuel or pressure line, also make sure the tank cap is sealing good. if you want some nitro engine reading, check this out: http://www.rchobbies.org/cars_eng-tuning.htm there are alot of good links and information there
Hide Signatures
       Post #: 265
RE: Redcat Racing Tornado Thread - 3/27/2007 7:13 AM
LorDDarknesS
Score: 100
Status: offline
thanx man thats good. you rule ehroof. i do have one more favor to ask though could you take a picture of your throtle linkage on your xp so i can get a good idea where to set mine it's working ok but i dont think its quite right (my rear retainer popped off..thankfully on cement not dirt)
Hide Signatures
       Post #: 266
RE: Redcat Racing Tornado Thread - 3/28/2007 12:50 AM
LorDDarknesS
Score: 100
Status: offline
ok so my carb is leaking from 2 places tried tightening everything and siliconing the seams but still leaking a little from the low end boot
if i wanted to replace it what is a good carb? i couldn't find one through redcat or rufaster.com
Hide Signatures
       Post #: 267
RE: Redcat Racing Tornado Thread - 3/28/2007 3:35 AM
AllAboutFunHobbies
Score: 100
Last Login: 11/10/2011
Status: offline
Stock carb, bottom right.
http://www.allaboutfunhobbies.com/tornadoxlparts6.htm
Also if you haven't tried it yet, you can take the carb aparts and pull out the O-rings and run to the local Hardware store and see if you can match them up, sounds like the O-rings are worn out.
< Message edited by AllAboutFunHobbies -- 3/28/2007 3:37 AM >
Dealer for..Redcat, Traxxas, Associated, Cen, Racers Edge, RD Logic, Losi, HPI, E-flight, Himoto, Venom, Heli-Max, O.S...etc
Hide Signatures
       Post #: 268
RE: Redcat Racing Tornado Thread - 3/28/2007 7:48 AM
LorDDarknesS
Score: 100
Status: offline
can i paint my block or will it cause overheating?
Hide Signatures
(in reply to AllAboutFunHobbies)
       Post #: 269
RE: Redcat Racing Tornado Thread - 3/28/2007 8:02 AM
AllAboutFunHobbies
Score: 100
Status: offline
Don't paint block, the paint will trap the heat in. Besides the nitro fuel just peel the paint off. If you really want to change the color of your block you need to take it apart and anodize it. but you have to dip it in a solvent to get it clean first, it's a stinky messy process and takes some practice, but looks cool when you get a handle on it.
< Message edited by AllAboutFunHobbies -- 3/28/2007 8:03 AM >
Hide Signatures
       Post #: 270
RE: Redcat Racing Tornado Thread - 3/28/2007 8:09 AM
LorDDarknesS
Score: 100
Status: offline
i have no idea how to anodize any literature out ther on how to?
another question, can i trim away some of the fuel to carb tubing to help get it outta the way?
also i just got an email from rufaster saying that the xp has been discontinued better order them parts while you can
< Message edited by LorDDarknesS -- 3/28/2007 8:42 AM >
Hide Signatures
       Post #: 271
RE: Redcat Racing Tornado Thread - 3/28/2007 9:06 AM
LorDDarknesS
Score: 100
Status: offline
just read a how to on anodizing..simple procedure if i can get some sulfuric acid real simple
Hide Signatures
       Post #: 272
RE: Redcat Racing Tornado Thread - 3/28/2007 5:30 PM
AllAboutFunHobbies
Score: 100
Status: offline
The hurricane XP has been discontinued from Redcat, but about ten other companies are building the car, there's no shortage of parts, unless your stuck buying from Redcat exclusivly and don't know that it's the same car as the Earthquake . You can get sulfuric acid from a hardware store, it comes in a plastic container to put in a battery for a riding lawnmower. Anodizing is pretty simple but be sure to do it in an area where there is good ventalation, it stinks to high heaven
Hide Signatures
       Post #: 273
RE: Redcat Racing Tornado Thread - 3/28/2007 6:37 PM
TORNADO BB
Score: 100
Last Login: 3/2/2011
Status: offline
Whats up everyone,
-ash
I had the same problem and all i did was tighten the crystle then it worked fine.
tornado xp
Hide Signatures
       Post #: 274
RE: Redcat Racing Tornado Thread - 3/28/2007 7:37 PM
chris15
Score: 100
Status: offline
i crashed my tornado xp and i broke the diff in like five pieces does anyone know where to get an aluminum diff case.
< Message edited by chris15 -- 3/28/2007 7:41 PM >
Hide Signatures
(in reply to TORNADO BB)
       Post #: 275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.563RCU1
