RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  39 40 [41] 42 43 44 45 46 47 48   next >   >>
Login
RE: Redcat Racing Tornado Thread - 9/14/2007 6:12 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
you could, just get the bigger ones so the reciever will fit in it, just zip tie the end where the wires come out.
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to d3d5)
       Post #: 1001
RE: Redcat Racing Tornado Thread - 9/14/2007 6:13 AM
hibityhupla
Score: 100
Last Login: 11/10/2007
Status: offline
quote:
ORIGINAL: d3d5
for balloons can i just get regular party ballons?
I think so. When I got a smartech car it came with one I just never knew what it was for.
Hide Signatures
(in reply to d3d5)
       Post #: 1002
d3d5
Score: 100
Last Login: 2/28/2012
Status: offline
k will get that tommarow i have 2 right now just need 1 more
tornado bb, firestorm what to get next?
Hide Signatures
(in reply to ehroof)
       Post #: 1003
RE: Redcat Racing Tornado Thread - 9/14/2007 6:20 AM
hibityhupla
Score: 100
Status: offline
quote:
ORIGINAL: hibityhupla
Is there any chance of the blocks cracking? What about if the car gets buried in snow? It get -40F here every winter.
Hide Signatures
(in reply to hibityhupla)
       Post #: 1004
RE: Redcat Racing Tornado Thread - 9/14/2007 6:23 AM
ehroof
Score: 105
Status: offline
anything is possible but i doubt it, you may have to wrap it with aluminum foil to keep the temp up if its -40. with the body on, even if it get burried in the snow, i am sure you will get to it before snow enters inside the body.
Hide Signatures
       Post #: 1005
RE: Redcat Racing Tornado Thread - 9/14/2007 6:28 AM
hibityhupla
Score: 100
Status: offline
I"ll have to try that. The weather guy is talking snow tomorrow already.
Can I lean it out a bit to make it run hotter or does that become an issue if I go to far? I'm sure at -40 it would be hard to make it overheat.
Hide Signatures
       Post #: 1006
RE: Redcat Racing Tornado Thread - 9/14/2007 6:29 AM
ehroof
Score: 105
Status: offline
it not the leaning to run warmer, it would be the lack of lubrication from the oil in the fuel, thats why you would wrap it with foil.
< Message edited by Eddie-redcat -- 9/14/2007 6:30 AM >
Hide Signatures
       Post #: 1007
RE: Redcat Racing Tornado Thread - 9/14/2007 6:33 AM
hibityhupla
Score: 100
Status: offline
What If you used a fuel with a high oil content, could you lean it out more then? Like then break in blend fuels?
Hide Signatures
       Post #: 1008
RE: Redcat Racing Tornado Thread - 9/14/2007 6:36 AM
ehroof
Score: 105
Status: offline
i wouldnt think so but its a good point, i would use the same fuel you always use, check the temp, try to keep it at 180 minimum. wrap the cooling head with some aluminum and you should be ok.
Hide Signatures
       Post #: 1009
RE: Redcat Racing Tornado Thread - 9/14/2007 6:40 AM
hibityhupla
Score: 100
Status: offline
I might have to try it one one of my smartech's just to see but I'll stick with your advice on the others.
Hide Signatures
       Post #: 1010
RE: Redcat Racing Tornado Thread - 9/14/2007 8:23 AM
NITROMAN125
Score: 100
Last Login: 12/17/2007
Status: offline
Hey i think i know the problem with my tornado but want to be sure,evry time i start it the cars tires start spinning could the clutch spring be bad or gone???
Hide Signatures
       Post #: 1011
RE: Redcat Racing Tornado Thread - 9/14/2007 10:36 AM
tyhodge07
Score: 100
Last Login: 3/28/2013
Status: offline
could be.. mine wasnt the clutch spring tho.. ur only way of tellin it takin the clutch bell off.. spring may have just come off.. but mine was one of the pins that held the clutch on..
Hide Signatures
(in reply to NITROMAN125)
       Post #: 1012
RE: Redcat Racing Tornado Thread - 9/14/2007 11:02 AM
NITROMAN125
Score: 100
Status: offline
I took it off and it was gone completly!!! what should i do just replace the spring???
< Message edited by blakeyboy250 -- 9/14/2007 11:03 AM >
Hide Signatures
(in reply to tyhodge07)
       Post #: 1013
RE: Redcat Racing Tornado Thread - 9/14/2007 11:07 AM
tyhodge07
Score: 100
Status: offline
the spring was gone? id just replace them both and keep the old one.. thats what id do.. but its up to you.
Hide Signatures
       Post #: 1014
RE: Redcat Racing Tornado Thread - 9/14/2007 11:38 AM
green 1
Score: 100
Last Login: 8/2/2008
Status: offline
you need to find out how motor is ported some high strung 8 ports might need that rpm to make power wouldnt need it on most big block apps. there preaty much ported for low end torque hope i helped a little green1
Hide Signatures
(in reply to arlo1)
       Post #: 1015
RE: Redcat Racing Tornado Thread - 9/14/2007 12:07 PM
green 1
Score: 100
Status: offline
ive seen new transmissions redcat stock at about 15.00
Hide Signatures
       Post #: 1016
RE: Redcat Racing Tornado Thread - 9/14/2007 12:21 PM
donshl
Score: 100
Last Login: 1/11/2008
Status: offline
Hey thanks hibityhupla,
I got some O'Donnell plugs in there (cant remember which ones offhand, but they should be hot ones). When you say its rich do you mean the HSN or LSN? I've turned the HSN 2 1/2 turns out from bottom and LSN flat with the top.
I've had to replace my stock tyres as I broke a wheel when I crashed into a garden wall and got the HPI F5 rear wheels with HPI Yokohama Geolander tyres. They look real good! Have loads more grip and handles soo much better than the stock ones.
If you cant beat them, join them and then beat the $h!t outta them!
Hide Signatures
       Post #: 1017
RE: Redcat Racing Tornado Thread - 9/14/2007 8:55 PM
NITROMAN125
Score: 100
Status: offline
If you order a new clutchbell from redcat does it come with the spring and everything??? Also lately i am having a prblem starting it. I pull and pull and i am starting to want to just step on the THING!! ... but i know it will start.. cause it has easily before... i think its a fuel problem... cause i cheched the plug with my glow starter and it is heating so the plugs fine.... any suggestions would REALLY HELP!!! by the way occasionally the car will try to start up it,ll go RARHHR and then stop it dosen,t sound like its dying the it sounds like its too rich could this bee the problem???
< Message edited by blakeyboy250 -- 9/14/2007 9:41 PM >
Hide Signatures
(in reply to donshl)
       Post #: 1018
RE: Redcat Racing Tornado Thread - 9/14/2007 11:32 PM
newdoughboy
Score: 100
Last Login: 2/1/2008
Status: offline
Can someone tell me if this will fit on my Tornado BB?
Hide Signatures
       Post #: 1019
RE: Redcat Racing Tornado Thread - 9/14/2007 11:46 PM
newdoughboy
Score: 100
Status: offline
sorry forgot the link
http://www.hpieurope.com/piw.php?lang=en&partNo=86139
Hide Signatures
(in reply to newdoughboy)
       Post #: 1020
RE: Redcat Racing Tornado Thread - 9/15/2007 1:14 AM
hibityhupla
Score: 100
Status: offline
quote:
ORIGINAL: newdoughboy
Should be fine.
Hide Signatures
       Post #: 1021
RE: Redcat Racing Tornado Thread - 9/15/2007 1:18 AM
hibityhupla
Score: 100
Status: offline
quote:
ORIGINAL: donshl
If your looking at the car from the top the fuel adjustment is the one that comes up right beside your air filter. Turn it in to lean it out-turn it out to make it rich.
Hide Signatures
       Post #: 1022
RE: Redcat Racing Tornado Thread - 9/15/2007 1:25 AM
hibityhupla
Score: 100
Status: offline
quote:
ORIGINAL: blakeyboy250
The part # for the clutch and spring is 02048 . As far as the running problem Try to adjust the idle. Take the air filter off so you can see what your doing and make sure the carb is open 1-1 1/2mm. After that maybe try leaning it out a 1/4 turn. I would try the idle first.
Hide Signatures
       Post #: 1023
RE: Redcat Racing Tornado Thread - 9/15/2007 1:33 AM
hibityhupla
Score: 100
Status: offline
If anyone has the o.s18cv-rx in their buggy and really wants to make it fly buy the hpi threaded clutch bell with the 18t and 23t gears and order the redcat lightning transmission # 02076. With the stock engine I couldn't make it shift but with the o.s. the car flies. I raced my buddy who is still running his stock and I can almost beat him without shifting but after I hit second it isn't even a race anymore.
Hide Signatures
       Post #: 1024
RE: Redcat Racing Tornado Thread - 9/15/2007 2:04 AM
newdoughboy
Score: 100
Status: offline
Hey guys, thanks for all your help,
could you tell me if this will fit my tornado bb?
HPI NITRO MT2 MT 2 18SS+ Header+Black Coupler HM22
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&rd=1&item=110162534311&ssPageName=STRK:MEWA:IT&ih=001
Hide Signatures
       Post #: 1025
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.938RCU1
