RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  128 129 [130] 131 132 133 134 135 136 137   next >   >>
Login
RE: Redcat Racing Tornado Thread - 2/4/2009 2:55 PM
joeyhatch11
Last Login: 5/16/2013
Status: offline
Here's a pics of what their talking about. http://www.hpiracing.com/products/en/85040/ It's a set of all three Front, Rear and Center. All it is, is a shell you still have to get the gears, slipper and whatever else is needed to make it work. Has anyone done this conversion yet? Will the stock spur gear fit in this tranny?
Hide Signatures
(in reply to clontz_wi64)
       Post #: 3226
RE: Redcat Racing Tornado Thread - 2/5/2009 2:09 AM
jambafromhell
Last Login: 11/26/2009
Status: offline
would you still nead the new clutch bell if you just get the tranny
Hide Signatures
       Post #: 3227
RE: Redcat Racing Tornado Thread - 2/5/2009 2:27 AM
jambafromhell
Status: offline
Hide Signatures
       Post #: 3228
RE: Redcat Racing Tornado Thread - 2/5/2009 2:33 AM
clontz_wi64
Last Login: 6/12/2009
Status: offline
the bolt pattern on that hpi mt2 tranny is different.... its not perfect squared bolt pattern like the tornado...... i think i'll just stick with the regular tornado single speed
< Message edited by clontz_wi64 -- 2/5/2009 2:34 AM >
_____________________________
Tornado BB vx.18 stock
Building tornado trx 3.3
Hide Signatures
(in reply to jambafromhell)
       Post #: 3229
RE: Redcat Racing Tornado Thread - 2/5/2009 2:41 AM
joeyhatch11
Status: offline
Yeah it looks like it'll be a pain in the as$ to do. Just play it safe with the stock set-up and you'll be fine.
Hide Signatures
       Post #: 3230
RE: Redcat Racing Tornado Thread - 2/5/2009 4:01 AM
jambafromhell
Status: offline
thanks for the tranny help does any body know stock needle valve AND idle skrew settings
Hide Signatures
(in reply to joeyhatch11)
       Post #: 3231
RE: Redcat Racing Tornado Thread - 2/5/2009 4:08 AM
joeyhatch11
Status: offline
HSN is 3 turns out. LSN say's 2 1/2 turns out. But I've found with that, that the engine is hard to start. I turned it in 1/2 turn and she kick right over. So 2 turns out on the LSN. Thats your starting point and you can tune from there.
Hide Signatures
       Post #: 3232
RE: Redcat Racing Tornado Thread - 2/5/2009 4:10 AM
joeyhatch11
Status: offline
Right now in Jersey it's been between 20-37 outside. My HSN is set and 2 3/4 turns out and I think my LSN is 1 1/2.
Hide Signatures
       Post #: 3233
RE: Redcat Racing Tornado Thread - 2/5/2009 6:04 AM
jambafromhell
Status: offline
well i am in Baltimore so were a little warmer, but do you know your idle skrew?
Hide Signatures
       Post #: 3234
RE: Redcat Racing Tornado Thread - 2/5/2009 6:23 AM
perhamrocks
Last Login: 2/9/2011
Status: offline
quote:
ORIGINAL: joeyhatch11
Actually the high speed needle is 2 1/2 turns out and the low speed is flush with the casing
Hide Signatures
       Post #: 3235
RE: Redcat Racing Tornado Thread - 2/5/2009 7:53 AM
mileslong
Last Login: 2/2/2013
Status: offline
hey guys just to clear tis up i didn't use the HPI tranny case. I just used the slipper clutch and shaft out of a MT2 and mounted it in the stock case. sorry for the confusion
Hide Signatures
       Post #: 3236
RE: Redcat Racing Tornado Thread - 2/5/2009 2:34 PM
joeyhatch11
Status: offline
Perhamrocks, I understand they say set the LSN flush but when I do, I can pull the pull start all day long and I get no where. It's only when I turn it in all the way and then back out 1 1/2 turns I'm able to get her to kick over. At which point the LSN is set no wheres near flush which I thought was very odd and wrong but it seems to work great this way.
Just last night I read a post made by the Owner of RedCatRacing I believe where he said that the HSN factory setting is 2 1/2 turns out and the LSH is 1 1/2. I'll try to find it and repost it. But I do follow "stock" setting. MY Hpi T-15 is set that way.
Hide Signatures
(in reply to mileslong)
       Post #: 3237
RE: Redcat Racing Tornado Thread - 2/5/2009 2:41 PM
joeyhatch11
Status: offline
Post was made by HimotoRacing: Engine manufacturers often include base-line settings for the mixture needles, so it’s wise to start with these. If this information is not provided, then you must arrive at needle settings that will get the engine started. A universal starting point is usually about 1 turn open (counterclockwise) on the low-speed needle and somewhere in the 2- to 3-turn range on the high-speed needle. This varies among engines, but it gets you started running, and then you can make the necessary corrections.
Hide Signatures
       Post #: 3238
RE: Redcat Racing Tornado Thread - 2/6/2009 4:27 AM
jambafromhell
Status: offline
but still does any body know IDLE SKREW!!!!!!!!
Hide Signatures
       Post #: 3239
RE: Redcat Racing Tornado Thread - 2/6/2009 4:29 AM
amf66
Last Login: 4/30/2013
Status: offline
First take off the air filter and look into the carb. When you apply the breaks the opening sould be about 1 mm. Turn the screw ccw for faster idle (bigger opening) and cw for slower idle and a smaller opening.
Tower Terror | HPI Nitro Rush | Himoto MTR-3
Join the Himoto revolution!
Hide Signatures
       Post #: 3240
RE: Redcat Racing Tornado Thread - 2/6/2009 5:37 AM
clontz_wi64
Status: offline
ahhhh but what about the gear?? does it fit too??
so would i be able to use the mt2 shaft, slipper clutch, and gear?? or will that gear fit..... and is it even a metal gear?
Hide Signatures
       Post #: 3241
RE: Redcat Racing Tornado Thread - 2/6/2009 5:39 AM
clontz_wi64
Status: offline
i guess i'll use their single speed from red cat but a jato 3.3 engine and clutch bell
probly a 14t with the tire/wheel i'm using..... not as big as a truggy's but bigger than stock
< Message edited by clontz_wi64 -- 2/6/2009 5:41 AM >
Hide Signatures
       Post #: 3242
RE: Redcat Racing Tornado Thread - 2/7/2009 5:43 PM
breezerboat
Last Login: 6/4/2010
Status: offline
I must be a freaking idiot. I have a redcat lightning and seem to have it out of tune and dont know what the hell I'm doing. I wish I could get it to it's factory setting again. And I really wish I had not started messing with those tuning needles. CRAP.
Hide Signatures
       Post #: 3243
RE: Redcat Racing Tornado Thread - 2/7/2009 7:34 PM
joeyhatch11
Status: offline
HSN- 2 3/4
LSN- Either 2 or 1 3/4
Idle- 1mm gap ( dont know turns on that one)
That'll bring you back to stock.
Hide Signatures
(in reply to breezerboat)
       Post #: 3244
RE: Redcat Racing Tornado Thread - 2/8/2009 12:23 AM
breezerboat
Status: offline
thank you so much. I got it working again. I am so happy it's not all screwed up.
Hide Signatures
       Post #: 3245
RE: Redcat Racing Tornado Thread - 2/8/2009 12:33 AM
joeyhatch11
Status: offline
Not a problem. Glad I could help
Hide Signatures
       Post #: 3246
RE: Redcat Racing Tornado Thread - 2/8/2009 8:30 PM
skyjake
Last Login: 4/17/2009
Status: offline
Setup Problems - Wheels Spin even though idle scree is down all of the way. We also tried to adjust the speed needles.
We are in the process of breaking in the engine. Have run one tank of gas. Now ready to do the figure 8's, but cannot until the engine is running and the wheels are not spinning.
Thanks for your help.
Hide Signatures
(in reply to ehroof)
       Post #: 3247
RE: Redcat Racing Tornado Thread - 2/8/2009 10:26 PM
chevyderek72
Last Login: 11/8/2010
Status: offline
Ok put your needles to factory settings
Hsn- 2.5-3 turns out
Lsn- flush with the collar
And then put your idle to about 1mm gap, take your air filter off and make sure the gap is about 1mm.
Make sure when your braeking in your engine gets to at least 200, but no too hott. You wanna run it rich and give it extra fuel, but not too much.
Your idle should be good at those settings, also pull on the pull cord, if the wheels wanna turn with it then your clutch spring is broke. OR if your car wont stay on unless moving its broken
Redcat Racing - Dunerunner, Hurricane XP, Aftershock 8e, Volcano, Volcano epx, Vortex epx, Tremor 18e pro
Its me ti**ta
Hide Signatures
(in reply to skyjake)
       Post #: 3248
RE: Redcat Racing Tornado Thread - 2/9/2009 12:12 AM
joeyhatch11
Status: offline
With the needles set right and the wheels still wanna move turn your LSN needle out 1/8 turn. You'll notice later once your done break in and tunning for performance, that when you turn you LSN in it'll also bring the rpm's up. Which is fine as long as your still getting performance out of it. Once you done adjusting you high and low speed needles, turn out you IDLE set screw till it has a nice easy idle to it. But for now, just turn you LSN out a hair.
While breaking in my sh .18 my buggy kept creaping on me. I turned out my LSN and it calmed it down till I was done break in.
Hide Signatures
(in reply to chevyderek72)
       Post #: 3249
RE: Redcat Racing Tornado Thread - 2/9/2009 5:24 AM
el_tonto
Last Login: 6/29/2011
Status: offline
quote:
ORIGINAL: skyjake
Setup Problems - heels Spin even though idle scree is down all of the way.
I think "Down" all the way would raise the idle. You want to back the screw out to lower the idle.
Turn your clutch bell by hand there should be no metal-on-metal rubbing feel or anything like. If there is then the clutch spring might be busted causing the clutch to be always engaged. In which case it'll never idle low enough not to spin the wheels. Busted clutch spring happened to me at break in.
Hide Signatures
       Post #: 3250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.707RCU1
