RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  134 135 [136] 137 138 139 140 141 142 143   next >   >>
Login
RE: Redcat Racing Tornado Thread - 4/19/2009 7:39 PM
lodemup
Score: 100
Last Login: 4/20/2009
Status: offline
I have a fairly new tornado - less than a month old- less than a gallon run through it. It ran out of control and ran into a brush pile so it didn't end with a hard impact, but after that the on/off switch on the car quit working-. it was replaced/upgraded. The batteries were changed and now the buggy loses signal at about 15ft from the transmitter. Will run fine in a circle or figure 8's near the controller but once the buggy gets a little further out, it zooms off on its on. Batteries are new, battery pack tests to be fine, does the same thing with recharables in it. Any suggestions?? Thanks!!
Hide Signatures
(in reply to Chubbysdad)
       Post #: 3376
RE: Redcat Racing Tornado Thread - 4/19/2009 11:16 PM
neyou86
Score: 105
Last Login: 1/4/2012
Status: offline
im not sure about this, but try a new crystal
Hide Signatures
(in reply to lodemup)
       Post #: 3377
RE: Redcat Racing Tornado Thread - 4/19/2009 11:19 PM
neyou86
Score: 105
Status: offline
my dogbones keep on bending in my rear when i jump, is there something wrong with my car
is there an upgrade for stonger ones
Hide Signatures
(in reply to neyou86)
       Post #: 3378
RE: Redcat Racing Tornado Thread - 4/19/2009 11:28 PM
lodemup
Score: 100
Status: offline
Ok I have another set here. Will give the new crystals a try. Thank you. ++++++ EDIT ++++ Tried another set.. still have the same problem
Hide Signatures
       Post #: 3379
RE: Redcat Racing Tornado Thread - 4/19/2009 11:40 PM
randyb1608
Score: 100
Status: offline
lodmeup i had the same problem with my tornado taking off people say buy a failsafe and all that but they dont work for me the simplest thing i did was found a spring of some sort and hook it to the back under the wing and then the other end to the throttle rod or all the way to the throttle linkage so when you go full out and let it snap back to the neutral possision the carb will go right back to idel and if there is an electronic malfunction the spring dont require batterers so that should help and it's cheaper then the fail safe hope this helps
Cameron the owner of redcat told me 2 do this he said he uses this method on all his rc cars and trucks
Randy
Hide Signatures
       Post #: 3380
RE: Redcat Racing Tornado Thread - 4/19/2009 11:46 PM
neyou86
Score: 105
Status: offline
what wt of shock oil should i use for jumping
Hide Signatures
(in reply to randyb1608)
       Post #: 3381
RE: Redcat Racing Tornado Thread - 4/20/2009 12:00 AM
lodemup
Score: 100
Status: offline
Well, the problem is not that the tornado takes off..... its that after 15 ft I have no control. I've been running it at far more distance than that and been fine previous to this. I want to get atleast my original range back if not more. If 15 ft is as far as it can get from me then I might as well give it to a 4 year old. 15 ft wont even get me to the first curve on the track much less all the way around.... and I've been running the whole track with no problem before now.
Hide Signatures
       Post #: 3382
RE: Redcat Racing Tornado Thread - 4/20/2009 12:05 AM
neyou86
Score: 105
Status: offline
check to see if ur antena is cut
Hide Signatures
       Post #: 3383
RE: Redcat Racing Tornado Thread - 4/20/2009 12:22 AM
lodemup
Score: 100
Status: offline
NEyou86: Thanks. I've looked and looked... I don't see or feel any knicks, cuts, etc. I even tried leaving all the guts ( the battery box, the wires , & receiver) out of the protector box , had my daught walk away with the controller and still repeatidly loses signal at 15ft. Thought maybe I was pinching a wire when I was stuffing them back in, but that wasn't it either.
Hide Signatures
       Post #: 3384
RE: Redcat Racing Tornado Thread - 4/20/2009 12:27 AM
AllAboutFunHobbies
Score: 100
Last Login: 11/10/2011
Status: offline
Your transmitter or reciever is bad. Unless you have another working setup, there won't be anyway to tell which is bad. About all you can do is send the transmitter and reciever back to redcat if you still are under the 30 day warrenty. If not then your gonna have to buy a new radio system.
_____________________________
Dealer for..Redcat, Traxxas, Associated, Cen, Racers Edge, RD Logic, Losi, HPI, E-flight, Himoto, Venom, Heli-Max, O.S...etc
Hide Signatures
       Post #: 3385
RE: Redcat Racing Tornado Thread - 4/20/2009 12:32 AM
lodemup
Score: 100
Status: offline
quote:
ORIGINAL: AllAboutFunHobbies
Well, pooshies, LOL..... I'll be sending an email to them tonight then. thanks so much for your help.
Hide Signatures
(in reply to AllAboutFunHobbies)
       Post #: 3386
RE: Redcat Racing Tornado Thread - 4/20/2009 12:38 AM
AllAboutFunHobbies
Score: 100
Status: offline
Your welcome, Email nick@redcatracing.com
< Message edited by AllAboutFunHobbies -- 4/20/2009 12:39 AM >
Hide Signatures
       Post #: 3387
RE: Redcat Racing Tornado Thread - 4/20/2009 1:53 AM
randyb1608
Score: 100
Status: offline
cameron@redcatracing.com thats the email i have for the owner he is cool and like to talk shop
Hide Signatures
       Post #: 3388
RE: Redcat Racing Tornado Thread - 4/20/2009 3:36 AM
lodemup
Score: 100
Status: offline
Awesome, ya'll have been great. I appreciate it so much.
Hide Signatures
       Post #: 3389
RE: Redcat Racing Tornado Thread - 5/7/2009 12:56 AM
419screaminrieman
Score: 100
Last Login: 5/11/2009
Status: offline
ok i have a question. i recently ran across shims that are to be used in the vertex .18 engine. i was just wondering what would be the benefit of having them seeing as how my engine doesnt use any. thanks.
Hide Signatures
       Post #: 3390
RE: Redcat Racing Tornado Thread - 5/8/2009 12:22 AM
harley75
Score: 100
Last Login: 5/17/2009
Status: offline
Question on the hpi gears and clutch bell i got these gears the guy sold me one is a 18 the other is a 22 now will i be able to use these or do i got to get 17 to run with the 22.
Hide Signatures
       Post #: 3391
RE: Redcat Racing Tornado Thread - 5/17/2009 10:23 PM
BigDave09
Score: 100
Last Login: 8/23/2010
Status: offline
i cant get my sh.18 to work new glow plugs and im useing traxxas top fuel
Hide Signatures
(in reply to ehroof)
       Post #: 3392
RE: Redcat Racing Tornado Thread - 5/17/2009 10:40 PM
harley75
Score: 100
Status: offline
quote:
ORIGINAL: BigDave09
check glow plug sometimes you can buy them bad now turn high needle out 2-1/2 turns from close and set lsn flush with coller also check for air leaks i had one that wouldn't start i beat my brains out here it was the o-ring around the gas tank lid
Hide Signatures
(in reply to BigDave09)
       Post #: 3393
RE: Redcat Racing Tornado Thread - 5/17/2009 10:42 PM
BigDave09
Score: 100
Status: offline
the glow plug is good i put it to my ignitor and it glows orange and the tank is sealed
Hide Signatures
(in reply to harley75)
       Post #: 3394
RE: Redcat Racing Tornado Thread - 5/17/2009 10:59 PM
BigDave09
Score: 100
Status: offline
when i get the gas 2 go 2 the engine air bubbles are in it does that cause it not 2 start and could it be the seal
Hide Signatures
       Post #: 3395
RE: Redcat Racing Tornado Thread - 6/10/2009 6:03 AM
clontz_wi64
Score: 100
Last Login: 6/12/2009
Status: offline
well i'm back on the 3.3 traxxas project again........ here it is so far....i just need
header, muffler, 3.3 carb
i'm having to order the 3.3 clutch and using my stock 2 speed bell but i half to grind the bell down so it wont touch the 3.3's flywheel and hoping the diamater of the 3.3 clutch will fit inside the stock bell gear
i know the bell gear looks crooked its just sitting on ther!!!! its not on yet, still waiting on the cluch shoes
 i will half to drill new slots closer for the motor mounts....
the stock mounts just needed a little clearing to fit on the motor....
i have upgraded with jato shocks and new black body, new wing, high torque and faster servos i think 7.7kg's but i forget the 60 degree turn times but the are faster than stock ones, new fuel/air filters, gas tank..... everything is new pretty much, along with clutch on 2 speed and brake disc
it should be done this month and the motor looks sicccck...... hoping  to get this 2 speeded 3.3 tornado done and videoed
i will be running 25% nitro for a little more kick and still be dependable.
let me know what ya think
enjoy pics
Tornado BB vx.18 stock
Building tornado trx 3.3
Hide Signatures
       Post #: 3396
RE: Redcat Racing Tornado Thread - 6/11/2009 11:02 PM
sailman7999
Score: 100
Last Login: 5/6/2010
Status: offline
I have another question;  for some reason when I turn the car it can turn to the left normally but it turns to the right slow and sometimes skips. The radio is fine and so are all the connections. I have no idea what could of caused this, can you please help?
Hide Signatures
(in reply to clontz_wi64)
       Post #: 3397
RE: Redcat Racing Tornado Thread - 7/3/2009 2:13 AM
jsalam
Score: 100
Last Login: 7/10/2009
Status: offline
my redcat tornado is messing up and i need some help the steering servo's was acting up and i bought a new one and now  when i was driving the wheel turned and kept it there untill i either turn the controller or the batteries off and when i turn it back it turns by it self  and i can control the throttle but it wont move when i try to control it if you now what this problem is could you please help is it contoller,steering servo, transmitter, or somthing else thanks
Hide Signatures
       Post #: 3398
RE: Redcat Racing Tornado Thread - 7/3/2009 10:49 AM
nubzorz
Score: 105
Last Login: 5/19/2010
Status: offline
quote:
ORIGINAL: holliwud
redcatz needz 2 start makin som metal gears for this tornado, they making a killin off me buying spare gears. i think these plastic gearz are ca ca do do. i want to try buying different gears but metal gears r so expensive, i don't wanna go buyin dem so recklessly.HOW R YA'LL DEALIN WIT DA GEARS? N YES I DO HAVE DA NEW CLUTCH BELL SET UP
i own 3 redcats never striped a spur gear so... i think its a user error mesh your gears properly
Maxx 2.5, Revo 3.3, Savage XL,Ofna lx1,Tornado BB,Pede xl-5,exceed infinity,redcat lightning, redcat Vortex SS,CEN FF/NX
Hide Signatures
(in reply to holliwud)
       Post #: 3399
RE: Redcat Racing Tornado Thread - 7/3/2009 10:51 AM
nubzorz
Score: 105
Status: offline
is the trim working on the radio? well you could try taking the servo horn off and positioning it in a different spot on the server so that when you turn the truck on the wheels stay straight
Hide Signatures
(in reply to jsalam)
       Post #: 3400
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.047RCU1
