RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  136 137 [138] 139 140 141 142 143 144 145   next >   >>
Login
RE: Redcat Racing Tornado Thread - 7/14/2009 6:41 AM
bkfamily1
Score: 100
Last Login: 5/17/2013
Status: offline
Undet - the blue loctite is removable. It will stop screws from vibrating loose, and it will make them harder to remove. But it is not "too hard."
I had the same thing happen to me with the screw pulling through the chassis. Check this post. http://www.rcuniverse.com/forum/fb.asp?m=7590060. It happened to me after I had been running the vehicle hard and frequently for a few months, and the washers worked for me.
_____________________________
September 11, 2001
Never Forget
Hide Signatures
(in reply to neyou86)
       Post #: 3426
RE: Redcat Racing Tornado Thread - 7/15/2009 12:44 AM
Undetermined
Score: 100
Last Login: 10/20/2011
Status: offline
Does anybody have any good walkthroughs on checking air leaks? I am pretty sure I am leaking air from my HSN. It runs great for 1/4 tank or so, then it dies. When I try to start it, there are air bubbles coming up the fuel line from the HSN.
Undetermined
I didn''t do it, or at least I don''t remember doing it...
Hide Signatures
(in reply to bkfamily1)
       Post #: 3427
RE: Redcat Racing Tornado Thread - 7/15/2009 6:20 AM
neyou86
Score: 105
Last Login: 1/4/2012
Status: offline
there is a video on youtube that a guy named squirel made about that
alright well i replace the oring with a one from a fleet farm and it still leaks, but now i notice a crack in the tank. i dont really wanna order a $5 part and pay $7 shipping.
Hide Signatures
(in reply to Undetermined)
       Post #: 3428
RE: Redcat Racing Tornado Thread - 7/15/2009 7:54 AM
BigDave09
Score: 100
Last Login: 8/23/2010
Status: offline
if ur checking for airleaks then ur soap and water and put sopywater around all the spots that could leak if u find the leak then take some gasket sealer for engines an seal it thats all the ifo i can give hope it works and gl
Hide Signatures
       Post #: 3429
RE: Redcat Racing Tornado Thread - 7/15/2009 8:50 AM
firebird78
Score: 105
Last Login: 12/8/2011
Status: offline
quote:
ORIGINAL: Undetermined
Undetermined
what I do is this....I remove the fuel line from the carb and the exhaust...put my finger over one end and blow in the other, it should hold pressure..if you blow hard enuff (and you dont have a leak) the lid on the tank will pop up, means good seal....I'm thinking along these lines is were your problem lays...if I hear a leak or it doesnt hold pressure I start removing fuel lines from the tank and checking them seperate...then I re-attach one to the tank and check the tank and the lid o-ring
if it all checks out good I move to a visual inspection of the engine, looking for fuel (usually if your backing plate is the issue you will have fuel under it)....if I dont see any problems I check the cooling head (tightening in a X pattern)...then I pull my adjustment needles and inspect the 0=rings...my last resort is to pull the engine, reseal the backingplate and carb with sylicone..
keep the shiney side up, the hammer down and the marshalls bored.....himoto rxb-1...himotoracingusa
Hide Signatures
       Post #: 3430
RE: Redcat Racing Tornado Thread - 7/17/2009 7:20 AM
Undetermined
Score: 100
Status: offline
I would highly recommend against blowing into the tank. I emptied it and pulled the lines. However, there was a small amount that did not come out. Once pressurized, it blew out the tube and all over me. Bad idea. However, I did not locate any leaks. I have checked the engine, carb, fuel lines, pull start, exhaust. AHHH, I AM GETTING ANNOYED.
So, I am taking my 30 day old Tornado back to the dealer, and he said he would look at it. It will take a couple of days or a couple of hours if I stay and he teaches me a few things while checking it over.
Will let you know, but on a side note... I flipped my car while it was running for more than 30 seconds and it landed on it's cooling head. Broke half the top colling head. No big deal, but it sure slide a long ways on the concrete.
To be continued...
Hide Signatures
(in reply to BigDave09)
       Post #: 3431
RE: Redcat Racing Tornado Thread - 7/17/2009 11:47 AM
chevyderek72
Score: 100
Last Login: 11/8/2010
Status: offline
Ive heard people putting nitro in a spray bottle and while the engine is running spray the motor, and if the motor changes rpms you found your leak.
Redcat Racing - Dunerunner, Hurricane XP, Aftershock 8e, Volcano, Volcano epx, Vortex epx, Tremor 18e pro
Its me ti**ta
Hide Signatures
       Post #: 3432
RE: Redcat Racing Tornado Thread - 7/20/2009 8:42 AM
nubzorz
Score: 105
Last Login: 5/19/2010
Status: offline
just order a new tank if you dont want to pay more for shipping than the actual item just order what youll need eventually. im sure your gonna need spur gears and glowplugs in the future so might aswell order a few of those also.
Maxx 2.5, Revo 3.3, Savage XL,Ofna lx1,Tornado BB,Pede xl-5,exceed infinity,redcat lightning, redcat Vortex SS,CEN FF/NX
Hide Signatures
       Post #: 3433
RE: Redcat Racing Tornado Thread - 7/20/2009 5:52 PM
neyou86
Score: 105
Status: offline
i got other stuff that i should order but i dont have any money to order and i just got an order
Hide Signatures
(in reply to nubzorz)
       Post #: 3434
RE: Redcat Racing Tornado Thread - 7/20/2009 11:16 PM
neyou86
Score: 105
Status: offline
hey guys i might be trading my tornado for a traxxas rustler xl5. its not the water proof version. should i do it?
Hide Signatures
       Post #: 3435
RE: Redcat Racing Tornado Thread - 7/21/2009 1:52 AM
chevyderek72
Score: 100
Status: offline
I wouldnt do it. plus if it doesnt come with some decent batteries and a decent charger your gonna have to buy them.
Its me ti**ta
Hide Signatures
       Post #: 3436
RE: Redcat Racing Tornado Thread - 7/21/2009 1:58 AM
neyou86
Score: 105
Status: offline
it comes with a battery and charger also it has paddle tires and aluminum front shocks
Hide Signatures
(in reply to chevyderek72)
       Post #: 3437
RE: Redcat Racing Tornado Thread - 7/21/2009 8:59 AM
chevyderek72
Score: 100
Status: offline
I mean it depeneds on you. What is the price comparison, and which would you rather have, you know?
Its me ti**ta
Hide Signatures
       Post #: 3438
RE: Redcat Racing Tornado Thread - 7/21/2009 4:39 PM
neyou86
Score: 105
Status: offline
well i think im gunna go for the rustler cuz then i dont need to order parts all the time it breaks and i dont really like the mess and trouble with nitro. the rustler is $100 i got offered $150 for my tornado but i figured that ill have him drive to my house so that the difference is made up.
Hide Signatures
       Post #: 3439
RE: Redcat Racing Tornado Thread - 7/22/2009 12:02 PM
basketballfan60123
Score: 103
Last Login: 9/18/2012
Status: offline
How do you put the clutchbell together ? I am having problems with shredding my 47 tooth spur gear on my tornado buggy; have gone through 5 of them regardless of how i set the gear mesh.
I have an sh18 engine; will this work for mine?
If so can you send me some pics on how this is done.
basketballfan60123@lycos.com
I always tell the truth. Even when I lie. Al Pacino (Scarface 1983)
Hide Signatures
(in reply to ehroof)
       Post #: 3440
RE: Redcat Racing Tornado Thread - 7/22/2009 5:32 PM
neyou86
Score: 105
Status: offline
what do you mean put the clutchbell together? did you get the hpi one? or did u buy a new one from redcat? do u want to know how to put the bearings in?
Hide Signatures
(in reply to basketballfan60123)
       Post #: 3441
RE: Redcat Racing Tornado Thread - 7/22/2009 5:52 PM
neyou86
Score: 105
Status: offline
alright guys now im having tuning trouble. i had my car tuned for about 60 degrees farenheit(outside temp) and now that its 80 degrees it runs terrible. if i do a high speed run then turn round and start to do another it doesnt have enough power to make it move. ive got the hsp at 3 turns out and the low speed flush cuz that seems to be what it used to like. ive changed the plug and fixed the fuel tank leak. also when i try starting it, it will run for a second and then shut off, so i keep trying and i gotta sit and pul for 15 minutes. its starting to get old and the guy that wants to trade is taking forever to reply.
Hide Signatures
       Post #: 3442
RE: Redcat Racing Tornado Thread - 7/23/2009 5:03 AM
basketballfan60123
Score: 103
Status: offline
the hpi one. I want to know how to put it together and how to install it in my tornado bb
Hide Signatures
       Post #: 3443
RE: Redcat Racing Tornado Thread - 7/23/2009 8:48 AM
BigDave09
Score: 100
Status: offline
quote:
ORIGINAL: neyou86
i used to have the same problem I adjusted the idle screw and now runs great and u might wanna check your glow plug
Hide Signatures
       Post #: 3444
RE: Redcat Racing Tornado Thread - 7/23/2009 4:52 PM
neyou86
Score: 105
Status: offline
did u raise it or lower it?
Hide Signatures
       Post #: 3445
RE: Redcat Racing Tornado Thread - 7/23/2009 4:53 PM
neyou86
Score: 105
Status: offline
basketballfan- look back some pages in this thread, its been covered alot. i would help you but i dont have the hpi one
Hide Signatures
       Post #: 3446
RE: Redcat Racing Tornado Thread - 7/25/2009 9:03 PM
shotgun32
Score: 100
Last Login: 3/19/2012
Status: offline
hello, all. Got a Tornado BB, broke it in according to manual and it ran beauty right from first pull. Fourth tank was just idling around, running at 140 degrees, decided to open it just a bit. It shifted in 2nd and I backed out of it,  di this a couple times. Third time or so I noticed a clicking sound when I was slowing down. Sped it up again and no shift... but it did click when slowing down. Insepected the Centrifugal clutch and noticed the arm moved outward, half the travel it should with no resistance. I tried turning allen in to tighten spring but it still had no resistance. Now I have had this a couple hours and I'm taking the transmission out to get a closer look at the clutch .  It seems the spring is fine but the ball will not go all the way to the arm...   Is this something that can be fixed? should I be looking at why the ball doesn't make contact or do I need a new clutch, already?  Any helps really appreciated, thanks
Hide Signatures
(in reply to Chubbysdad)
       Post #: 3447
RE: Redcat Racing Tornado Thread - 7/25/2009 9:09 PM
neyou86
Score: 105
Status: offline
your grub screw most likely came out. did it seem like it accelerated slower? if so then you will need a new two speed clutch
Hide Signatures
(in reply to shotgun32)
       Post #: 3448
RE: Redcat Racing Tornado Thread - 7/25/2009 9:54 PM
shotgun32
Score: 100
Status: offline
 No the grub screws were both there, actually looks like the bottom of shifting lever where balls rubs against got deformed,  or at least doesn't look perfect. Does anyone know is the ball supposed to travel all the way through the clutch housing, eg: if shifting arm is out of housing will the ball go all the way through the channel? or does it stop short of falling out? I wouldn't mind replacing it if I got more then 100 feet driving, was kind of hoping a bad decision would be cause of my first replacment parts.
Hide Signatures
       Post #: 3449
RE: Redcat Racing Tornado Thread - 7/25/2009 10:14 PM
neyou86
Score: 105
Status: offline
i have no clue about that ball thing, i didnt think there was a ball in the 2 speed clutch. is it what the arm pushes on when its lifted up?
Hide Signatures
       Post #: 3450
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.094RCU1
