RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  137 138 [139] 140 141 142 143 144 145 146   next >   >>
Login
RE: Redcat Racing Tornado Thread - 7/26/2009 1:37 AM
glk420247
Score: 100
Last Login: 5/10/2012
Status: offline
It is not shifting because your stuck in second gear. Check this tread out bro. This one is from way back. Read post # 20 about half way down http://www.rcuniverse.com/forum/m_4207842/mpage_1/key_/tm.htm
You will have to take it out and clean it.. This is an age old problem with the 2 speed clutch. The little thing takes a beating when it shifts. I went though 3 of them before I got a good one. Just my 2 cents.
One more thing make sure the steel pin is there in the spur gear.
Later, Fong
< Message edited by glk420247 -- 7/26/2009 1:46 AM >
_____________________________
Team Losi Lst2 (Kick azz truck)
Hide Signatures
(in reply to shotgun32)
       Post #: 3451
RE: Redcat Racing Tornado Thread - 7/26/2009 1:45 AM
neyou86
Score: 105
Last Login: 1/4/2012
Status: offline
hey guys my tornado wishes it could fly haha. it only runs good off the ground but it starts on the ground. i got it started drove it 5 feet and it seemed like it had no power and then it died. any ideas. ill give it a full check out tommorow but i figured i would see if you guys knew what the problem could be.
Hide Signatures
(in reply to glk420247)
       Post #: 3452
RE: Redcat Racing Tornado Thread - 7/26/2009 1:51 AM
glk420247
Score: 100
Status: offline
You broke your spring That goes around your clutch. Take your clutch bell off and you will see your spring has broken. Try replacing with this one.http://www3.towerhobbies.com/cgi-bin/wti0095p?FVSEARCH=4146x&FVPROFIL=++&search3=Go You only use the spring. Good luck bro.
Check this Thread out and look into buying the Hpi A885 clutch shoe.Clutch spring
Here is a link to the Hpi A885 clutch shoe. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLW03&P=FR
< Message edited by glk420247 -- 7/26/2009 2:04 AM >
Hide Signatures
(in reply to neyou86)
       Post #: 3453
RE: Redcat Racing Tornado Thread - 7/26/2009 7:17 AM
shotgun32
Score: 100
Last Login: 3/19/2012
Status: offline
thanks for the ideas but thinking its not dirt,  this buggy is brand new, only driven 200 feet on clean pavement at 1/4 to half throttle, the clutch was shiney in my hand. I think the arm is damaged where the ball makes contact but can't take arm out without destroying clutch,  so guess I'll order one, then maybe destroy this and see if right, thanks again.
Hide Signatures
       Post #: 3454
RE: Redcat Racing Tornado Thread - 7/26/2009 7:40 PM
neyou86
Score: 105
Status: offline
alright i didnt find anything wrong really but i noticed i had one wheel nut too tight and it was rubbing on the nuckle. could that have caused it
Hide Signatures
       Post #: 3455
RE: Redcat Racing Tornado Thread - 7/27/2009 2:09 AM
whauburger
Score: 100
Last Login: 7/22/2010
Status: offline
My tornado was running fine and I havn't used it in about two months, when I went to run it the other day it would shut off as soon as it shifted into 2nd gear any ideas?
Hide Signatures
       Post #: 3456
RE: Redcat Racing Tornado Thread - 7/27/2009 2:33 AM
neyou86
Score: 105
Status: offline
adjust it to shift later. that should do the trick
Hide Signatures
(in reply to whauburger)
       Post #: 3457
RE: Redcat Racing Tornado Thread - 7/27/2009 2:46 AM
neyou86
Score: 105
Status: offline
hey, im pretty sure my one way bearing is out in my pull start. which one is better the hpi one or the redcat racing one?
Hide Signatures
       Post #: 3458
RE: Redcat Racing Tornado Thread - 7/28/2009 10:40 AM
BigDave09
Score: 100
Last Login: 8/23/2010
Status: offline
I cant really just wich owb is better but i can say i've had mine owb from redcat for three months and i haven't had a problem I would say there all pro rated the same just depends on how you use yours
Hide Signatures
       Post #: 3459
RE: Redcat Racing Tornado Thread - 7/28/2009 9:56 PM
Undetermined
Score: 100
Last Login: 10/20/2011
Status: offline
Any ideas on how to keep the gas tank from letting air into the lines? When my tank gets below about 1/2 tank, and I hit some little bumps, my car gets a lot of air in the lines and chokes out. Was thinking of some rubber grommets at the bottom where it mounts to the chassis. Not sure yet.
I didn''t do it, or at least I don''t remember doing it...
Hide Signatures
       Post #: 3460
RE: Redcat Racing Tornado Thread - 7/28/2009 11:35 PM
neyou86
Score: 105
Status: offline
hi when i start my tornado it runs good but then i drive it 10 feet and it dies. what is the problem? could it be the fuel tank?
Hide Signatures
(in reply to Undetermined)
       Post #: 3461
RE: Redcat Racing Tornado Thread - 7/29/2009 6:37 AM
chevyderek72
Score: 100
Last Login: 11/8/2010
Status: offline
Put it back to factory specs and tune from there. Its probably tuning. If you have a crack in your tank then you wont be able to go high rpms because the engine cant suck fuel to it anymore, it needs pressure from the exhaust.
Redcat Racing - Dunerunner, Hurricane XP, Aftershock 8e, Volcano, Volcano epx, Vortex epx, Tremor 18e pro
Its me ti**ta
Hide Signatures
       Post #: 3462
RE: Redcat Racing Tornado Thread - 7/29/2009 8:38 AM
BigDave09
Score: 100
Status: offline
quote:
ORIGINAL: Undetermined
check your air lines for leaks first and if it aint that just spend the 5 bucks and get a new tank instead of replaceing the rubber and check for cracks in the tank
Hide Signatures
       Post #: 3463
RE: Redcat Racing Tornado Thread - 8/1/2009 7:22 AM
basketballfan60123
Score: 103
Last Login: 9/18/2012
Status: offline
Just bought the HPI 2speed clutch parts fore my Tornado S30 just wondering how you put this thing together do you use threadlock to assemble it and how do you keep it from falling off the clutch shoes ?
I always tell the truth. Even when I lie. Al Pacino (Scarface 1983)
Hide Signatures
(in reply to ehroof)
       Post #: 3464
RE: Redcat Racing Tornado Thread - 8/5/2009 1:50 AM
hridge06
Score: 100
Last Login: 4/26/2010
Status: offline
 I just got finished breaking in my Tornado BB and she idles fine. When I use the brakes, the car dies. I looks like the opening in the carb closes all the way when i use the brakes. I'm new to the nitro RC. Any suggestions?
Hide Signatures
(in reply to basketballfan60123)
       Post #: 3465
RE: Redcat Racing Tornado Thread - 8/5/2009 2:02 AM
AllAboutFunHobbies
Score: 100
Last Login: 11/10/2011
Status: offline
Turn the idle screw in till it stays running when ou hit the brakes.
Dealer for..Redcat, Traxxas, Associated, Cen, Racers Edge, RD Logic, Losi, HPI, E-flight, Himoto, Venom, Heli-Max, O.S...etc
Hide Signatures
(in reply to hridge06)
       Post #: 3466
RE: Redcat Racing Tornado Thread - 9/3/2009 6:46 AM
Undetermined
Score: 100
Status: offline
Are these alright servos? I would like to get some high end ones, but honestly I am going to tear it up. I do jumps and flips, etc. Would like something decent and budget friendly.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUK84
Hide Signatures
(in reply to AllAboutFunHobbies)
       Post #: 3467
RE: Redcat Racing Tornado Thread - 9/3/2009 5:25 PM
neyou86
Score: 105
Status: offline
well its got a one year warranty so what do you have to lose
Hide Signatures
       Post #: 3468
RE: Redcat Racing Tornado Thread - 9/3/2009 8:09 PM
chevyderek72
Score: 100
Status: offline
I think the stock servo specs are close to the futaba 3003, which is only 2 oz higher than that servo. So i dont think it would be much of an upgrade, but it would work
Its me ti**ta
Hide Signatures
       Post #: 3469
RE: Redcat Racing Tornado Thread - 9/7/2009 9:17 AM
k3nv
Score: 115
Last Login: 1/5/2011
Status: offline
Have a Tornado BB and EPX, what's the biggest wheel you can put on the buggies? I want some more clearance for riding on long grassy areas.
http://www.kenbuys.com - reviews of stuff I buy
http://iphonenodata.com - disable EDGE/3G iphone
Hide Signatures
(in reply to chevyderek72)
       Post #: 3470
RE: Redcat Racing Tornado Thread - 9/9/2009 7:35 AM
chevyderek72
Score: 100
Status: offline
You can put bigger tires on, really as big as you want, but you will have to change the gear ratio.
Its me ti**ta
Hide Signatures
(in reply to k3nv)
       Post #: 3471
RE: Redcat Racing Tornado Thread - 9/22/2009 5:10 AM
LosParaZitos
Score: 100
Last Login: 10/30/2009
Status: offline
Hi all! I'm new here i just ordered my first nitro gas RC car it the Tornado S30 i wanted to know can these Rc run in the snow and if they can is there anything special that i need to get it to run in snow ( i ask this cauz I'm from Quebec,Canada and winter is coming soon ) :P thanks in advance for you answers
Hide Signatures
       Post #: 3472
RE: Redcat Racing Tornado Thread - 9/23/2009 5:08 AM
neyou86
Score: 105
Status: offline
you need to waterproof the reciever and servo. you will have to watch out for rust. snow is bad for a nitro motor. it screws up the expanding and contracting process. but if it were me i would do it.
Hide Signatures
(in reply to LosParaZitos)
       Post #: 3473
RE: Redcat Racing Tornado Thread - 9/23/2009 5:37 AM
LosParaZitos
Score: 100
Status: offline
ok thank ! anyways its my first nitro gas RC i am bound to break it in some ways wether it because of the snow or because i crashed it in a concrete wall other thing is the Sh .18 engine the biggest engine you can fit on a 1/10 RC or can i fit in a .21 engine ?
Hide Signatures
       Post #: 3474
RE: Redcat Racing Tornado Thread - 9/24/2009 3:25 AM
neyou86
Score: 105
Status: offline
you can put a trx 3.3 in it but it is hard on it. its not made for that much power. and you have to make stuff fit
Hide Signatures
       Post #: 3475
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
