RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  137 138 139 [140] 141 142 143 144 145 146   next >   >>
Login
RE: Redcat Racing Tornado Thread - 10/2/2009 3:36 AM
robster94gt
Score: 100
Last Login: 11/24/2010
Status: offline
Hey all,
I picked up a used Tornado BB from a friend. It had a broken lower arm so I couldn't do anything with it until now. I took it out for a spin today, and found that the engine ran nicely without stalling. However, every time I went full throttle, it would speed up, and then die. I took it home and was fiddling with it, and found that with the wheels spinning freely, if I went to to full throttle it would speed up, and die. It couldn't maintain wide open throttle without stalling.
To make matters worse, I started hearing some unhealthy grinding, and then checked it find - yep you guessed it - the trans gear stripped. When I would run the engine before I heard a distinctive metallic rattling - obviously the clutch bell.
I read on the first page of this forum that the replacing the clutch will take care of the stripping gear problem. I was wondering, what is it about the stock setup that strips the gears?
Bad start for my re-entry into nitro
Cheers,
Rob
Hide Signatures
(in reply to neyou86)
       Post #: 3476
RE: Redcat Racing Tornado Thread - 10/2/2009 7:11 AM
chevyderek72
Score: 100
Last Login: 11/8/2010
Status: offline
Well if its stalling at high rpm, your hsn is lean, your motor isnt getting enough fuel and stalling. Check it you have a steel or aluminum clutch bell, if its aluminum they go out of round and will eat spurs. Steel will be magnetic. Is it the 2 speed tornado? Or single speed? If 2 speed which gear stripped?
_____________________________
Redcat Racing - Dunerunner, Hurricane XP, Aftershock 8e, Volcano, Volcano epx, Vortex epx, Tremor 18e pro
Its me ti**ta
Hide Signatures
(in reply to robster94gt)
       Post #: 3477
RE: Redcat Racing Tornado Thread - 10/2/2009 7:13 AM
chevyderek72
Score: 100
Status: offline
By the way, welcome to the forum
Its me ti**ta
Hide Signatures
(in reply to chevyderek72)
       Post #: 3478
RE: Redcat Racing Tornado Thread - 10/2/2009 8:13 AM
robster94gt
Score: 100
Status: offline
Hi, thanks for the welcome.
As for the stalling, I just wanted to make it clear that it only stalls on wide open throttle. I was driving it around at high throttle no problem. Is it safe to run the engine at high rpm with the motor just mounted in the car, not powering the wheels? I just wanted to test the motor.
It's a 2 speed tornado, I'm pretty sure it's the aluminum bell, it seems softish. The gear that is stripped is the one that would match up with the smaller pinion on the bell.
Rob
Hide Signatures
       Post #: 3479
RE: Redcat Racing Tornado Thread - 10/2/2009 8:47 AM
Mickstix
Score: 105
Last Login: 11/6/2010
Status: offline
Yep, sure sounds like your highspeed needle (the screw up beside the air cleaner) is set too lean.. Give that puppy a 1/2 turn counter clockwise and see how she does! (After that, use 1/8 turns to fine tune) Running it that lean can and will run it too hot, and eventually damage it.. (Not to mention it hurts performance) Keep tuning the HS needle until it runs good and puts out a nice stream of smoke at full throttle! Once ya have that set, make sure your low speed needle (one that's where the throttle linkage connects to) is set so ya JUMP off the line good! There's alot of ways to tune, but for the low speed, I use the "pinch" method.. Ya pinch the fuel line that enters the carb, and wait for it too cut off.. It should rev a little and cut off in a second or two.. If it takes too long to die, and revs "excessively" it's a little too rich. If it doesnt rev up before dieing, it's too lean.. Remember, to adjust: clockwise = leaner ; counter clockwise = richer.. Also, there are lots of videos on "youtube" that'll help ya tune these things!! Alishanmo is one of the best, imo, and has a bunch of cool vids you can check out about Redcat Racing RC's!! The one I linked to (click his name) is a good one!!
Mick Nesevitch
Hide Signatures
       Post #: 3480
RE: Redcat Racing Tornado Thread - 10/2/2009 10:47 PM
robster94gt
Score: 100
Status: offline
Thanks for tuning tips. hopefully I didn't hurt it running wide open on the bench to check for stalling.
I guess at this point I need to figure out what replacement parts i need. I checked with my parts place and they have the spurs and steel bell. I read early on in this thread that a different clutch spring is recommended. When i idled mine you could here matallic dinning noise. Is a different spring still recommended with the steel bell, or is the stock one ok. I'll take my clutch bell out and see what it looks like inside.
Hide Signatures
(in reply to Mickstix)
       Post #: 3481
RE: Redcat Racing Tornado Thread - 10/3/2009 4:21 AM
chevyderek72
Score: 100
Status: offline
The springs breaking and the aluminum bells were on the older models, so if its newer it should be a good spring and a steel bell. Get something magnetic and see if the the magnet is attracted to the clutch bell. The dinging noise is metal clutch shoes. You might need to turn your idle down a bit so the clutch shoes arent trying to engage at idle.
Check and see how many teeth that spur is that you stripped. Ive got a 47 tooth here that i dont need cause i dont have a 2 speed car anymore. And there is a one way bearing in it, if its just the small bearing it wont work, but if it has the white bigger hex piece around it it will work.
Its me ti**ta
Hide Signatures
       Post #: 3482
RE: Redcat Racing Tornado Thread - 10/3/2009 6:12 AM
Mickstix
Score: 105
Status: offline
Also, a couple spare dogbones are good to have on hand!! I lost one my first run after breakin, and when doing research afterward, found out that them falling out is pretty common unless you get the 87mm ones or put o-rings into the drive cups before the dogbones.. (Im talking about the bones/link from the diff out to each wheel) I got some 84mm (stock) and also some 87mm, incase the stock ones fall out again.. But I added an o-ring and they seem to be alot more secure now.. I also painted them flo orange before reinstalling them ..
Mick Nesevitch
Hide Signatures
       Post #: 3483
RE: Redcat Racing Tornado Thread - 10/3/2009 5:39 PM
LosParaZitos
Score: 100
Last Login: 10/30/2009
Status: offline
yep dog bones on tornado are really easy to loose i got mine it was missing a o- ring in one off them cup i just stuck a 3 mm piece or rubber fuel line in the cup and solved the dog bone issue for now
Hide Signatures
       Post #: 3484
RE: Redcat Racing Tornado Thread - 10/11/2009 4:48 AM
robster94gt
Score: 100
Status: offline
Hey thanks for the spur gear offer. It's the one I need. I'm just afraid that if I only replaced the spur, I'd end up with it being stripped pretty soon. I'm thinking of ordering the steel bell, as it seems that that should end the stripping problems.
Rob
Hide Signatures
(in reply to LosParaZitos)
       Post #: 3485
RE: Redcat Racing Tornado Thread - 10/12/2009 2:48 AM
chevyderek72
Score: 100
Status: offline
Well if you order the clutch bell just get a spur too, but if not and you wanna try a new gear let me know, pay postage and ill let you have it. It might have just been meshed wrong, cause if its mesh is off it sill eat gears.
Its me ti**ta
Hide Signatures
       Post #: 3486
RE: Redcat Racing Tornado Thread - 10/28/2009 6:44 PM
robster94gt
Score: 100
Status: offline
Hi chevyderek72,
I think I'll take you up on the offer for the spur gear. I ordered one along with the clutch bell, but when I went to install it, I found out it's a different part. In the picture my original is the stripped one with the bearing still in place. The part they sent me looks like it takes a much bigger bearing, as the hex hole is much larger. I contacted the place I ordered it from, but it looks like they don't want to help by just shipping me the bearing. They charge my about 15 bucks shipping for each order.
Thanks again,
Rob
Hide Signatures
       Post #: 3487
RE: Redcat Racing Tornado Thread - 10/29/2009 5:03 AM
chevyderek72
Score: 100
Status: offline
Ok, redcat used to have a small bearing in the first gear (big one), looked almost round, then then put that inside a bigger metal hex. The one i have is the bigger one, i possibly might have the old smaller one way bearing one, but i just noticed you live in canada, how much is shipping from the us to canada? There are a few dealers in canada, and it might be cheaper to do that possibly.
Edit- I have an extra 2 speed tranny and an extra first gear spur. Both have the bigger one way, do you know how much shipping is to canada? If not ill give the post office a call tomorrow and see how much it is to ship, and if you wanna pay it ill send both gears out, so you'll have 3 spurs and one i send will have the hex piece/bearing you need.
Its me ti**ta
Hide Signatures
       Post #: 3488
RE: Redcat Racing Tornado Thread - 10/29/2009 5:26 AM
robster94gt
Score: 100
Status: offline
Hey that's great - Thanks for your help
As far as shipping goes, I know that if you just send it surface, non insured etc... the rates aren't too bad. The cheapest rate would be fine, as I'm not in a hurry to get it - I'm leaving on vacation on Fri. My Postal code is K1R 5N3.
Thanks again,
Rob
Hide Signatures
       Post #: 3489
RE: Redcat Racing Tornado Thread - 10/29/2009 8:43 AM
chevyderek72
Score: 100
Status: offline
Your postal code, is that like the us's zip code? Do i just call or go to the post office and ask how much it would cost to send something to canada, postal code K1R 5N3?
Its me ti**ta
Hide Signatures
       Post #: 3490
RE: Redcat Racing Tornado Thread - 10/30/2009 3:59 AM
robster94gt
Score: 100
Status: offline
Hi,
I sent you a pm with my address, it should be enough info to get a quote,
Thanks again
Hide Signatures
       Post #: 3491
RE: Redcat Racing Tornado Thread - 11/13/2009 8:07 AM
Mickstix
Score: 105
Status: offline
Just a "bump" to keep this thread on the 1st page..
NOTE: Sorry, I keep forgetting about the "Support" threads that are sticky'd.. DOH!!
Mick Nesevitch
Hide Signatures
       Post #: 3492
RE: Redcat Racing Tornado Thread - 11/13/2009 10:54 AM
chevyderek72
Score: 100
Status: offline
Its me ti**ta
Hide Signatures
       Post #: 3493
RE: Redcat Racing Tornado Thread - 2/15/2010 12:41 AM
tylerjackson
Score: 100
Last Login: 12/22/2011
Status: offline
Ok its been awhile since anybody has posted here so i suppose i will go ahead and do it. My first model grade RC was a redcat racing shockwave that was severaly abused even before i got ahold of it. Since any of my previous RC's were simply wal-mart quality i was amazed by the tunablity, speed, durabilty even though these were like the very first ones out of redcat. Now that ALOT of problems have been fixed and updated i think i might go ahead and pick up a tornado s30 for my local track since its a kind of small and would fit nicely. I have had experiance with the sh. 18 and do know for my track it will provide enough power but i am wondering however if maybe something like a traxxas pro .15 will be a slightly better choice after the sh starts going down hill. I have had a pro .15 in a t-maxx and it moved it quite well so i believe that all should go right (the 3.3 would put to much stress on the drivetrain and i just dont want to bother with it in a redcat). What do you guys think? I have found a tornado s30 for $150 a pop at xenonproject.com.
Hide Signatures
       Post #: 3494
RE: Redcat Racing Tornado Thread - 2/15/2010 2:11 AM
neyou86
Score: 105
Last Login: 1/4/2012
Status: offline
ive heard the pro 15 have poor tuning on them. its hard for them to hold it.
Hide Signatures
(in reply to tylerjackson)
       Post #: 3495
RE: Redcat Racing Tornado Thread - 2/15/2010 2:21 AM
tylerjackson
Score: 100
Status: offline
I have also heard that but never experianced it. Mine did just fine when i broke it in correctly ran it right and tuned it properly.
Hide Signatures
       Post #: 3496
RE: Redcat Racing Tornado Thread - 2/15/2010 9:37 AM
Mickstix
Score: 105
Status: offline
I dont know much about the motors, but if you get the Tornado S30 to "race", pickup a single speed tranny/clutchbell when you get the car. The 2 speeds are still not the best quality, and unless you have a monster straightaway, you wont get the benefits out of the 2 speed.. (Just my opinion.. I've also got a S30)
Mick Nesevitch
Hide Signatures
       Post #: 3497
RE: Redcat Racing Tornado Thread - 3/14/2010 1:23 AM
brovik
Score: 100
Last Login: 3/20/2010
Status: offline
Hello all! Can i use 11.1v 5000mAh 12C LiPo acc with "Tornado EPX PRO 1/10 Scale Brushless Buggy" ? Thanks!
Hide Signatures
       Post #: 3498
RE: Redcat Racing Tornado Thread - 4/12/2010 11:00 AM
faroutdude
Score: 100
Last Login: 6/26/2010
Status: offline
I have a tornado s30 and it shifts way late is it tuning or tranny adjustment???
Hide Signatures
(in reply to Chubbysdad)
       Post #: 3499
RE: Redcat Racing Tornado Thread - 4/12/2010 3:48 PM
neyou86
Score: 105
Status: offline
tranny adjustment. if i remember right loosen the screw.not too much though or it will fall out. for tuning make sure blue smoke is coming out of the exhaust.
Hide Signatures
(in reply to faroutdude)
       Post #: 3500
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.000RCU1
