RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  137 138 139 140 [141] 142 143 144 145 146   next >   >>
Login
RE: Redcat Racing Tornado Thread - 4/12/2010 6:06 PM
faroutdude
Score: 100
Last Login: 6/26/2010
Status: offline
right on thanks also my steering servo makes noise and seems weak is it just a cheap servo or what???
Tornado s30
Hide Signatures
(in reply to neyou86)
       Post #: 3501
RE: Redcat Racing Tornado Thread - 4/13/2010 1:19 AM
neyou86
Score: 105
Last Login: 1/4/2012
Status: offline
could be. it should always make a noise. you should hear the electric motor.
Hide Signatures
(in reply to faroutdude)
       Post #: 3502
RE: Redcat Racing Tornado Thread - 4/13/2010 6:56 AM
Mickstix
Score: 105
Last Login: 11/6/2010
Status: offline
Yea, there not the best quality to begin with, but even good ones will "whine" sometimes.. Make sure you always have fresh batteries in the reciever box. (a 6v rechargeable hump pack is better than the (4) AA's)
_____________________________
Mick Nesevitch
Hide Signatures
       Post #: 3503
RE: Redcat Racing Tornado Thread - 4/15/2010 11:41 PM
afkellner
Score: 100
Last Login: 5/6/2010
Status: offline
Can you please post a link to a battery hump pack that would be compatible, and how hard is it to wire it? Thanks.
Hide Signatures
(in reply to Mickstix)
       Post #: 3504
RE: Redcat Racing Tornado Thread - 4/16/2010 6:53 AM
Mickstix
Score: 105
Status: offline
Sure, here's the one I run in both my Tornado S30 and Monsoon XTR! 6v Hump pack reciever batt There's no wiring to do, the hump pack has the same plug on it as the "AA" battery holder has, so ya just remove the AA holder and plug in the hump pack!! URCHobby also sells the  "adapter" so you can charge the hump pack off a standard charger..
PS: The battery says out of stock, so call or email Kurt.. He might have one in stock and just not be showing it on the website! Kurt: 516-499-7419 support@urchobby.com
Mick Nesevitch
Hide Signatures
(in reply to afkellner)
       Post #: 3505
RE: Redcat Racing Tornado Thread - 4/16/2010 6:45 PM
afkellner
Score: 100
Status: offline
Thank you very much for that info, but I have no chargers around, what do you consider a "Standard" charger?
Hide Signatures
       Post #: 3506
RE: Redcat Racing Tornado Thread - 4/17/2010 6:52 AM  1 votes
Mickstix
Score: 105
Status: offline
Any of em' really.. Even the most basic chargers should have a "Tamiya" style plug, (or come with an adapter) and the adapter I linked to above lets ya use it (or any charger) with the Humppack battery (cause the hump pack has a BEC style connector).. If you get the battery from Kurt, ask him what he recommends to charge the battery.. He has a wall charger on his site for like 5$ that I think should work fine, if all ya need to charge is the hump pack? But ask him about it, he'll steer ya in the right direction!
Mick Nesevitch
Hide Signatures
       Post #: 3507
RE: Redcat Racing Tornado Thread - 4/21/2010 10:11 PM
afkellner
Score: 100
Status: offline
quote:
ORIGINAL: Mickstix
Thank you, just ordered everything from Kurt.
Another question, I keep reading about the "o ring" or the 2mm fuel line fix to keep the dogbones falling out, but I really don't see where to put the o-ring or fuel line, I've searched all over for a picture of this fix but couldn't find it, does anyone know of a pic?
Thanks!
Hide Signatures
       Post #: 3508
RE: Redcat Racing Tornado Thread - 4/22/2010 1:17 AM
neyou86
Score: 105
Status: offline
what you do is take out your dogbone and then put the o ring or fuel tubing piece into the two cups then reinstall the dogbone
Hide Signatures
       Post #: 3509
RE: Redcat Racing Tornado Thread - 5/3/2010 6:51 PM
afkellner
Score: 100
Status: offline
HELP!!
My Tornado s30 is stuck in first gear, have about 1/2 gallon run through it.
What do I do?
Hide Signatures
(in reply to ehroof)
       Post #: 3510
RE: Redcat Racing Tornado Thread - 5/4/2010 1:18 AM
neyou86
Score: 105
Status: offline
check your 2 speed tranny. try adjusting your shift clutch. (whatever you wanna call it). let me know how adjust goes. you screw may have fallen out and its in second gear.
Hide Signatures
       Post #: 3511
RE: Redcat Racing Tornado Thread - 5/20/2010 4:47 AM
Timsjs550
Score: 100
Last Login: 7/7/2010
Status: offline
Hey hows it goin.  Where can I get the parts to make my s 30 a single speed.  I like the 2 speed but your right you are realy MOVIN by the time she even shifts I would like to have the option of a single speed.
Hide Signatures
       Post #: 3512
RE: Redcat Racing Tornado Thread - 5/20/2010 4:49 AM
Timsjs550
Score: 100
Status: offline
Are plastic.  Or metal clutch shoes better.  Im thinking the metal ones will grab more aggressivly
Hide Signatures
(in reply to chevyderek72)
       Post #: 3513
RE: Redcat Racing Tornado Thread - 5/20/2010 5:15 AM
neyou86
Score: 105
Status: offline
well the metal will out last the plastic. im sure it will grab better too. i dont really know. all ive used is metal. try urchobby.com or rufaster.com. they got good prices and fast shipping.
Hide Signatures
(in reply to Timsjs550)
       Post #: 3514
RE: Redcat Racing Tornado Thread - 6/2/2010 2:38 AM
Jimmyt707
Score: 100
Last Login: 9/26/2011
Status: offline
Newbe here.   I have a Redcat Tornado S30.
What is the exact dimensions on Redcat Rims?   Heighth, width, offset.
What size tires fit these rims?   How is size measured?
Hide Signatures
       Post #: 3515
RE: Redcat Racing Tornado Thread - 6/12/2010 7:15 AM
Mickstix
Score: 105
Status: offline
The short answer is, the rims and tires that fit the Associated B44 (4x4) will also fit the Tornado S30.. (The rears for a B4 will also fit the rear, but ya need fronts for a B44) If you do a google search for Associated B44 rims and tires you should come up with pleny of options.. Sorry I dont know the exact diminsions of the wheels and tires though. Although they do use a 12mm hex on the rims.. Cheers!
Mick Nesevitch
Hide Signatures
(in reply to Jimmyt707)
       Post #: 3516
RE: Redcat Racing Tornado Thread - 6/25/2010 12:34 AM
brandonzz
Score: 100
Status: offline
Tornado BB : Car Not responding to acceleration:
Please help, car is not responding to acceleration when I pull trigger, the steering responds to reveiver as normal, but the throttle doesnt respond when pulling the receiver trigger. Please help me with any advice or parts I may need to order to repair it.
Brandon
Hide Signatures
(in reply to Chubbysdad)
       Post #: 3517
RE: Redcat Racing Tornado Thread - 6/25/2010 2:16 AM
neyou86
Score: 105
Status: offline
could be any where from a unplugged servo, bad servo, loose link. no link. turn on the controller and reciever box. then pull your throttle. what does it do?
Hide Signatures
(in reply to brandonzz)
       Post #: 3518
RE: Redcat Racing Tornado Thread - 7/5/2010 8:41 PM
stuber
Score: 100
Status: offline
Hello Forum,
I have a Tornado that I just cannot keep running! It will not idle low enough that the wheels do not turn and it very difficult to keep running at low speeds. I need help and guidance.
Ed
Hide Signatures
(in reply to TORNADO BB)
       Post #: 3519
RE: Redcat Racing Tornado Thread - 7/5/2010 10:37 PM
neyou86
Score: 105
Status: offline
is it broken in? how much fuel has been through it? is your filter clean? how do your fuel lines look? take off your clutch bell and have a look. it could be your spring broke or there is something hanging up.
Hide Signatures
(in reply to stuber)
       Post #: 3520
RE: Redcat Racing Tornado Thread - 7/22/2010 2:06 AM
whauburger
Score: 100
Last Login: 7/22/2010
Status: offline
I have a Tornado BB, It runs fine is broken in and everything but as soon as it shifts into 2nd gear it dies. I have adjusted the screw to make it shift sooner, later all in between. No matter where it just dies when it hits 2nd. It hasn't always done this used to shift fine and drive great, just recently started. Any ideas?
Hide Signatures
       Post #: 3521
RE: Redcat Racing Tornado Thread - 7/23/2010 8:05 PM
Redcat-Derek
Score: 100
Last Login: 10/5/2012
Status: offline
whauburger,
Try going back to factory settings on your needles. 2.5-3 turns out on the high and low speed needle and then tune from there. It really shouldnt be dieing because all its doing is dropping the engines rpm and going back up. So it might be a tuning issue.
Derek
RedcatRacing
Hide Signatures
(in reply to whauburger)
       Post #: 3522
RE: Redcat Racing Tornado Thread - 7/30/2010 5:48 AM
robster94gt
Score: 100
Last Login: 11/24/2010
Status: offline
Hey all,
Well, I finally got my Tornado out and running. I'm pretty pleased with the engine. In the past I've had trouble keeping my trx .15 engine running, but this one ran really well without cutting out dying. Except when it was on it's back. Which happened quite a lot at the track I was running it on today. The car acted pretty much like it does in some of the videos I've seen of it. Bouncing around like crazy on a rough surface makes tougher to control than it should be. Going to fast and hit a rough spot - flip on it's back. Take off from a jump, rear compresses, kicks the rear up- on it's back. Any advice on how to adjust the stock setup to handle the bumps better? What sort of oil is in the shocks from the factory? It seems pretty light to me, and doesn't seem to offer much damping. Anybody had any success in getting these things to handle better?
Rob
Hide Signatures
(in reply to Redcat-Derek)
       Post #: 3523
RE: Redcat Racing Tornado Thread - 7/30/2010 6:05 AM
neyou86
Score: 105
Status: offline
try 45 wt oil. then set up the shock so when you drop it and lift it up the shocks will extend a bit more. just try soft spring settings
Hide Signatures
(in reply to robster94gt)
       Post #: 3524
RE: Redcat Racing Tornado Thread - 9/14/2010 4:36 AM
CUHRYTDUH
Score: 105
Last Login: 5/14/2013
Status: offline
I have a tornado bb. I was driving and it stops responding. car will run and rev up but not go any where. sounds like something is still spinning when u cut engine off. does anyone know what this is? thx for reading.
Revo Picco .26max, HPI Savage x, EPX drift, Slash 4x4
Hide Signatures
(in reply to glk420247)
       Post #: 3525
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
