Redcat Racing Tornado Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Redcat Racing Tornado Thread
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Redcat Racing Tornado Thread - 1/29/2007 10:40:20 PM
Chubbysdad
Status: offline
This is a folder for all posts that have to do with the Tornado. Please only post questions, problems, or add on's that relate to the Tornado's.
_____________________________
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16, Redcat Earthquake
       Post #: 1
RE: Redcat Racing Tornado Thread - 1/30/2007 1:48:24 AM
HimotoRacingUSA
Status: offline
Here are some pics of my tornado xp's:
1. upgrade your 2 speed clutch bell to: http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXCLR2&P=K + http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXDHM0&P=K + http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXCLR9&P=K
you may need to widdle away a little of the upper plate post so the gears clear it
2. if you want more low end touque use this clutch bell: http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXM730&P=K you will loose top end speed with this but have much low end take off
3. upgrade your single speed clutch bell to: http://www.clermontmotorsports.com/servlet/Detail?no=200 or this place: http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLST9&P=7
4. upgrade to this clutch spring traxxas 4146x : http://www2.towerhobbies.com/cgi-bin/wti0095p?FVSEARCH=4146x&FVPROFIL=++&search3=Go
Click to see fullsize image.
Click for fullsize
Click for fullsize
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM
***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
(in reply to Chubbysdad)
       Post #: 2
RE: Redcat Racing Tornado Thread - 1/30/2007 2:58:16 AM
slide150
Status: offline
will these work http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCFR3&P=M
instead of these or are these better
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXVK12&P=7
Better Smokin than Broken ......tornado equivelent
(in reply to HimotoRacingUSA)
       Post #: 3
RE: Redcat Racing Tornado Thread - 1/30/2007 3:08:21 AM
HimotoRacingUSA
Status: offline
they are both the same, just you get 2 sets of springs with the 886, firm and regular, this is for different stall rates (higher rpm engagement of the clutches)
(in reply to slide150)
       Post #: 4
RE: Redcat Racing Tornado Thread - 1/30/2007 3:17:55 AM
arlo1
Status: offline
I just ordered a tornado bb 2 speed what about the tranny on them what are some good mods and the a arm's Any one fine one tougher?
Tornado bb.
       Post #: 5
RE: Redcat Racing Tornado Thread - 1/30/2007 3:41:00 AM
nitrospeed33
Status: offline
you always wanna change the clutch spring to the traxxas one. and the clutch bell needs to be changed to the hpi one. if you dont change them, your gears will strip. change them before you run your car for the first time, it will save you alot of trouble. the links are up above. hope this helps you.
(in reply to arlo1)
       Post #: 6
RE: Redcat Racing Tornado Thread - 1/30/2007 3:46:36 AM
aviator2007
Status: offline
So ehroof, you tried the lower gearing clutchbell, and it worked. Sound like good news or me.
(in reply to nitrospeed33)
       Post #: 7
RE: Redcat Racing Tornado Thread - 1/30/2007 12:32:34 PM
HimotoRacingUSA
Status: offline
its much lower gearing than the 3 part clutch bell but theres not near as much top end.
(in reply to aviator2007)
       Post #: 8
RE: Redcat Racing Tornado Thread - 1/30/2007 4:07:14 PM
aviator2007
Status: offline
ehroof, I saw that it went from like 17t to 13t. My question is, should I keep my 2.8 in tires or go down to a smaller 2.2 in with the shorter gearing???
       Post #: 9
RE: Redcat Racing Tornado Thread - 1/30/2007 7:04:28 PM
HimotoRacingUSA
Status: offline
i would get both, the 17/22 is good for top end (and the smaller tires), the 13/18 is good for low end torque and the bigger tires. i put 2.2 rims with smaller tires back on as you can see in the pictures above (green one).
       Post #: 10
RE: Redcat Racing Tornado Thread - 1/30/2007 7:40:27 PM
seedless
Status: offline
I bought an aluminum upper plate for the tornado bb but I cannot figure out where the battery holder and battery pack go. Also there is a bar that came with the kit that i cannot figure out where to place it.
       Post #: 11
RE: Redcat Racing Tornado Thread - 1/30/2007 10:15:22 PM
dclintonh
Status: offline
my little vx.18 is shot.
i have hardly any resestance on the pull starter.
what can i do, is there a rebuild kit or somthing?
(in reply to seedless)
       Post #: 12
RE: Redcat Racing Tornado Thread - 1/30/2007 11:07:16 PM
HimotoRacingUSA
Status: offline
make sure your head bolts are tight and the glow plug is tight too. you can get a piston and sleeve from someone, i think top speed toys used to sell the engine parts for it, you can check his site, if not do a google of infinity .18 engine parts or piston and sleeve
(in reply to dclintonh)
       Post #: 13
