RE: Redcat Racing Tornado Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  103 104 [105] 106 107 108 109 110 111 112   next >   >>
Login
RE: Redcat Racing Tornado Thread - 4/4/2008 11:21:59 PM
Hibityhupla!
Status: offline
Well I hit another problem with the 20t gear. I have ordered almost every one I have seen for sale and still haven't found one that will work. The one for the 4tec is so close it's aggravating. It's almost like the hole is right but thread is different. So for now the best we can do on a bell is the losi lst 2speed threaded bell with the rs4 19t gear and R40 24t gear. I'm not going to quit trying but it's the best I have so far.
(in reply to HimotoRacingUSA)
       Post #: 2601
RE: Redcat Racing Tornado Thread - 4/4/2008 11:47:07 PM
Hibityhupla!
Status: offline
Here's a question----Do they make a thread chaser that's the same size as the 12mm clutch bell? If so, I bet I could just run that through the 4tec gear to make it work..
(in reply to Hibityhupla!)
       Post #: 2602
RE: Redcat Racing Tornado Thread - 4/6/2008 12:07:28 AM
Hibityhupla!
Status: offline
The 4tec gear is a 12mm center but the threads are bigger. What would be easier? changing the bell threads or the threads inside the gear? I'm about ready to take a file to it and just jb weld it in place....lol
       Post #: 2603
RE: Redcat Racing Tornado Thread - 4/6/2008 12:24:50 PM
Nitro Ray
Status: offline
Hi Hibityhupla!
Thanks for the reply, you seem very knowledgable in the buggys.
I have 1 more question. I put my 2-speed in and the front center dogbone keeps getting jammed in the front part of the c-cup. please help.
       Post #: 2604
RE: Redcat Racing Tornado Thread - 4/6/2008 4:33:54 PM
numskull223
Status: offline
I had the same thing, i had to adjust the cup all the way back, make sure you still have the rubber O-ring inside your drive cups. Hope that helps, Jeff
(in reply to Nitro Ray)
       Post #: 2605
RE: Redcat Racing Tornado Thread - 4/6/2008 8:32:22 PM
Crazy420Nick
Status: offline
My tornado shuts off when I apply the brakes. The trhottle wire pulls back on the carburator which closes it and causes it to shut off. How can I fix this?
_____________________________
Crazy Nick
(in reply to Chubbysdad)
       Post #: 2606
RE: Redcat Racing Tornado Thread - 4/6/2008 9:35:07 PM
nubzorz
Status: offline
i was wondering what other tires and rims are compatible with tornado bb and where could i get some they are always sold out on recat website. and also i have to replace a dogbone in the front of my car how would i go about doing this does it just snap in or do i have to take somthing apart
       Post #: 2607
RE: Redcat Racing Tornado Thread - 4/7/2008 12:30:19 AM
Hibityhupla!
Status: offline
quote:
ORIGINAL: Crazy420Nick
You need to adjust the idle with the idle screw. If you just do it with the controller every time you hit the brakes it will die. Keep it open .5-1mm. It should stay that far open even holding the brakes.
(in reply to Crazy420Nick)
       Post #: 2608
RE: Redcat Racing Tornado Thread - 4/7/2008 12:34:21 AM
Hibityhupla!
Status: offline
quote:
ORIGINAL: nubzorz
Jato rear wheels and tires work good. You can get them off ebay all the time. Which front dogbone do you mean? Tranny to front differential or differential to wheel hub? The tranny one you'll have to take the engine and tranny out to do, the front diff-wheel dogbone you can remove the wheel and hub.
(in reply to nubzorz)
       Post #: 2609
RE: Redcat Racing Tornado Thread - 4/7/2008 12:41:31 AM
Hibityhupla!
Status: offline
quote:
ORIGINAL: Nitro Ray
Hi Hibityhupla!
Jammed? To tight of a fit? If so try what numskull223 said. If you still need more room take the drive cup of the tranny and file down the back side a little(the side the faces the transmission. You shouldn't need more then 1mm probably. If too loose you can move that drive cup out a little. Just make sure it's not too loose or it will find its way out constantly.
       Post #: 2610
RE: Redcat Racing Tornado Thread - 4/7/2008 3:47:41 AM
numskull223
Status: offline
hey all, my buddy has a nitro rustler, that thing comes out of the hole like a sling shot, is there a way to get a Tornado to run like that?
       Post #: 2611
RE: Redcat Racing Tornado Thread - 4/7/2008 7:54:39 AM
Hibityhupla!
Status: offline
quote:
ORIGINAL: numskull223
Yep...A big freaking engine....lol
(in reply to numskull223)
       Post #: 2612
RE: Redcat Racing Tornado Thread - 4/7/2008 12:30:30 PM
rclynx
Status: offline
2 wheel drive will almost always blow the doors of a 4x4 from the start. Thats why the ST is so much fun to race
Custom Cars bring out the stars / Home of the RCLYNX, RC IMPROVEMENT, MOD, SALES & SERVICE Dealer;XTM, CEN, HPI & much more
       Post #: 2613
RE: Redcat Racing Tornado Thread - 4/7/2008 2:48:59 PM
numskull223
Status: offline
Oh, i forgot, its a 2.5 rustler. I read that a traxxas 2.5 turns 50,000 RPM's, Is there any other motor that will fit a redcat that can turn anything close to that?
Is there performance clutches for Redcat cars?
< Message edited by numskull223 -- 4/7/2008 3:04:20 PM >
(in reply to rclynx)
       Post #: 2614
RE: Redcat Racing Tornado Thread - 4/7/2008 10:46:44 PM
Hibityhupla!
