RE: Redcat Racing Tornado Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  106 107 [108] 109 110 111 112 113 114 115   next >   >>
Login
RE: Redcat Racing Tornado Thread - 4/23/2008 5:26:49 AM
numskull223
Status: offline
quote:
ORIGINAL: Hibityhupla!
quote:
ORIGINAL: numskull223
gOTTA QUICK QUESTION, I bought some traxxas wheels, with the 12 mm hex. They fit but the back spacing is to deep on the fronts. I was wondering if they make some thing to extend the axles, i just need about 1 inch per side. Thanks jeff
cut and paste at ebay.. - 12MM HEX WHEEL EXTENSIONS FOR TRAXXAS STAMPEDE VXL
Thanks, I looked at them and I ended up making my own, with a lil beefer steel. Thanks
(in reply to Hibityhupla!)
       Post #: 2676
RE: Redcat Racing Tornado Thread - 4/23/2008 10:54:39 AM
Hibityhupla!
Status: offline
quote:
ORIGINAL: huejohnson
this problem is too common. on your trans. there are two set screws one locks the hub in place and the other is for shift points. if it's stuck in first gear turn the shift point set screw out 1/2 turn at a time and test it it can be a long and painfull process if it's in 2nd gear just do the opp. this is why most of us go with the single speed trany. hope this helps anyone eles have some info if i'm wrong wich i think i'm not
Right on the money but smaller adjustments... Probably 1/4 turn max at a time. It's real easy to go to far.
(in reply to huejohnson)
       Post #: 2677
RE: Redcat Racing Tornado Thread - 4/23/2008 11:18:54 PM
dak70
Status: offline
I'm a newbie to RC Nitro cars and I have a problem. When I run my Shockwave in the grass I loose all power to the wheels. The buggy seems to get more and more slugish until I can go full throttle and it just sits there. The engine revs, but no power at the wheels. I will stop running it for some time and the problem goes away. Any Ideas on what is wrong?
-DAK
(in reply to HimotoRacingUSA)
       Post #: 2678
RE: Redcat Racing Tornado Thread - 4/24/2008 12:24:16 AM
Hibityhupla!
Status: offline
quote:
ORIGINAL: dak70
-DAK
That's a tough one without really seeing it. You'll have to chase the problem to find it. Start at the bell and tranny. Both spinning? then from the tranny to the diffs. the drive cups that hold the shafts come loose fairly frequently. If your good there check from the diffs to wheels. If the shaft from the tranny to the diff is spinning but not from diff to wheel could be a bad diff. If they are all spinning but tries wont move check the 12mm hex for the wheels. Still have the pins behind them? Stripped? Like I said without seeing it it's kinda a tough one. Hope this helps......
(in reply to dak70)
       Post #: 2679
RE: Redcat Racing Tornado Thread - 4/24/2008 5:34:49 AM
Cam_132
Status: online
quote:
ORIGINAL: dak70
-DAK
Hi Dak
that could be a buntch of things... Spurgear, Diffs, Differential pinion gear, Drive cup (had the grub screw come loose and the cup would just spin) or a broken shaft... so check all of thows things and report back with photos if you can...
-Cam-
p.s. the Diff pinion gear would be located behind the diff. when you pull the diff out the gear will be right behind it, it will be held in by a "E" Clip and the way to get them off is take a pare on Needle nose plyers and squeze it shut and put it in the open part and open the plyers and it should come right off, may take some time and "E" clips are notorious for springing in to the un-known... so try not to loose any... if you do take one off some ware elts, they are all the same size except the clutch it uses a big one...
< Message edited by retard1322 -- 4/24/2008 5:40:02 AM >
_____________________________
Sponcer: Vancouver hobbies,Email westcoasthobbies@shaw.ca
Best of luck to you in your future endeavors - Dr.kliner HL2
(in reply to dak70)
       Post #: 2680
RE: Redcat Racing Tornado Thread - 4/24/2008 11:42:55 PM
will0983
Status: offline
need to know what size dogbones for the front? thanks
(in reply to Chubbysdad)
       Post #: 2681
RE: Redcat Racing Tornado Thread - 4/25/2008 1:19:42 AM
dak70
Status: offline
Thanks man! I'll check it out. I was kinda thinking it is something with the clutch/tranny.
-DAK
       Post #: 2682
RE: Redcat Racing Tornado Thread - 4/28/2008 12:17:37 AM
huejohnson
Status: offline
I've been into rc cars for a long time, now my son is into them. So for his first car i bought him a shockwave. I've upgraded the shocks,clutch,clutch springs, a few other small things, and of course the motor to O.S .18. But with this car something keeps happening that I've never seen before, the bog bones keep snapping in half. At first I thought it was something that he was doing. So I fixed it then I took it for a drive, I drove it around for a while with no problems untill i put it on the track. I was sitting on the front stretch and put the hammer down the car moved about 10 feet. this time 2 bones broke. I've looked through all my books and all my notes and can't find anything even similar, and nobody I,ve talked to has anythig stronger. So what I'm asking is has anyone eles had this problem or know of where I can find stronger dogbones. Thanks for the input
(in reply to dak70)
       Post #: 2683
RE: Redcat Racing Tornado Thread - 4/28/2008 1:28:14 AM
gokartingbob455
Status: offline
once agian i must say redcat needs to manufacture and sell diamond parts. those dog bones wouldn't break if they were made of diamonds!
ummmmm.................he did it.
       Post #: 2684
RE: Redcat Racing Tornado Thread - 4/28/2008 2:00:39 AM
rclynx
Status: offline
Try lowering your LCG and bend the tabs so the arms can't come down so far................that might help a little
Custom Cars bring out the stars / Home of the RCLYNX, RC IMPROVEMENT, MOD, SALES & SERVICE Dealer;XTM, CEN, HPI & much more
(in reply to gokartingbob455)
       Post #: 2685
RE: Redcat Racing Tornado Thread - 4/28/2008 2:17:26 AM
Hibityhupla!
Status: offline
i've had that happen too. It will either happen when a rock gets stuck somewhere it shouldn't while moving or they will bind if you have it set to high with stiff suspension. It sounds like you getting it moving and it gets stuck with all that force and "snap".
(in reply to rclynx)
       Post #: 2686
RE: Redcat Racing Tornado Thread - 4/28/2008 2:33:19 AM
gokartingbob455
Status: offline
rocks get in my wheels all the time and my dog bones never break...i guess im lucky.
       Post #: 2687
RE: Redcat Racing Tornado Thread - 4/28/2008 2:48:47 AM
huejohnson
Status: offline
the suspension is set very soft with 40wt. oil and as for stones there is none my back yard is all clay and my track gets groomed before every use. the only thing I can figure is torque and tons of it.
       Post #: 2688
