RE: Redcat Racing Tornado Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: Redcat Racing Tornado Thread - 3/26/2007 2:40:37 AM
daveschutt
Status: offline
I THOUGHT I WAS LOOSING MY MIND!!! AT LEAST SOMEONE ELSE SEEMS TO BE HAVING THE SAME PROBLEM WITH THE DIFFERENT SIZE BEARING CUT OUT ON THIER 47 TOOTH SPUR GEARS. ANY ONE KNOW WHERE I CAN GET THE GEARS WITH THE SMALLER CUTOUT? IF NOT DOES REDCAT HAVE A PART # FOR THE NEW BEARING. THANKS
_____________________________
Woah-what was that? i think it was a racoon-nope just another wimpy t max under my MGT!
(in reply to LorDDarknesS)
       Post #: 251
RE: Redcat Racing Tornado Thread - 3/26/2007 2:54:27 AM
HimotoRacingUSA
Status: offline
call redcat or go to their live support and find out about the bearing.
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM
***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
(in reply to daveschutt)
       Post #: 252
RE: Redcat Racing Tornado Thread - 3/26/2007 6:38:09 AM
groovetrippin
Status: offline
Whats up everyone,
Need some help.... Have a brand new out of the box Tornado BB and was following all the steps to break in the engine. Tested all the electronics with fresh batteries and the tested the engine.. Both worked like a champ. All of a sudden the controls just stopped working... Checked all the connections and made sure they were tight... Changed out the batt's for new ones and nothing... Let the car sit for about an hour and everything works again... Then 5 min's later the electronics just quit... This has happened now about 3 times. Any clue what's up? I am new so please break your answers down into plain english... Just kidding But please do.
-ash
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Tornado BB, IRC Vulcan
       Post #: 253
RE: Redcat Racing Tornado Thread - 3/26/2007 8:07:14 PM
LorDDarknesS
Status: offline
ok i got it running without the power loss but while i was working on it i was putting pressure on the rubber boot that surrounds the low end needle and noticed air bubbles forming in the barrel of the carb. does this mean my carb is bad?
mate, eat, bash nitro, repeat
(in reply to groovetrippin)
       Post #: 254
RE: Redcat Racing Tornado Thread - 3/26/2007 8:12:12 PM
HimotoRacingUSA
Status: offline
quote:
ORIGINAL: groovetrippin
Whats up everyone,
-ash
sounds like you got a bad radios setup, call redcat and as long as its within 30 days they should give you a new one. actually you should upgrade it, for less than $50 you can get a decent futaba setup.
       Post #: 255
RE: Redcat Racing Tornado Thread - 3/26/2007 8:13:26 PM
HimotoRacingUSA
Status: offline
quote:
ORIGINAL: LorDDarknesS
what is the problem you are having? If its running good and not overheating, i wouldnt worry about it.
       Post #: 256
RE: Redcat Racing Tornado Thread - 3/26/2007 8:38:36 PM
LorDDarknesS
Status: offline
but it still stalls at low speed about 50% of time and then wont start the tuning range is good and it doesnt always happen but as long as i give it gas it runs like a raped ape with proper smoke and good heat
< Message edited by LorDDarknesS -- 3/26/2007 8:40:35 PM >
(in reply to HimotoRacingUSA)
       Post #: 257
RE: Redcat Racing Tornado Thread - 3/26/2007 8:43:38 PM
HimotoRacingUSA
Status: offline
either its the glow plug or the low end needle is set too rich.
       Post #: 258
RE: Redcat Racing Tornado Thread - 3/26/2007 8:58:48 PM
LorDDarknesS
Status: offline
brand new glow plug and i have been working through the entire spectrum of low end....but i'll keep trying also is there any literature out there for headers on a .18 (more power needed lol)
       Post #: 259
RE: Redcat Racing Tornado Thread - 3/26/2007 9:16:09 PM
kcrd2
Status: offline
quote:
ORIGINAL: ehroof
here you go, with a little patience you can do it or he can, if there is a problem, just come here and we will help.
1. upgrade your 2 speed clutch bell to: http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXCLR2&P=K + http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXDHM0&P=K + http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001135084&I=LXCLR9&P=K
you may need to widdle away a little of the upper plate post so the gears clear it
2.upgrade to this clutch spring traxxas 4146x : http://www2.towerhobbies.com/cgi-bin/wti0095p?FVSEARCH=4146x&FVPROFIL=++&search3=Go
Replaced these parts on the Tornado XP. Can you tell me what differences replacing these individual parts was supposed to make?? Just want to make sure that we are getting the right response with the replacements. Thanks.
       Post #: 260
RE: Redcat Racing Tornado Thread - 3/26/2007 11:36:27 PM
HimotoRacingUSA
Status: offline
quote:
ORIGINAL: kcrd2
quote:
ORIGINAL: ehroof
it will stop the spur gear from stripping in the first few tanks of fuel also the spring will last alot longer than the stock one, you may see some more top end since there is a tooth more on the new clutch bell you put in.
(in reply to kcrd2)
       Post #: 261
RE: Redcat Racing Tornado Thread - 3/26/2007 11:39:02 PM
HimotoRacingUSA
Status: offline
this header will fit nicely: http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBTB5&P=ML
try retuning the whole engine, start with 3 out on the high end and flush with the collar on the low end. Maybe you have something clogging the low end needle? take it out and try to clean it out inside, be careful with it.
