RE: Redcat Racing Tornado Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  113 114 [115] 116 117 118 119 120 121 122   next >   >>
Login
RE: Redcat Racing Tornado Thread - 6/12/2008 8:29:04 AM
Swamp3r
Status: online
Turn your idle screw out while the truck is running and on a block of wood or something so the wheels are not touching. Do it in like small turns till the wheels stop spinning but you still have a good idle. I would leave the radio(remote) alone and adjust the idle screw relying on the radio to control the servo puts extra stress on the servo so set the idle screw instead.you need around a 1 mm gap, just pop off the air filter and look in the carb. I would set your radio)remote to default and use the carb to set everything. If you need a small tweak and I do mean small then use the throttle trim on the radio. The tires should not spin at all if the truck is off the ground at idle. When you adjust the idle screw just tap the accelerator/ radio lightly then watch the wheels .Just curious I know your new you had the radio on while doing this right? So have the truck off the ground, set your radio back to default,adjust the idle screw out till the wheels stop spinning.But keep a good high idle, just set it till the wheels stop moving.. It will take alot more tweaking as the tuck gets broke in more, just so you know. Do not lower the idle too low or you may stall when you hit the breaks thats why I say set it till the wheels stop moving and still have a good idle. Hope this helps
Edit: I forgot to mention your not dumb we all had to start somewhere. Only dumb question is the one thats never asked. Welcome to the family man. I forgot to mention how to set your radio you should see 2 dials one will say st trim thats to set steering and the other is th trim thats the one I want you to set to default meaning straight up dead center. Just be sure to have the radio and receiver (remote on) while doing any tuning.
< Message edited by Swamp3r -- 6/12/2008 8:53:00 AM >
_____________________________
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
(in reply to bnick)
       Post #: 2851
RE: Redcat Racing Tornado Thread - 6/12/2008 10:56:06 AM
bnick
Status: offline
Thanks I had the radio and the car on. I was had the screws all set according to the factory settings so I think. The low end screw is the one I was tring to adjust when I tightened it the engine sped up and the wheels went real fast when I loosened it up I stalled the car. I will try to play with the idle screw the one under the air filter. Can I take off the air filter and star the car for adjustment and put it back on when I run the car. Oh I did look at the carb opening when I hit the throtle all the way the hole was open all the way and just a slight gap when in nuteral.
Oh on a side note I see these electric starter kits out there. Are they worth the money and do they make the car easier to start. All I wanted to do was get the car running yesterday and had zero luck. I found pulling it was hard I think I might of hydro locked it a couple of times as gas was spitting out of the exhaust. Not sure if the electric starters make life easier.
This forum is great by the way so many people helping me out.
< Message edited by bnick -- 6/12/2008 11:03:26 AM >
(in reply to Swamp3r)
       Post #: 2852
RE: Redcat Racing Tornado Thread - 6/13/2008 12:56:17 AM
Gelo_USA
Status: offline
the electric starter will only replace the cord so u dont have to keep pulling it but if ur car doesnt start with the pullstart it wont start with the electric.... it only makes it easyer because it removes the PULLING PART but ur car still have to be tuned properly...
(in reply to bnick)
       Post #: 2853
RE: Redcat Racing Tornado Thread - 6/13/2008 1:21:56 AM
AllAboutFunHobbies
Status: offline
if your engine is tuned properly and has been taken care of it will start first or second pull every time.
Dealer for...Redcat Racing, Traxxas, Team Associated, Cen, Racers Edge, RD Logic, Bodies by Blue, HPI, Himoto USA.....etc
(in reply to Gelo_USA)
       Post #: 2854
RE: Redcat Racing Tornado Thread - 6/13/2008 4:33:17 AM
bnick
Status: offline
Ok I got it started and I broke in the engine. Now my issue is when I getting it running when I put the break on full it still runs and the car does not move so I think I have that set up ok. When I give it gas and then let off it is still running like I am giving it gas untill I hit the break all the way to stop it. I do not know if this is normal. should it slow down once I let off the gas or do I allways have to use the break to slow it down.
(in reply to AllAboutFunHobbies)
       Post #: 2855
RE: Redcat Racing Tornado Thread - 6/13/2008 10:53:56 PM
Gelo_USA
Status: offline
no.. it should slow down... now its time to adjust the THROTHLE on the controller... watch the carburetor when u acelerate it opens when u release it closes when u brake it closes a little more(thts how urs is)... what u want to do is adjust it so when u release throtle the carb closes to a position where when u brake it doesnt move...
I hope I was clear enough... kind of hard to explain online....
< Message edited by Gelo_USA -- 6/14/2008 3:10:34 PM >
(in reply to bnick)
       Post #: 2856
RE: Redcat Racing Tornado Thread - 6/15/2008 2:07:40 AM
Gelo_USA
Status: offline
WOW... thts all I can say for 200$ on the tornado... I totally changed my mind about REDCATRACING.... because my volcano was a piece of **** when I got it... but I wasnt really surprised since its so cheap but when I got the tornado s30 I noticed it was better than the volcano... it came all aligned already meshed correctly and with thread lock on MOST of the screws tht needs it... the car is working perfect... took it out for break in today... I m a little confused with the low speed nedle since the other engine I learned on is only one needle but I think I got it set right.... how do u knw the low speed is set right??? the car accelerates really fast if I dnt control it spins out so much torque.. so I think the low speed needle is right.... let me knw how u guys do it.... and also the pull start is getting stuck on the throthle link... I ve seen people on utube with cars running away because of tht... how do u guys fix it?? I m scared about it... otherwise its a total different experience than the one I had with the volcano... its great... I ran like only 3 tanks after break in... the sh engine has WAY more than enough power for it and after its already going insanely fast it switches to 2nd gear and man I couldnt believe.... I need to talk to someone to be a dealer of redcat cars... only today I wouldve sold 3.... 2 people stopped their cars to ask about it...
       Post #: 2857
RE: Redcat Racing Tornado Thread - 6/15/2008 7:39:58 AM
bnick
Status: offline
I tuned it up today and it runs great except for it not slowing down when I let off the gas. I think my clutch is engaging to soon at low RPM how do I adjust this.
       Post #: 2858
RE: Redcat Racing Tornado Thread - 6/16/2008 5:54:30 PM
Encaged Rage 22
Status: offline
im interested in getting a nitro buggy ive been looking at the tornado s-30. Any reivews would be great.
(in reply to HimotoRacingUSA)
       Post #: 2859
RE: Redcat Racing Tornado Thread - 6/16/2008 8:42:01 PM
derekguzz
Status: offline
hey guys, I bought my girl a tonrado BB and I am eating threw spur gears. What exactly do I have to buy to prevent this? Member she has a 2 speed tranny. other than that this thing flys. Thanks alot
(in reply to frekbynature2002)
       Post #: 2860
RE: Redcat Racing Tornado Thread - 6/18/2008 12:36:02 AM
Hibityhupla!
Status: offline
quote:
ORIGINAL: derekguzz
i would recommend swapping to the single speed. I went though dozens of gears before i changed. Still on my first single speed gear. I did hear that himoto is working on a metal gear 2speed tranny. Not sure if or when it will be out though.
(in reply to derekguzz)
       Post #: 2861
RE: Redcat Racing Tornado Thread - 6/18/2008 1:58:49 AM
derekguzz
Status: offline
well if I want to keep the 2 speed set-up what clutch bell and new spur gears should I get
       Post #: 2862
RE: Redcat Racing Tornado Thread - 6/18/2008 3:26:08 PM
daveschutt
Status: offline
since the transmissions in these cars are crap, is it possible to mount the hot bodies 10 transmission in the car?
Woah-what was that? i think it was a racoon-nope just another wimpy t max under my MGT!
