RE: Redcat Racing Tornado Thread
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  131 132 133 134 [135] 136 137 138 139 140   next >   >>
Login
RE: Redcat Racing Tornado Thread - 4/6/2009 7:15 PM
419screaminrieman
Score: 100
Last Login: 5/11/2009
Status: offline
i have a tornado bb and i have been wanting for some time now to upgrade the engine. i was just wondering what engine would provide the most acceleration but would also be a direct fit? Also i was wondering if anyone knew of any good sites to buy hop up parts from. Thanks!
Hide Signatures
(in reply to FULLYGROWNKID)
       Post #: 3351
RE: Redcat Racing Tornado Thread - 4/7/2009 3:06 AM
chevyderek72
Score: 100
Last Login: 11/8/2009
Status: offline
The sh 18 engine is a good upgrade, really good engine. With the redcats engine replacement program you can get it for 45 bucks which is a awesome deal. The os cr-vs (i think thats the one) motor is even better, buty thats like 120 bucks or something. Get the sh, you will be happy with it
_____________________________
Redcat Racing - Hurricane, Volcano, Volcano epx
Its me ti**tae, had my name changed
Hide Signatures
(in reply to 419screaminrieman)
       Post #: 3352
RE: Redcat Racing Tornado Thread - 4/7/2009 4:16 AM
419screaminrieman
Score: 100
Status: offline
Is it really that much of an upgrade though?
Hide Signatures
       Post #: 3353
RE: Redcat Racing Tornado Thread - 4/7/2009 6:04 AM
chevyderek72
Score: 100
Status: offline
Oh ya, you would be suprised. Just because the engine is the same displacement, doesnt mean that it puts out the same power. I would deffinitely reccomend the sh 18
Hide Signatures
       Post #: 3354
RE: Redcat Racing Tornado Thread - 4/12/2009 1:50 AM
bpotter402
Score: 100
Last Login: 7/13/2009
Status: offline
hey guys, i got cameron at redcat to tell me how to tell the glow plugs apart. i now have a new problem, i have a hard time starting the engine, when it does start it wants to scream at sounds like full throttle, wont idle at all, not even close to where the idle needs to be. the tires are screaming fast. i have tried setting the needles back to original factory settings, i took off the carb and cleaned all the internal pieces(fully disassembled), i am running a medium glow plug and 20% nitro. fairly new to the nitro world. i am about to take the shotgun to the dam thing but i still have hope. please help.
Hide Signatures
(in reply to chevyderek72)
       Post #: 3355
RE: Redcat Racing Tornado Thread - 4/12/2009 2:14 AM
neyou86
Score: 100
Last Login: 11/7/2009
Status: offline
will it start on the ground? ur clutch spring might be shot. try rolling the car on the ground see if it is catching at all
Hide Signatures
(in reply to bpotter402)
       Post #: 3356
RE: Redcat Racing Tornado Thread - 4/12/2009 2:25 AM
bpotter402
Score: 100
Status: offline
just went and triedd rolling it on the ground. almost no resistance. rolls all the way across my basement floor with very minimal effort. no catching or binding anywhere.
Hide Signatures
(in reply to neyou86)
       Post #: 3357
RE: Redcat Racing Tornado Thread - 4/12/2009 2:36 AM
bpotter402
Score: 100
Status: offline
i cant try to start it on the ground right now, there are some kids sleeping in the house. i was messin with it earlier today and when it did start it ran for only a few seconds and when it was running it wanted ta run 1000 miles an hour. it did run for more than a couple seconds a couple of times but i had to keep it running with the throttle.
Hide Signatures
       Post #: 3358
RE: Redcat Racing Tornado Thread - 4/12/2009 3:01 AM
neyou86
Score: 100
Status: offline
when u had the engine running did it sound like the idle was set really high or were just the wheels spinning fast
Hide Signatures
       Post #: 3359
RE: Redcat Racing Tornado Thread - 4/12/2009 3:14 AM
bpotter402
Score: 100
Status: offline
it was running really fast (engine). tirea were screamin too but they should have been. i cant get the idle to come down and stabalize, it just dies. now i have set the gap in the carb to about 1mm, reset the carb to the factory settings and i removes disassembled and cleaned the carb. i have a medium glow plug with one tank of 20% fuel ran through it. my glow igniter is fully charged, i have blew through both fuel lines and they are clear. the only thing i can think of left is the clutch spring but it isn't showing any symptoms of that being the problem
Hide Signatures
       Post #: 3360
RE: Redcat Racing Tornado Thread - 4/12/2009 3:18 AM
neyou86
Score: 100
Status: offline
what did u set high speed needle at?
Hide Signatures
       Post #: 3361
RE: Redcat Racing Tornado Thread - 4/12/2009 3:30 AM
bpotter402
Score: 100
Status: offline
2 1/2 turns out on both. thats what it says to do oin the manual, thats what it was when i got it. only after i changed glow plugs and started messin with the needles did this happen, and the screw for the brake linkage fell out so is got another one. i have checked the throttle linkage to see if it is binding and have found nothing, thanks by the way for helping.
Hide Signatures
       Post #: 3362
RE: Redcat Racing Tornado Thread - 4/12/2009 3:34 AM
neyou86
Score: 100
Status: offline
the stock setting on mine was at 3 turns out on the hsn and flush with the lsn
if that helps u any
Hide Signatures
       Post #: 3363
RE: Redcat Racing Tornado Thread - 4/12/2009 3:37 AM
neyou86
Score: 100
Status: offline
check the idle gap with the controller and reciever on. ur throttle trim on ur controller might be sett high
Hide Signatures
       Post #: 3364
RE: Redcat Racing Tornado Thread - 4/12/2009 3:58 AM
bpotter402
Score: 100
Status: offline
ok i said to hell with the kids and their sleep, my tornado and my piece of mind is more important ha ha. i went and set the needles to where you said and it started and idled pretty well. it was loads better than it was. i also changed glow plugs back to a hot plug but that didn't make any difference. best i can figure is that with the 10% nitro fuel the factory settings and a hot plug is good enough for it to run but the performance sucks! i still havent got it to go into second gear. like i said i am running 20% nitro and a medium glow plug. the factory settings must not be close to what they need to be. i did check my transmitter trims and they are not screwed up. the throttle is not open too much. thanks for all your help. i am going to try it tomorrow after easter celebs.
Hide Signatures
       Post #: 3365
RE: Redcat Racing Tornado Thread - 4/12/2009 4:02 AM
neyou86
Score: 100
Status: offline
any time. good luck on tuning
Hide Signatures
       Post #: 3366
RE: Redcat Racing Tornado Thread - 4/12/2009 8:12 AM
chevyderek72
Score: 100
Status: offline
Use a hot plug with 20%, but if you go higher use a colder plug.
Hide Signatures
       Post #: 3367
RE: Redcat Racing Tornado Thread - 4/13/2009 10:33 PM
neyou86
Score: 100
Status: offline
how did it run? bpotter
Hide Signatures
       Post #: 3368
RE: Redcat Racing Tornado Thread - 4/14/2009 12:44 AM
bpotter402
Score: 100
Status: offline
it ran for a couple of minutes, it was richer than hell. spitting out raw fuel. i was switching glow plugs and foung that they are junk. i ordered more last night. they will be here in a couple of days. it was actuelly idling for a little bit but it didn't last long. ill post again when i get the plugs
Hide Signatures
       Post #: 3369
RE: Redcat Racing Tornado Thread - 4/17/2009 2:27 PM
t@n
Score: 100
Last Login: 8/24/2009
Status: offline
hello there, i 'm from indonesia and can't speak english very well.. how can i improve the acceleration on redcar tornado? because i feel the engine have a poor acceleration.. please help..
thanks
Hide Signatures
       Post #: 3370
RE: Redcat Racing Tornado Thread - 4/17/2009 2:54 PM
denn34
Score: 100
Last Login: 7/20/2009
Status: offline
Can I put an sh21 or vx 21 or sh28 in a tornado? Has anyone done this and how much modifying would there be?
Hide Signatures
(in reply to t@n)
       Post #: 3371
RE: Redcat Racing Tornado Thread - 4/17/2009 5:18 PM
chevyderek72
Score: 100
Status: offline
Yes you can, but it takes some modification, but really its not worth it, it will tear up your drivetrain. Just get an sh 18, they are great motors, and have plenty of power. But the big blocks will snap drive shafts and eat your diffs.
Hide Signatures
(in reply to denn34)
       Post #: 3372
RE: Redcat Racing Tornado Thread - 4/18/2009 11:44 PM
bpotter402
Score: 100
Status: offline
alright guys, i got my glow plugs and it will start(not to easy) and run. it ran pretty good for about one tank of fuel. every time i went wot and came out of it it wants to die. i tried the #8 plug first and it would hardly run. i put in an ac3 and it ran pretty well but was having this problem with it dying.i think i just need to tune it more but if anybody has any ideas it would be appreciated. remember it is stock except an air filter. i am running 20% nitro. it is not dying when i hit the brake either. just after it has been wide open throttle once or twice. thanks guys.
Hide Signatures
       Post #: 3373
RE: Redcat Racing Tornado Thread - 4/19/2009 3:01 AM
neyou86
Score: 100
Status: offline
ive been trying to tune my buggy and i have the hsn set at 3 turns out and i was wondering if i would ever have to richen it more from that setting
Hide Signatures
       Post #: 3374
RE: Redcat Racing Tornado Thread - 4/19/2009 3:46 AM
chevyderek72
Score: 100
Status: offline
Ya 2.5-3 turns out is your base setting, then you tune (lean) from there.
Hide Signatures
       Post #: 3375
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.969RCU1
