RE: Redcat Racing Tsunami Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tsunami Thread
Page: <<   < prev  26 27 [28] 29 30 31 32 33 34 35   next >   >>
Login
RE: Redcat Racing Tsunami Thread - 2/16/2008 3:34 AM
eminentguitar
Score: 108
Last Login: 3/26/2011
Status: offline
Do you know if the balls are the same size around on the mt2 dog bones as the tsunami bones?
_____________________________
\m/(><)\m/
Hide Signatures
(in reply to ehroof)
       Post #: 676
RE: Redcat Racing Tsunami Thread - 2/16/2008 3:36 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
i have the cvd's bro but i would think they are close i just dont know if they are the same length.
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to eminentguitar)
       Post #: 677
RE: Redcat Racing Tsunami Thread - 2/16/2008 3:42 AM
eminentguitar
Score: 108
Status: offline
length is not an issue man im going to post a few pics on how to lengthen and strengthen your bones as soon as I can get my camera working.
\m/(><)\m/
Hide Signatures
       Post #: 678
RE: Redcat Racing Tsunami Thread - 2/16/2008 3:48 AM
ehroof
Score: 105
Status: offline
let the secret out of the bag bro
Hide Signatures
       Post #: 679
RE: Redcat Racing Tsunami Thread - 2/16/2008 3:49 AM
eminentguitar
Score: 108
Status: offline
or shorten them it works well and costs 5 bucks to do as many as you want just about
\m/(><)\m/
Hide Signatures
       Post #: 680
RE: Redcat Racing Tsunami Thread - 2/16/2008 4:42 AM
eminentguitar
Score: 108
Status: offline
Well no pics but ill just explain it as best as i can.
You have to grab the ends as hard as you can and pull. lol kidding
things you need - a barrel or roll pin kit with assorted sizes usually from any hardware store. (the little pins that are hallow and have a cut along the length of them)
-SILVER solder NOT LEAD OR TIN!!!!! silver solder is very strong and sticks to BARE steal very well.
You have to cut the dogbone in half and remove as much length as you need. If you have to make them 6mm shorter take 3mm off of each piece.(If you want them longer dont remove anything)
Find a barrel pin that you can barely force over the shaft of the dog bone. The tighter it is the better, it helps keep them straight.
Now you have to remove all of the black coating off of the pin and dog bones(even the inside of the pin, not fun i'm going to let you guys find a good way to do that because I still have trouble lol) I use 220 grit sand paper.
Force the dogbone halfs into the barrel pin(you may need a hammer just dont bend them) make sure you dont go to far its hard to get them out of the pin trust mel after you get the bone in the pin make sure the length is what you need by installing the bone back into the car or truck and making sure you still have play between the ends of the dog bone and you cups.
If everything looks good now your ready to solder them up. I welded mine with a MIG welder. I dont recommend it as it is really easy to warp them.
I would give you instructions on how to solder them but there are many types of silver solder some have flux and some dont. Just make sure if you get solder that does not have a flux core you have to buy the right flux for that solder.
You will need a propane torch for silver solder.
I hope this helps you guys out. I have had many challenges building this hotrod tsunami of mine
its got parts from just about anything you can think of on it.
Just pm me if you have any questions.
\m/(><)\m/
Hide Signatures
       Post #: 681
RE: Redcat Racing Tsunami Thread - 2/16/2008 4:47 AM
eminentguitar
Score: 108
Status: offline
If you have a gap in between your dogbone ends inside the pin make sure you fill it up with solder. Im going to post a picture sometim
\m/(><)\m/
Hide Signatures
       Post #: 682
RE: Redcat Racing Tsunami Thread - 2/16/2008 4:51 AM
Macanan
Score: 100
Last Login: 4/10/2011
Status: offline
Your talking about useing spring pins right, these here ?
http://www.instockfasteners.com/SearchResultsxhtmlsubcategoryid~116/criteria~/mea~0/plnk~1/search~2
thats a very good ideal you got there
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
Hide Signatures
       Post #: 683
RE: Redcat Racing Tsunami Thread - 2/16/2008 4:53 AM
eminentguitar
Score: 108
Status: offline
yup im just taking a picture of one now
\m/(><)\m/
Hide Signatures
(in reply to Macanan)
       Post #: 684
RE: Redcat Racing Tsunami Thread - 2/16/2008 4:54 AM
eminentguitar
Score: 108
Status: offline
if you put the volcano stubs in a tsunami you have to lengthen the bones thats why I thought of doing this
\m/(><)\m/
Hide Signatures
       Post #: 685
RE: Redcat Racing Tsunami Thread - 2/16/2008 5:04 AM
eminentguitar
Score: 108
Status: offline
here are some pics
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
\m/(><)\m/
Hide Signatures
       Post #: 686
RE: Redcat Racing Tsunami Thread - 2/16/2008 5:10 AM
eminentguitar
Score: 108
Status: offline
If you want a stronger dogbone dont weld them, use the solder(this is hardened steal and heat affects its strength). You can also use the barrel pins to cover the entire dogbone just make sure you have enough clearance for it
\m/(><)\m/
Hide Signatures
       Post #: 687
RE: Redcat Racing Tsunami Thread - 2/16/2008 5:16 AM
ehroof
Score: 105
Status: offline
nice information there bro, i give you an A+
Hide Signatures
       Post #: 688
RE: Redcat Racing Tsunami Thread - 2/16/2008 5:18 AM
eminentguitar
Score: 108
Status: offline
Thanks ehroof I just hope it helps someone get out of a crappy situation.
\m/(><)\m/
Hide Signatures
       Post #: 689
RE: Redcat Racing Tsunami Thread - 2/16/2008 6:55 AM
snowcruiser_91
Score: 100
Last Login: 5/18/2008
Status: offline
so, i visit this forum on my phone for the most part, making it hard to search for things in a large thread: so im sorry if this has been posted\answerd already.....i have an AMAX model cheetah, which i was told is basically a redcat tsunami regulalr...i got it used, already broken in, and when i got it, i got it to run, but very rich, and it wouldnt stay still on idle, it would wanna drive off...so i tried to adjust her, i know where the high speed needle, low speed needle, and idlele set are...i adjusted them according to a thread on here; high speed-4 turns out or so, low speed-the screw head flesh with the casing its in, but my idle set screw doesnt seem to o anywhere when i turn it, i can turn it infinately in either direction with out it going in or out or changing anything...now, even when primed, glow starter charged and on, i cant get it to start...? any suggestions?
Hide Signatures
(in reply to Chubbysdad)
       Post #: 690
RE: Redcat Racing Tsunami Thread - 2/16/2008 7:14 AM
ehroof
Score: 105
Status: offline
4 out is too rich on the high needle, try starting it off the ground, if its starts and stalls when you put it on the ground, the clutch spring is broken and needs to be replaced
Hide Signatures
(in reply to snowcruiser_91)
       Post #: 691
RE: Redcat Racing Tsunami Thread - 2/16/2008 7:27 AM
snowcruiser_91
Score: 100
Status: offline
thanks 4 the quick reply ehroof...! ill try that probably tomorrow, but what about the idle set screw...?
Hide Signatures
       Post #: 692
RE: Redcat Racing Tsunami Thread - 2/17/2008 8:36 AM
KeithjV
Score: 125
Last Login: 4/10/2012
Status: offline
quote:
ORIGINAL: ehroof
lol, in small case letters i didnt realize what it was, i have some GPM parts on my hpi mt.
Got any pics of your MT? Im in the process of hopping up a used MT2 I picked up.
Hide Signatures
       Post #: 693
RE: Redcat Racing Tsunami Thread - 2/17/2008 8:57 AM
KeithjV
Score: 125
Status: offline
quote:
ORIGINAL: snowcruiser_91
Take the air filter off and look inside the carb. As you turn the idle screw does the gap get larger?
And I agree with ehoof, its sounds like the clutch spring is broken. You can bend a new end on it if it is.
Hide Signatures
       Post #: 694
RE: Redcat Racing Tsunami Thread - 2/17/2008 5:31 PM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: KeithjV
quote:
ORIGINAL: ehroof
i will take some with the body off, its got the os cvrx .18, titanium turnbuckles, aluminum shocks, cvd's and some other stuff, lol
Click for fullsize
Hide Signatures
(in reply to KeithjV)
       Post #: 695
RE: Redcat Racing Tsunami Thread - 2/22/2008 6:35 AM
eminentguitar
Score: 108
Status: offline
Ehroof do the mt2 wheels work on the tsunami?
\m/(><)\m/
Hide Signatures
       Post #: 696
RE: Redcat Racing Tsunami Thread - 2/22/2008 6:39 AM
KeithjV
Score: 125
Status: offline
Yes they do. I put the geolanders on mine and they work great. Much better then the stock tires and foams.
Hide Signatures
       Post #: 697
RE: Redcat Racing Tsunami Thread - 2/22/2008 6:40 AM
eminentguitar
Score: 108
Status: offline
the rims too?
\m/(><)\m/
Hide Signatures
       Post #: 698
RE: Redcat Racing Tsunami Thread - 2/22/2008 6:45 AM
KeithjV
Score: 125
Status: offline
Yep. They use standard 12mm hexes.
These are the wheels Im using http://cgi.ebay.com/HPI-Scorch-6-Spoke-2-2-Black-Chrome-Wheels-4-3089_W0QQitemZ110225078178QQihZ001QQcategoryZ44028QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
and these are the tires
http://cgi.ebay.com/HPI-2-2-Yokohama-Geolandar-Tires-4-for-Stampede-Rustler_W0QQitemZ110225131064QQihZ001QQcategoryZ44028QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
Hide Signatures
       Post #: 699
RE: Redcat Racing Tsunami Thread - 2/22/2008 6:48 AM
KeithjV
Score: 125
Status: offline
The first picture is the stock tires and wheels and the second is the upgrade.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 700
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
