HimotoRacingUSA
Joined: 2/27/2006 From: howard beach, NY, USA Status: online
its the metal gears on the engine, its behind or underneath that, you have to take the engine out, (4) screws on the bottom, take the clutch bell off, screw at the end of it, and swap the spring, you wrap it around the shoes, you will need to clamp it first, if you get the setup from clermont, you would take the shoes off too, just but everything back the way you took it off, its real easy
_____________________________
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM ***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
