KeithjV
NY, USA Status: offline
ok, apparently my other post was deleted because I included a link to show you the servos I was talking about. Must be something new since Ive seen a number of posts like that in the past. Anyway, do a search for MG995 servos and see what you find. Heres the specs * Dimension : 40mm x 19mm x 43mm * Weight : 55g * Operating Speed : 0.17sec / 60 degrees (4.8V no load) 0.13sec / 60 degrees (6.0V no load) * Stall Torque : 13kg/cm at 4.8V 15kg/cm at 6V * Temperature Range : -30 to 60 Degree C * Dead Band Width : 4 usec * Operation Voltage : 4.8 - 7.2Volts * Motor Type: 3 Pole Ferrite * Potentiometer Drive: Indirect Drive * Bearing Type: Dual Ball Bearing * Gear Type: All Metal Gears * Connector Wire Length: 11.81" (300mm)
< Message edited by KeithjV -- 5/6/2008 4:01:54 AM >
