RE: Redcat Racing Tsunami Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tsunami Thread
Page: <<   < prev  72 73 [74] 75 76 77 78 79 80 81   next >   >>
Login
RE: Redcat Racing Tsunami Thread - 8/7/2008 6:14 AM
KeithjV
Score: 125
Last Login: 4/10/2012
Status: offline
more then likely the clutch spring broke. It its just the end you can easily put a new bend on it. I did it with mine and it lasted for a while before I had to do it again. After the second time it broke I replaced it. You'll have to pull the cb to find out for sure though.
Hide Signatures
(in reply to retrosoul)
       Post #: 1826
RE: Redcat Racing Tsunami Thread - 8/8/2008 6:22 AM
retrosoul
Score: 100
Last Login: 5/3/2009
Status: offline
ok i think i found the click and hang up it is coming from the brake. the metal disk flops around i can move it back n forth im not sure if this is normal i think it should be tight on the drive shaft.
_____________________________
Go Fast or Go Home!!!
Hide Signatures
(in reply to KeithjV)
       Post #: 1827
RE: Redcat Racing Tsunami Thread - 8/8/2008 6:55 AM
retrosoul
Score: 100
Status: offline
ok nevermind nothing wrong with the brakes its defanetly the rear drive shaft. hmm how do i xplain it. if you look at the drive shaft coupling on the transmision side the pins that go into the slots to stop the shaft from spinning in the coupling are warn and one of the pins actually slips out of the slot and drops inside the coupling the pin on the other side stays in place im not sure on what part should changed either way it looks like a **** to change i can get the set screw loose on the front drive shaft ill try some pb blaster on it anyways i can probaly still drive it till it breaks completly while the replacment parts are on the way it doesnt slip during driving i also noticed that the pins made groves on the inside of the coupling grove im sure this is normal wear and tear but ive only had the truck for like a month now
Hide Signatures
       Post #: 1828
RE: Redcat Racing Tsunami Thread - 8/8/2008 7:25 AM
retrosoul
Score: 100
Status: offline
ok by coupling i mean universal joint sorry about that
Hide Signatures
       Post #: 1829
RE: Redcat Racing Tsunami Thread - 8/8/2008 10:10 AM
eminentguitar
Score: 108
Last Login: 3/26/2011
Status: offline
Yeah man thats normal wear and tear they dont last long and when you try to get the set screws out try to heat them up a bit thay have lock tite on them and heat is what is used to break it free. I put the hpi mt2 drive cups on my tsunami because I was tired of them wearing out all the time. My brake disk does the same thing man sometimes it hangs up.
< Message edited by eminentguitar -- 8/17/2008 9:32 PM >
\m/(><)\m/
Hide Signatures
       Post #: 1830
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:08 AM
KeithjV
Score: 125
Status: offline
You can also try adding an o-ring to the drive cup to take up some of the play in the dogbone
Hide Signatures
       Post #: 1831
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:11 AM
retrosoul
Score: 100
Status: offline
got a new air filter setup today from my lhs. its made by ofna its mutch larger not sure if it adds more power but it makes me happy looking at it also picked up some e-clips body clips and a quart of fuel. my lhs doesnt sell 20% by the gallon anymore only 33% and im sure 33% wouldnt be good for my tsunami.
Hide Signatures
(in reply to eminentguitar)
       Post #: 1832
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:12 AM
retrosoul
Score: 100
Status: offline
already an o-ring in it can i add 2 o-rings?
Hide Signatures
       Post #: 1833
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:14 AM
KeithjV
Score: 125
Status: offline
retro you need to post some pictures with the new filter.
You could run the 33% but you might have to go to a cooler plug, it might cause the engine to run too hot.
Hide Signatures
       Post #: 1834
retrosoul
Score: 100
Status: offline
where in ny keith?
Hide Signatures
       Post #: 1835
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:15 AM
KeithjV
Score: 125
Status: offline
sure as long as it doesnt push the end of the dogbone out of the cup.
Im on Long Island
Hide Signatures
       Post #: 1836
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:43 AM
retrosoul
Score: 100
Status: offline
ok heres some picture of the air filter and yes the throtle linkage does hit the filter im going to fabricate a small aluminum bracket for it.
< Message edited by retrosoul -- 8/9/2008 3:44 AM >
Hide Signatures
       Post #: 1837
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:47 AM
retrosoul
Score: 100
Status: offline
i need a good tire and rim setup what can i get for direct fit?
Hide Signatures
       Post #: 1838
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:48 AM
retrosoul
Score: 100
Status: offline
also 40 dollas is my budget on tires and rims less would be good.
Hide Signatures
       Post #: 1839
uhoo_01
Score: 100
Last Login: 5/12/2012
Status: offline
hey just wondering is it safe with the single speed redcat tranny to just run power to the rear wheels (2wd) by droping out the front shafts????? because iv bin breaking my engine in with only 2wd cos im waiting for a drive shaft . plus i was thinking any way 2wd will take a lil more load of the drive train because is will wheel spin more like it does and not hook up and break stuff .
:SC10 full carbon chassis race truck :)
:Mugen MBX5R-PS - go-tech
Hide Signatures
       Post #: 1840
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:51 AM
uhoo_01
Score: 100
Status: offline
quote:
ORIGINAL: retrosoul
the hpi racing Yoky geo-landers are a great tyre there only 2.2 but are super soft and sticky , i run them on the rear . but i think there $15 or so a pair so that only leaves $10 for rims .
Hide Signatures
       Post #: 1841
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:52 AM
eminentguitar
Score: 108
Status: offline
uhoo I made mine 2wd and it was killer hard to controle and the rear diff didnt like it very much and your just going to add 2 times as much strain to the powertrain. Even if its spinning its still hard on things
\m/(><)\m/
Hide Signatures
(in reply to uhoo_01)
       Post #: 1842
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:55 AM
uhoo_01
Score: 100
Status: offline
quote:
ORIGINAL: eminentguitar
yeah i no about hard to control lol its a mission and a half , my front drive shafts have come so i guess il just put them in but it does the best burnouts at the moment lol hahahahhahaha
Hide Signatures
       Post #: 1843
retrosoul
Score: 100
Status: offline
do the geo landers come with foam?
Hide Signatures
       Post #: 1844
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:58 AM
uhoo_01
Score: 100
Status: offline
yes
Hide Signatures
       Post #: 1845
RE: Redcat Racing Tsunami Thread - 8/9/2008 3:59 AM
uhoo_01
Score: 100
Status: offline
if you do go the 2.2" option make sure you get the wheel offset that fits on with out hitting the arm's or anthing
Hide Signatures
       Post #: 1846
RE: Redcat Racing Tsunami Thread - 8/9/2008 4:39 AM
retrosoul
Score: 100
Status: offline
check this out http://www.nitrorc.com/default2.asp?Introduction=http://www.nitrorc.com/fuelws/
Hide Signatures
       Post #: 1847
RE: Redcat Racing Tsunami Thread - 8/9/2008 4:53 AM
eminentguitar
Score: 108
Status: offline
thats cool man
\m/(><)\m/
Hide Signatures
       Post #: 1848
RE: Redcat Racing Tsunami Thread - 8/9/2008 6:17 AM
Kodiac400
Score: 100
Last Login: 11/8/2012
Status: offline
These are the tires and rims I chose. They are a direct fit.
Click Here
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1849
RE: Redcat Racing Tsunami Thread - 8/9/2008 6:48 AM
retrosoul
Score: 100
Status: offline
did any 1 elses tsunami come rtr with aluminum body shocks?
Hide Signatures
(in reply to Kodiac400)
       Post #: 1850
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
