Ralph Morris
AZ, USA Status: offline
[QUOTE]Originally posted by Zweihander I originally designed a tandem wing plane, but quickly realized that someone has to fly it, which I have never seen anybody try. Bipe seemed close enough to me. I will definately post pictures of the plane once complete after the competition. [/QUOTE] Don't be afraid of a tandem-wing design. There are several successful ones, full-scale and models. Make a smaller model, with a box fuselage so you can move the forward wing fore and aft. Place the CG (cargo hold) just ahead of the aft wing, and vary the size and location of the front wing to achieve balance and positive pitch stability. You can calculate the wing areas and distance from CG to centers of aerodynamic effort using standard equations or a simple graphic method. By the way, you don't need a horizontal stabilizer for this design, although Andy Lennon put a T-tail on a similar one. This is the only photo I could find, but you can see the general layout. Notice how close to the ground the front wing is, in order for it to produce more lift than the aft wing, when lifting off. It's a natural for a weight-lifting contest. http://www.amazon.com/exec/obidos/tg/detail/-/0911295402/ref=lib_rd_prev_4/104-9375038-2675145?v=glance&s=books&vi=reader&img=4&jumbo=1#reader-link I've completed a design for a canard without verticals, except for the pylon that supports the aft wing. It banks and turns ala B-2, using "spoilerons," and is designed to compete in the annual R/C Marathon held at Baker, California. The open class allows 1/2 gallon of fuel of your choice, and the longest distance flown over a 50-mile closed course wins. You have to follow the airplane down a two-lane blacktop with a convertible or pickup, so you can see the airplane overhead. It's great fun, and the team I was on won the open event twice back in the 90s (Team LA-LA, sponsored by Jim Kelley). Click on the following link to check it out. It's similar to weight lifting, when you consider lifting off with 1/2 gallon of fuel aboard. They now have an electric class, as well as open and sportsman, where you can fly your regular Sunday flyer. http://www.camarathon.com/
_____________________________
Keep 'em flying!
