RE: WK-1001 info?
Tower Hobbies
Logged in as Guest
  Printable Version
Miniature Aircraft USA Ion-X - RTF
Seller:  1surfer
Details:   $5,000.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: WK-1001 info?
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: WK-1001 info? - 2/13/2007 7:51:43 PM
davenraithatha
Status: offline
i see, what is a negative/positive shift and how can you tell which it is?
(in reply to soneebee)
       Post #: 26
RE: WK-1001 info? - 2/13/2007 10:12:53 PM
soneebee
Status: offline
Futaba/Hitec radios have negative shift , Jr are on positive shift.. there is actually nothing better with one another its just the way the RX recieves its into from the TX.. both fuctions the same.. its more like a lock so that you cannot use a JR rx with a Futaba Tx... but this applies on the PPM RX... if you are using PCM the more it will not match.. so it will be very hard to match radios with PCM mode....
(in reply to davenraithatha)
       Post #: 27
RE: WK-1001 info? - 2/14/2007 7:47:07 PM
davenraithatha
Status: offline
ok cool so is the wk-1001 negative shift?
thanks for all your help btw
       Post #: 28
RE: WK-1001 info? - 2/16/2007 3:06:07 AM
soneebee
Status: offline
I am not sure if the WK-1001 is negative shift... JR is positive shift.. i guess if its identical to the Jr3810 it might have a positive shift....
       Post #: 29
RE: WK-1001 info? - 2/17/2007 2:10:14 AM
scorp27
Status: offline
yeaaahhhhh my wk1001 is here , but my df36 aint hopefully it gets here tomarrow, now all i gotta do is try to find a trainer cord that will plug into the back of the radio and connect to the realflight controler so i can use it on realflight.
       Post #: 30
RE: WK-1001 info? - 2/17/2007 11:21:09 PM
soneebee
Status: offline
I think you can use the JR trainer plug.. the one on the Wk-1001 is only a earPhone jack....
(in reply to scorp27)
       Post #: 31
RE: WK-1001 info? - 2/22/2007 3:43:54 AM
scorp27
Status: offline
soneebee, was it very difficault to get it to work with the df36, seems like all my functions are reveresed and using the rever on the radio program doesnt seem to help.
       Post #: 32
RE: WK-1001 info? - 2/22/2007 3:57:08 AM
soneebee
Status: offline
The controller was really easy to setup.. I used it on the 36 and it was doing good.. never encountered the servo direction problem.. I also set the BeltCP with this radio.. and set it for CCPM.. it also works okay.... i wonder why you cannot get the direction correctly....
       Post #: 33
RE: WK-1001 info? - 2/22/2007 4:00:46 AM
scorp27
Status: offline
Dont know whats goin on with it, it wont even start the blades turning and its mixing the aileron and elevator with the thorttle. Ill get this thing figured out or it will kill me first...lol
Thanx for the fast response soneebee.
       Post #: 34
RE: WK-1001 info? - 2/22/2007 4:41:23 AM
soneebee
Status: offline
I think you have set is up wrong.. are you using CCPM on the #36.. this is a mechanical mix heli.. you have to set it up to normal.... it might be the reason for the mixing movements not he servos...
quote:
ORIGINAL: scorp27
       Post #: 35
RE: WK-1001 info? - 2/22/2007 10:13:27 AM
davenraithatha
Status: offline
scorp27 are you using the stock df36 reciever?
thanks
       Post #: 36
RE: WK-1001 info? - 2/22/2007 11:24:42 AM
scorp27
Status: offline
yep its stock reciever in the 36. I did put the tx in norm mode but was still mixin the servos im gonna order a speed control and use the wk801 receiver and see what happens i think. Ill hopefully have time this week to mess with it. Thanx guys.
       Post #: 37
RE: WK-1001 info? - 2/22/2007 12:24:50 PM
soneebee
Status: offline
I think its because the RX used is not the WK801.. you should use the supplied RX to get the mixing to work properly
       Post #: 38
RE: WK-1001 info? - 2/22/2007 1:27:37 PM
davenraithatha
Status: offline
So what other recievers work with the wk-1001?
       Post #: 39
RE: WK-1001 info? - 2/22/2007 10:52:10 PM
scorp27
Status: offline
thanx soneebee, i still aint ordered my esc but im plannin on it. I still aint got it flyin with the stock transmitter yet still setting it up. Gonna read the posts you and Thierry have written on the 36.
       Post #: 40
