RE: 1/2 Scale Fokker D-8    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: 1/2 Scale Fokker D-8
Page: <<   < prev  19 20 [21] 22 23 24 25 26 27 28   next >   >>
Login
RE: 1/2 Scale Fokker D-8 - 4/1/2010 6:46 AM
abufletcher
Score: 1576
Last Login: 6/19/2013
Status: offline
That's an interesting question. On a small model, covered with thin ply, I wouldn't expect any problems. In essence the 2.4 Rx in my Albatros CI will be "inside a ply box" (aka "the fuselage"). But on a "semi-full-scale" model like yours, there's a lot more wood. Still, I would imagine that the 2.4 signal can penetrate a few sheets of plywood since 2.4 phones seem to be able to handle whole walls in houses. In the end, the only real answer to your question is TESTING, TESTING, TESTING (to your own satisfaction).
Maybe you could make up a "test box" with a servo that raises a flag or something outside the box and then do a full range check. It's strange to think of a teeny little 2.4 Rx controlling that whole enormous model. Is there such as thing as using two Rx's in a redundant system?
Hide Signatures
(in reply to TKFOKKER)
       Post #: 501
RE: 1/2 Scale Fokker D-8 - 4/1/2010 6:57 AM
cocobear
Score: 110
Last Login: 6/18/2013
Status: offline
Hey Tom, I have my receivers buried in Ply boxes in all my Albi's so far so good
Dave
Hide Signatures
(in reply to abufletcher)
       Post #: 502
RE: 1/2 Scale Fokker D-8 - 4/1/2010 4:07 PM
TKFOKKER
Score: 130
Last Login: 6/13/2013
Status: offline
Abufletcher and Dave
Thanks for the input, I feel better now knowing that you do the same Dave. After all those beautiful models you build fly great! Thanks again, Tom
Hide Signatures
(in reply to cocobear)
       Post #: 503
RE: 1/2 Scale Fokker D-8 - 4/4/2010 4:20 PM
TKFOKKER
Score: 130
Status: offline
Happy Easter to all of you who occasionally visit my build on the D-8. Good health to all!
Tom
Hide Signatures
       Post #: 504
RE: 1/2 Scale Fokker D-8 - 4/6/2010 11:38 PM
TKFOKKER
Score: 130
Status: offline
Today I received my wing mount hardware in the mail from GTM. He had Rodger Freeman make these for me. Odd that such a small piece of thin metal holds the whole wing to the fuse. I will get these bent to shape, then put the fuselage back on the table to fit the struts to the wing. I still need to make my rear struts. And figure out the incidence, fun stuff!
Thanks for taking a peek!
Tom
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 505
RE: 1/2 Scale Fokker D-8 - 4/7/2010 3:27 AM
ProfLooney
Score: 100
Status: offline
Tom how thick metal you using there? looks like it is abt 1/16 - 3/32 thick by the picks
Joe
_____________________________
Scale Model Design And Fabrication Services L.L.C.
Http://www.proflooney.net
Hide Signatures
       Post #: 506
RE: 1/2 Scale Fokker D-8 - 4/7/2010 4:01 AM
abufletcher
Score: 1576
Status: offline
quote:
ORIGINAL: TKFOKKER
Early hang-gliders had what was humorously called the "Jesus bolt." This was a single bolt that held the sling and the wing together and was all that kept these "daring young men" from plunging to their deaths.
Reading your build with all its great photos is like taking a Master Course in model building! Thanks!
Hide Signatures
       Post #: 507
RE: 1/2 Scale Fokker D-8 - 4/8/2010 4:06 AM
TKFOKKER
Score: 130
Status: offline
Joe
Yes just about 1/16th but a little soft. I'm sure they'll be ok. As long as I don't catch a wing tip for any reason! That is if I'm lucky enough to get her flying some day.
Hide Signatures
       Post #: 508
RE: 1/2 Scale Fokker D-8 - 4/16/2010 5:57 AM
TKFOKKER
Score: 130
Status: offline
Well I finally cleaned the shop and brought the fuselage back in. As you can see I stripped down the fuselage to work on the wing mounting. I positioned the aircraft across my table so I could lower the wing over it, to be mounted on. This way I can set it up and not have to move it away, just lift it out off the way. I will fill the tops of the struts and put the tubes in the tops so I can bolt them on, that is the metal mounts. Then I will attach them to the spars. The rear struts need to be made also. Glenn's plans show 0 incidence. Any takes
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 509
RE: 1/2 Scale Fokker D-8 - 4/19/2010 5:04 AM
Horsepoweraviation
Score: 100
Status: offline
Hey Tom I set the D6 @ 0 and it flies great....... 2 cents worth.......
I cant get over the incredible detail you have put in this plane.......we all are not worthy!
Hope to see you this year!
Paul
OHIO DAWN PATROL
July 19-21 2013
Hide Signatures
       Post #: 510
RE: 1/2 Scale Fokker D-8 - 4/19/2010 5:43 PM
cocobear
Score: 110
Status: offline
Hey Paul, You choose not too. What's a word that rymes with crazy:-)
Hide Signatures
(in reply to Horsepoweraviation)
       Post #: 511
RE: 1/2 Scale Fokker D-8 - 4/19/2010 6:57 PM
Horsepoweraviation
Score: 100
Status: offline
quote:
ORIGINAL: cocobear
HEY COCOBUTTER, soooo??? What's a word that RHYMES with "Circus freak"?
Maybe you should use that "crazy rhyme" and start using a dictionary.......LOL!!!!!!!!
OHIO DAWN PATROL
July 19-21 2013
Hide Signatures
       Post #: 512
RE: 1/2 Scale Fokker D-8 - 4/20/2010 1:45 AM
TKFOKKER
Score: 130
Status: offline
You Guys are TOO FUNNY, But I'm The crazy one. You guys are having more fun than I am!!! Believe me.
Tom
Hide Signatures
       Post #: 513
RE: 1/2 Scale Fokker D-8 - 4/20/2010 1:49 AM
ProfLooney
Score: 100
Status: offline
Hey Tom do you by chanve have an all up weight on that beast so far. I am curious as to how its coming in right now
Hide Signatures
       Post #: 514
RE: 1/2 Scale Fokker D-8 - 4/20/2010 1:56 AM
TKFOKKER
Score: 130
Status: offline
Last time I checked it was around 50lbs.
Hide Signatures
(in reply to ProfLooney)
       Post #: 515
RE: 1/2 Scale Fokker D-8 - 4/20/2010 1:59 AM
ProfLooney
Score: 100
Status: offline
really good for all thats in it. I just started my thread in this forum on my 1/2 scale Alb DVa I have been commissiond to do I hope I can keep it under a ton lol as it has to be as yours museum scale and doing a 1/2 covered 1/8 scale so both have to be anally built
Hide Signatures
       Post #: 516
RE: 1/2 Scale Fokker D-8 - 4/20/2010 2:06 AM
TKFOKKER
Score: 130
Status: offline
Good luck! I guess you have a lot of time? And a very understanding wife???? I wish I hadn't gone so crazy on my project, I miss having fun. I'll be watching!
Tom
Hide Signatures
       Post #: 517
RE: 1/2 Scale Fokker D-8 - 4/20/2010 2:32 AM
ProfLooney
Score: 100
Status: offline
well im a millwright and there hasnt been any work round here for a couple yrs. alcoa and john deere and the general mills etc are all holding onto their wallets.
as far as wife she likes the planes and such and since nothing is coming out of my bank account she dont care lol. I have spent most of last year designing abt 8 or so planes for the UK Dawn Patrol Show team and am finishing up my next to last design for them so I will have some time to build and need the nice payday that will get when their finished.
Joe
Hide Signatures
       Post #: 518
RE: 1/2 Scale Fokker D-8 - 4/20/2010 2:46 AM
TKFOKKER
Score: 130
Status: offline
Joe
That's really cool that you can find a way to make a few extra bucks out of the hobby. It seems the only way I do is when there's totally no work and I have to sell the planes I love. As is the 1/2 D-8 That will be going as soon as some one wants it bad enough. In the mean time I will slowly continue to finish it.
Hide Signatures
       Post #: 519
RE: 1/2 Scale Fokker D-8 - 4/20/2010 2:53 AM
ProfLooney
Score: 100
Status: offline
Yea I just wished I could do more building than drawing. the UKDP wants to have 60 planes in the air in the next couple years and I will be supplying a lot of the plans. As soon as I get caught up they want more but hey its a few extra bucks.
I am finishing a Pflaz DRI for them and peckergnat then have to finish an FE2b then they contacted me week ago and already commissioned me to finish up my Roland series with a Roland DII for them and an AEG Giv bomber which will be little over 20 ft ws at 3rd scale. Plus theres still the Snipe to do and an LVG CVI
So I have another year or so in work just on those then theres 30 ish planes left they still need. as they only trying to allow 1 of every type so ppl dont all build the same thing.
Hide Signatures
       Post #: 520
RE: 1/2 Scale Fokker D-8 - 4/20/2010 3:06 AM
TKFOKKER
Score: 130
Status: offline
Wow, That's a lot of drawings and design work.
Hide Signatures
       Post #: 521
RE: 1/2 Scale Fokker D-8 - 4/20/2010 3:17 AM
ProfLooney
Score: 100
Status: offline
well in the last year I provided the following. though they fairly detailed and complete they are more prototype plans they are building now then will send me all the info for changes made so I can finalize for market.  remembering all their planes have to be 3rd scale so that everythings the same for their shows.
Bristol Fighter
Sopwith Triplane
Roland DVI
Roland CII Walfisch
Pfalz DXII
Pfalz DRI/DVII (should be finished this week)
FE2b (couple weeks after Pfalz)
theres another I am forgetting here but the future stuff is
Roland DII
Sopwith Snipe
Albatros Series
Bristol Scout
AEG GIV
LVG CVI
so those are the ones I have finished and have yet to do for them but I know theres 1 or 2 finished ones I am forgetting abt here. I know the rolands are in the middle of being built right now and I am waiting to see pics. the Pfalz DXII has 2 being built as 1 is early model with different tail feathers and the other is late model. and I know theres 2 Bristol Fighters but not sure if their started yet. the Pfalz and rest will be built once ppl finish up projects they working on currently
so you can see why I dont get much time for building its all drawing 14 hrs a day 6 to 7 days a week hehehe
Hide Signatures
       Post #: 522
RE: 1/2 Scale Fokker D-8 - 4/20/2010 3:37 AM
TKFOKKER
Score: 130
Status: offline
Is there any way we can get those guys to post construction pic's on RCU? I would love to see some of there work. Always can learn from others.
Tom
Hide Signatures
       Post #: 523
RE: 1/2 Scale Fokker D-8 - 4/20/2010 3:43 AM
normgoyer
Score: 100
Last Login: 7/17/2012
Status: offline
Hi Tom, it's too bad you don't live our here in LaLa land, you would be working for some movie studio model division at really big bucks. At 83 I have all the work I can handle writing about aircraft. There are folks working out here that wouldn't qualify to hold your monkey wrench. Norm
Hide Signatures
       Post #: 524
RE: 1/2 Scale Fokker D-8 - 4/20/2010 3:52 AM
TKFOKKER
Score: 130
Status: offline
Norm
It's so nice to hear from you. And thanks for the compliments. Yes I do wish I was doing just that, making models for the movies, but like my woman says, you picked your profession. Construction in New England really sucks. And I'm getting too old to be doing what I do. I'm pleased to see your healthy and busy, You were always a charm to see at the events. Days gone by, Good ones. Stay in touch.
Tom
Hide Signatures
(in reply to normgoyer)
       Post #: 525
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
