SLAUGHTERHOUSEJACK1988
Joined: 1/25/2007 From: Isle of Wight, UNITED KINGDOM Status: offline
The best ive ever used, i buy the bottle version rather than the areosole*, then as you see i pure about quarter* of a jar full put all ya bits in plastic or metal, but i tend to do all metal parts, screws, drive shaft, bearings e.t.c together and then do all the plastic bits in another one and shake it. Then you sive* out all the liquid(into another jar you can reuse it a couple of times) then fill the jar up about a quater* of hot water and shake it again for a lil while then sive* out the water and dry your parts, what i do then if im not going to rebuild straight away is put all your bits you have just done in another jar or plastic bag and if there metal put a small amount of oil in there to prevent rust. Its a really good way to clean small parts quickly. Its called gunk and 1litre cost about £5.
