mini lst tires
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> mini lst tires
Page: [1]
Login
mini lst tires - 1/31/2007 10:37:47 PM
zjwhitrock
Status: offline
will the mini lst tires work on rc18t rims
and what adapter do you need to run half 8 wheels
_____________________________
speed calc www.scriptasylum.com/rc_speed/_top_speed
hyper 7 PBS, RC10B4, evader
       Post #: 1
RE: mini lst tires - 2/1/2007 1:16:53 AM
Racing T
Status: offline
no, the mini lst tires are way bigger than the rc18t rims, and running the half 8 tires in wich car? here is a comparation between the to tires to give yopu an idea,
Click to see fullsize image.
Click for fullsize
(in reply to zjwhitrock)
       Post #: 2
RE: mini lst tires - 2/1/2007 1:37:25 AM
aznmode
Status: offline
quote:
ORIGINAL: zjwhitrock
You might be able to fit it if you use a widetrack conversion kit. The LST tires will rub when you turn. Also the LST have a small hex pattern on the rim and will not bolt on with out some type of adapter. This could be an expensive conversion if it was possible.
       Post #: 3
RE: mini lst tires - 2/1/2007 2:25:14 AM
Dadeent
Status: offline
you can bolt up the tire with the same adaptors that the mini lst uses...I have done it on mine but didn't last long, you have to turn the steering travel way down....
hope this helps
(in reply to aznmode)
       Post #: 4
RE: mini lst tires - 2/1/2007 3:17:52 AM
Racing T
Status: offline
but he was asking in if you can use the rc18t wheels on the mini lst tires I think, not if you can run mini lst wheels and tires on the rc18t
(in reply to Dadeent)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
