What Size Engine Would You Like To See In The "cd" Enine Range
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $18.95   |  11/3/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> What Size Engine Would You Like To See In The "cd" Enine Range
Page: [1] 2   next >   >>
Login
What Size Engine Would You Like To See In The "cd&... - 2/5/2003 11:03 PM
Otto Kudrna
Score: 100
Last Login: 4/24/2004
Status: offline
This is a poll to find out what size of RCV "CD" engines would be the most desired by the modeling public. The CD engine range is the new RCV engine which at the time only has the .58 and will soon have the .96. The .96 will be 81mm (3 3/16") tall from center line to top of head. This dimension is exactly the same as the OS .60FP 2cy engine. Please respond to this post only once and encourage others to do the same. "But PLEASE respond" You may have more than one size you want to see, please list them in the order of preference most preferred on top.
OTTO KUDRNA RCV TECH SUPPORT
Click to see fullsize image.
Click for fullsize
< Message edited by Otto Kudrna -- Feb 5 2003 6:28PM >
Hide Signatures
       Post #: 1
CD series - 2/6/2003 12:04 AM
lokeetl
Score: 100
Last Login: 4/5/2005
Status: offline
Hi Otto,
I was going to say something a little bigger than, say, an OS 91FS, but I see RCV is going to have that covered.
How about something in the 1.3 range? 1.4 maybe? That would get into alot of 1/4 scale stuff that way. Maybe even pull a F8F?
Talk to you later,
Chip
Hide Signatures
(in reply to Otto Kudrna)
       Post #: 2
RCV poll - 2/6/2003 1:08 AM
Hobbsy
Score: 122
Last Login: 11/26/2009
Status: offline
I would suggest a 1.25 cu. in. engine called the 125, it's a nice sounding number and nobody except Maloney makes one that size, you'd be surprised how many people would buy it just because it's .05 bigger than a 120.
_____________________________
If it ain''t a Farmall, it ain''t at all.
Hide Signatures
       Post #: 3
What Size Engine Would You Like To See In The "cd&... - 2/6/2003 6:01 AM
edwarda10pilot
Score: 100
Last Login: 11/21/2009
Status: offline
Otto:
I think that I would like to see something in the 1.5 range in both the "CD" and the "SP" line.
Ed
Hide Signatures
       Post #: 4
What Size Engine Would You Like To See In The "cd&... - 2/6/2003 6:15 AM
Juice
Score: 105
Status: offline
How about a gas RCV engine? Something that will go into a .60 to 1.20 sized warbird.
Juice
Hide Signatures
       Post #: 5
What Size Engine Would You Like To See In The "cd&... - 2/6/2003 7:35 AM
Damnathius
Score: 100
Last Login: 10/25/2004
Status: offline
How about a twin based on the CD design? Small, large, doesn't matter.
Hide Signatures
       Post #: 6
What Size Engine Would You Like To See In The "cd&... - 2/6/2003 9:56 AM
MikeChilson
Score: 100
Last Login: 11/25/2009
Status: online
I would suggest 1.3 or a 1.6 in that profile.
Mike Chilson
RCSCALEBUILDER.COM Founder
Hide Signatures
       Post #: 7
What Size Engine Would You Like To See In The "cd&... - 2/6/2003 9:06 PM
bgi
Score: 100
Last Login: 10/27/2008
Status: offline
a .72 for the .40 size planes and a 1.8 for the 1.20 planes would be nice.
Hide Signatures
       Post #: 8
What Size Engine Would You Like To See In The "cd&... - 2/6/2003 9:32 PM
JoeyCoates
Score: 100
Status: offline
How about a .75 in the SP line as it would be right in between the .60 and the .90?
Hide Signatures
       Post #: 9
What Size Engine Would You Like To See In The "cd&... - 2/6/2003 9:46 PM
P-51B
Score: 295
Last Login: 10/21/2009
Status: offline
SP range - 2.5 - 3.0 GAS (something for an 85" warbird turning a scale size 4 blade with hot performance)
CD range - 1. See above
2. 1.80
Have you given Live Wire a 5-star rating yet today?
Hide Signatures
       Post #: 10
What Size Engine Would You Like To See In The "cd&... - 2/6/2003 11:17 PM
w8ye
Score: 138
Status: online
There seems to be a lot of "120" size ARF and kit planes available. I think that one in the 120 physical size would be Ideal.
As Hobbsy mentions, a 1.25 would have a nice ring to it. There's not any around anymore this size and it would have a nice unique number that people would remember.
Jim
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 11
What Size Engine Would You Like To See In The "cd&... - 2/8/2003 7:01 PM
Iflyrc4fun
Score: 100
Last Login: 3/21/2006
Status: offline
I like the possibility of a big block. Something like a 2.5 ci. Since other guys on this thread like the sound of a 125 you could call this a 250. When it come to big engines the choices get limited, beyond the Saito 180 or YS 140 people are forced to 2 cycles like Moki 180 or 210 or they go gas. I think a smooth running light weight big block 4 cycle single cylinder would fill a nitch that is now empty
Hide Signatures
       Post #: 12
What Size Engine Would You Like To See In The "cd&... - 2/8/2003 8:28 PM
Edwin
Score: 110
Status: offline
I would love a 1.20 size also.
Edwin
Hide Signatures
       Post #: 13
What Size Engine Would You Like To See In The "cd&... - 2/10/2003 1:36 AM
zagi450t
Score: 100
Last Login: 10/1/2009
Status: offline
how about a 30 or 40 size for twin engine planes.
Hide Signatures
       Post #: 14
What Size Engine Would You Like To See In The "cd&... - 2/10/2003 3:50 AM
ric52
Score: 100
Last Login: 10/26/2007
Status: offline
I agree with the friend from ohio: a big 4 stroke single cylinder of more than 30cc capacity (i.e. 1.80 for you!) is missing on the market and should be very interesting.
I think the right way should be a big friend of the RCV 58 that is more easy to fit in a cowl and should have the same cooling of a traditional engine.
ric 52
Hide Signatures
       Post #: 15
What Size Engine Would You Like To See In The "cd&... - 2/10/2003 12:30 PM
McGuiver
Score: 100
Last Login: 7/17/2008
Status: offline
For me a .60 to .80 gas burner would be great as I am in the process of building a twin .60 2stroke powered floatplane and shutter at the thought of feeding them.
Live Long and Prosper
Hide Signatures
       Post #: 16
What Size Engine Would You Like To See In The "cd&... - 2/10/2003 11:28 PM
shupack
Score: 100
Last Login: 11/23/2009
Status: offline
I'd like to see something that could spin a 30" three blade or 4 blade (depending on the variant modeled) prop for a ziroli corsair and/or p-47. and definately gas, i hate the sticky mess, especially since you suggest running these a bit rich (which means even more mess.....
Aoccdrnig to a Cmabrigde Uinervtisy sudty, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tih
Hide Signatures
       Post #: 17
What Size Engine Would You Like To See In The "cd&... - 2/11/2003 12:04 AM
Chuckr53-RCU
Score: 100
Last Login: 3/22/2008
Status: offline
I like the idea of the .96. You might also want to make a .32 size to compete for the .20 2c sized planes (i.e. GP T-Craft or TT Slow Cub)
Hide Signatures
       Post #: 18
What Size Engine Would You Like To See In The "cd&... - 2/15/2003 8:33 AM
Bruce L Prater
Score: 100
Last Login: 2/4/2005
Status: offline
1.5-2.5, could be gas.
Hide Signatures
       Post #: 19
What Size Engine Would You Like To See In The "cd&... - 2/15/2003 2:53 PM
Merlin65
Score: 100
Status: offline
1.5 to 1.8 for me!
Let's get some scale props happening on the 1/5 scale warbirds.
Build in a cooling fan too please Otto.
Merlin
Hide Signatures
       Post #: 20
What Size Engine Would You Like To See In The "cd&... - 2/15/2003 7:45 PM
Damnathius
Score: 100
Status: offline
[QUOTE]Originally posted by Merlin65
1.5 to 1.8 for me!
Merlin
[/QUOTE]
I bet an SP series in those sizes would do just that. Might want to develope a 2.0 SP though to be sure. I'd be on one of those in a heartbeat, even if it was just going to sit on my engine shelf!
With the lack of decently priced scale prop spinning power and drives for large WWII warbirds, I bet RCV would do quite well in this department.
Hide Signatures
       Post #: 21
What Size Engine Would You Like To See In The "cd&... - 2/18/2003 9:58 PM
benzin
Score: 100
Last Login: 11/8/2004
Status: offline
I agree here for the big one because the only for the Warbird's they fits in a small cowl are Laser 180s, 240v, 300v.
The Saito 180 fit not so perfect and 200ti is expensive and heavy for his 33ccm.
YS 140 dz is a vibration and nitro killer so my choice for a 80" Warbird after long research was the Laser 240v to get the sound of a 4-stroker and plenty of pulling power.
So a 40 - 50ccm big single would be nice alternative for 80" and up planes.
Hide Signatures
       Post #: 22
More attention to weight - 2/19/2003 1:17 AM
wingspan99
Score: 100
Last Login: 8/28/2009
Status: offline
Otto I'd like to see the CD engines get lighter. How can Saito make a .72 that's lighter than the RCV .58? And Saito fit their .91 in the case of their .65 making it even lighter than the .65. I would like to see more attention paid to the weight of an engine. No matter what kind of airplane a person flies, having the highest power/weight is desirable. -Tom
Hide Signatures
       Post #: 23
What Size Engine Would You Like To See In The "cd&... - 2/19/2003 4:41 AM
Otto Kudrna
Score: 100
Status: offline
The reason why Saito is so light is because the Aluminum cylinder is Chromed, that is all, there is no hard metal sleeve like in the other makes of engine. It is what is known as AAC. the Rcv has a rotating Steal Cylinder for the valving. You sacrifice mass for size and efficiency. There will never be an engine which is as light as Saito. the RCV will always be in the hi end of the Mass spectrum. the decision must be made by you if you want a small engine which fits in a particular place, or a light engine which sticks out the side of the airplane.
Otto Kudrna RCV Tech Support
Hide Signatures
       Post #: 24
What Size Engine Would You Like To See In The "cd&... - 2/23/2003 4:28 AM
WorldModelNut
Score: 100
Last Login: 10/17/2009
Status: offline
I have been watching these RCV's with great interest, but the .58 size is to small for my needs. I vote for the development of a 2.5 or so. No competition in that area for a 4 stroke glow. More and more ARFS each year requiring that size to have good performance. You can't beat the sound over a gas burner!
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.563RCU1
