Lai Shing RC RTF ELECTRIC 4 ch ZERO
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> Lai Shing RC RTF ELECTRIC 4 ch ZERO
Page: [1]
Login
Lai Shing RC RTF ELECTRIC 4 ch ZERO - 2/1/2007 2:47:43 AM
ponchoyo
Status: offline
hi i've recently purchased a Lai Shing RC RTF ELECTRIC 4 ch ZERO from NITROPLANES.COM, It flys but it keeps on climbing until it stalls and then it falls. PLUS the Center of gravity is balanced. So i need to movedown the propeler shaft down by a couple degrees. IM wondering if im the only one with this problem! Can someone (STAFF) tell me how many degrees i should move the propeller down by?
Click to see fullsize image.
Click for fullsize
< Message edited by ponchoyo -- 2/5/2007 3:35:00 AM >
_____________________________
My ideas are better than yours!
       Post #: 1
RE: Lai Shing RC RTF ELECTRIC 4 ch ZERO - 2/1/2007 4:05:05 AM
opjose
Status: online
I do not have one of these, but....
Moving the shaft down is NOT the way to fix this. The position of the shaft has NO effect on climb... on these small electrics downthrust is not an issue either.
Either the C.G. is not correct or the incidence of the horizontal stabilizer is off.
Move the C.G. 1/2 Inche forward by adding weight to the nose, or shifting things around a bit. See if this improves the situation.
You may also want to trim out the zero point of the stab a bit first to see if this helps.
Build em'', fly em'', crash em'' and build more.
(in reply to ponchoyo)
       Post #: 2
RE: Lai Shing RC RTF ELECTRIC 4 ch ZERO - 2/5/2007 3:22:11 AM
ponchoyo
Status: offline
i'll try that
(in reply to opjose)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
