Ed Cregger
GA, USA Status: online
quote:
ORIGINAL: efish Thanks X Jet. I have to say that the Enya is about as good as any 2 stroke I've ever used. To be fair, there's nothing really I could objectively fault the engine on. In fact, most of my flying mates think it performs beautifully. But the reality is I'm not that good a flier and can't help but want to get things as good as I can. Tried the richer LSN today, and I think I'd have to agree with you - much prefer it with the LSN as lean as possible and the HSN rich; seems to work better at least for my setup. Could be personal preference too. As it happens, I bought a lightly used TT 46 Pro recently. Was debating between that and a Saito 56 to put in my next 3D plane. Can't say your comments have made my choice any easier .... Was wondering if I shouldn't have saved up for an OS 46AX instead of the TT but I guess each has its fans. As an aside, I have noticed that hovering is a lot easier with the HSN on the rich side. On a leaner setting, the plane becomes a little twitchy in the hover and is hard to get it to sit still. A few clicks rich, the smoke trail thickens and it becomes much better behaved. I was just wondering why. I don't think the engine is running lean since all these settings still produce smoke and the engine is running very much rich when tuned on the ground. ---------------- Forget that nonsense about "over revving" a conventional two-stroke (non SK). That doesn't happen in the real world - no valves to swallow. Sagging occurs because the timing is too far advanced for the load. One can richen the mixture a tad (which you don't like doing), back off a tad on the prop load, lower nitro (you're low enough now), lower compression OR change to a glow plug that runs a bit cooler in heat range. That would probably be the easiest thing to do. Also, a helicopter heatsinked cylinder head would be a help, if you can find one at a good price. When flying competition fun fly models my OS.32F-H never sagged out, like my competition's engines did. That heli cylinder head was well worth the extra weight it added. Thunder Tigers are good engines, but they are not in Enya's class at all, XJet. Ed Cregger
_____________________________
Artisan "Flying models since the Fifties - I'll get the hang of this yet!!!"
