rclynx
CA, USA Status: offline
No settings are set in stone guys. Some times the idle screw works better at 1 to 2mm instead of just 1mm. Choking on throttle up is usually to rich but then again you can't set the LSN till everything is good on the HSN. If you get set up with your HSN properly you very seldom need to move your LSN more than 1/2 turn one way or the other good luck guys and keep pluggin thats the only way to learn
_____________________________
Custom Cars bring out the stars / Home of the RCLYNX, RC IMPROVEMENT, MOD, SALES & SERVICE Dealer;XTM, CEN, HPI & much more
