TurboReg is not a fully redundant regulator
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Smart-Fly (Quest Engineering) Support Forum >> TurboReg is not a fully redundant regulator
Page: [1]
Login
TurboReg is not a fully redundant regulator - 2/3/2007 9:41:43 PM
Pashka_22
Status: offline
What does that mean?
       Post #: 1
RE: TurboReg is not a fully redundant regulator - 2/3/2007 10:51:24 PM
rrritchey
Status: offline
Hi,
It means that there are two regulation transistors but a single control circuit.
Let me know if you need more explanation.
_____________________________
Robert Ritchey
Owner, Smart-Fly
(in reply to Pashka_22)
       Post #: 2
RE: TurboReg is not a fully redundant regulator - 2/3/2007 11:03:10 PM
Pashka_22
Status: offline
Thank you very much for this quick explanation.
I have a few more questions:
1. If I run SF Ignition Cutoff switch, do I have to have switch between battery and Ignition Cutoff switch receiver unit?
2. You mention in previous posts that Power Expander can be run with 2 LiIon batteries, but without regulator. Will it be too much voltage for servos? And does Power Expander have bat share functionality build in?
(in reply to rrritchey)
       Post #: 3
RE: TurboReg is not a fully redundant regulator - 2/3/2007 11:23:19 PM
Pashka_22
Status: offline
Oh and one more:
If one of the regulation transistors will fail on TurboReg, is there indication of it? How I would know, after the flight, that SmartFly just saved my airplane?
       Post #: 4
RE: TurboReg is not a fully redundant regulator - 2/4/2007 5:38:41 PM
rrritchey
Status: offline
Hi,
Let me try to answer your questions.
1) It all depends on how you want to setup your system and how you maintain your system. I do not run a switch between the battery and the Ignition Cutoff but I have to unplug the battery from the Cutoff at the end of the day or it would ruin my battery if I left it connected too long. Some people do not like the inconvenience of disconnecting the battery and want a charge port in a switch so they run a DSC switch.
2) The PowerExpander can be run with Lithiums directly but the only servos I know of that can handle this are Hitec 5995s. If you are not running these then you need to a regulator in front of the PowerExpander. The PowerExpander does have the equivalent of a BatShare built in but it has a much lower voltage drop across it than the BatShare does.
3) There is no way to tell how a transistor will fail. If someone tells you there is they are mistaken. It can fail as a short or an open. They is now way to predict.
Let me know if you have any more questions.
Robert Ritchey
Owner, Smart-Fly
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.703RCU1
