Truck not going even at full throttle???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> Truck not going even at full throttle???
Page: [1]
Login
Truck not going even at full throttle??? - 2/4/2007 8:51 PM
kneeno
Score: 100
Last Login: 4/28/2007
Status: offline
Hi-
Now that I finally got my truck started I'm having a problem getting it moving. When I give the truck gas with the remote the engine is screaming like it wants to go, but is barely even rolling. After letting off and on the gas for a few minutes with no success I shut it off and thought I better get some advice. Help!! Mike
Hide Signatures
       Post #: 1
RE: Truck not going even at full throttle??? - 2/4/2007 10:16 PM
associatedelectric
Score: 100
Last Login: 5/3/2008
Status: offline
Make sure your slipper is tight. Are the gears moving when you give it gas?
Hide Signatures
(in reply to kneeno)
       Post #: 2
RE: Truck not going even at full throttle??? - 2/5/2007 12:25 AM
125cchyperman
Score: 100
Last Login: 11/19/2012
Status: offline
Yes make sure that the slipper is nice and tight also make sure if you have a ball diff that the diff screw is nice and tight also. If the diff screw is loose that will also caus this.
_____________________________
Go eat a grape there cowboy
Hide Signatures
(in reply to associatedelectric)
       Post #: 3
RE: Truck not going even at full throttle??? - 2/5/2007 12:34 AM
jdeadman
Score: 100
Last Login: 7/4/2012
Status: offline
Sounds like the throttle linkage is set improperly. Make sure that when you pull down on the trigger that the carb opens fully. If it does open fully then you may have it set way to rich
Try that first
Hide Signatures
(in reply to 125cchyperman)
       Post #: 4
RE: Truck not going even at full throttle??? - 2/5/2007 1:13 AM
littlebone
Score: 100
Last Login: 2/26/2008
Status: offline
u should check your slipper heres a good website for http://www.misbehavin-rc.com/pit-lane/slipper-adjustment/nr-slipper-adjustment.asp this can also help with other problems
Hide Signatures
(in reply to jdeadman)
       Post #: 5
RE: Truck not going even at full throttle??? - 2/5/2007 1:22 AM
CJ3B
Score: 100
Last Login: 2/21/2007
Status: offline
I concur with the slipper clutch adjustment issue...
Jorge
1950 M38 US ARMY Jeep
Hide Signatures
(in reply to littlebone)
       Post #: 6
RE: Truck not going even at full throttle??? - 2/5/2007 1:39 AM
46u
Score: 136
Last Login: 7/13/2012
Status: offline
More information would help like what truck and like some others asked when giving it throttle where does the turning stop? Yes could be the slipper or the clutch or a bad differential or strip gear in the transmission or a screw missing in a drive cup and so on. Yes the slipper is the frist thing to check.
Rebel Racing
Sponsored by Killer RC maker of great kill switches and more!
Hide Signatures
(in reply to CJ3B)
       Post #: 7
RE: Truck not going even at full throttle??? - 2/5/2007 7:00 AM
bte214
Score: 105
Last Login: 3/5/2011
Status: offline
It's a XXX-NT. Set the slipper. Tighen all the way then back of 1/4 to a 1/2 turn. Then tighten the differential. All the way tight then 1/8 out. My guess would be the diff.
Hide Signatures
(in reply to 46u)
       Post #: 8
RE: Truck not going even at full throttle??? - 3/12/2007 12:23 AM
kneeno
Score: 100
Status: offline
I tightened the slipper all the way, and attempted to find the differential screw to tighten it as suggested. However, the manual shows the screw with the drive shaft apart and I'm having a hard time finding the screw to check it. Any suggestions? Thanks!
Hide Signatures
(in reply to bte214)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.406RCU1
