davidgeorge212
AL, USA Status: offline
Hi, you inspired me to go with the same setup. I have all my servos in the same way you do and I am running pull pull on both elevator and rudder. I have a couple questions though. did you notice any of the wires rubbing against each other on your plane, becuase I am pretty sure mine are. Is it ok if they do rub or should I try to separate them? I have most of my wires running as straight as I could make them going back to the tail, but as for the top elevator cable I could not get it in a straight path, did you half to curve your top elevator cable in the tail so it would line up evenly as it exited out the tail fairing block? If so, I am assuming its ok to have a curve in the pull pull set up. Thanks, David G.
