Which RCV for VQ P51-D Warbird
Tower Hobbies
Logged in as Guest
  Printable Version
O.S. Engines O.S. BGX-1 3500 w/ BCM #4224 Pitt
Seller:  jmhernan
Details:   $200.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> Which RCV for VQ P51-D Warbird
Page: [1]
Login
Which RCV for VQ P51-D Warbird - 2/9/2007 11:41:12 PM
rajvirdee
Status: offline
VQ Warbirds are selling RCV engines as well now and I'm going for one.
The model I'm getting is the P51-D Mustang.
The specs are
Wingspan: 58.2 "
Fuselage: 46.8 "
Weight: ~ 5.9 - 6.4 lbs
Engine req: .40 - .46 (2 stroke), .70 (4 stroke)
I used to have a similar model with an OS 70 Surpass. I think the 58 size engine will be ok however I don't want it to be gutless in this model.
Please advise on what you think will be best
Raj
UK
       Post #: 1
RE: Which RCV for VQ P51-D Warbird - 2/15/2007 9:07:55 AM
RCV Engines
Status: offline
Hi Raj
Thanks for your enquiry. It's a tricky one as you definately don't want a gutless Mustang.
The RCV58CD will certainly power a 6lb model and I am sure this would be suitable. Check out our user gallery and there is a couple of 6 - 6.4lb mustangs flying successfully.
http://www.rcvengines.com/gallery/rcv_gallery_58cd.htm
http://www.rcvengines.com/gallery/rcv58cd_p51mustang.htm
The RCV58CD is not as an OS70 though, so if you like to have even more power then you could always consider the RCV91CD which is the height of a 52 4-stroke (so still smaller than a conventional .70) and will have masses of power.
I hope this helps
Best regards
Laurenne
_____________________________
Technical Support
RCV Engines - UK
(in reply to rajvirdee)
       Post #: 2
RE: Which RCV for VQ P51-D Warbird - 2/16/2007 7:07:37 PM
rajvirdee
Status: offline
thank you - would you know what the best prop is for this combination (or where I should start !)
Regards
Raj
(in reply to RCV Engines)
       Post #: 3
RE: Which RCV for VQ P51-D Warbird - 2/19/2007 8:20:03 AM
RCV Engines
Status: offline
Hi
A good starting point for props sizes are:
58CD - 12x6
91CD - 14x6
I hope this helps
Best regards
Laurenne
Technical Support
RCV Engines - UK
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
