marwen1
Joined: 3/25/2004 From: WINNIPEGMB, CANADA Status: offline
Strykass GREAT IDEA about the pipe I am still waiting for a 1" offset and a tuned pipe from MORRIS HOBBIES My ROSSI .61 is bored out to a .81cc ad was last used for a BYRON FAN setup I bought a glass 3 blade PUSHER PROP 14/7 a couple of weeks ago. That'll do to help me get this thing toollin' around the runway. I think I want go with a wooden replaceable blade setup from ZINGER. At hi speeds, that glass prop just might explode. The light bulb you saw wasn't a strobe but a 12V HALOGEN bulb. One on top of both rudders. The plugin I made is pretty generic and it wants to fall out at the drop of a hat. Look like I'll have to drop some adhesive on it at permanent plugin time. It is SO-o-o-o-o- BRIGHT, youu can see the damn thing at ANY distance -- day or nite! I've hooked up a micro switch on top of the servo with velcro to turn on/off -- I want to use as a LANDING LITE setup. Darn, I still like that idea of putting the pipe in the middle of the bay and out the bottom. Some years ago, I had the same plane (36"WS) Of course all the exhast goes out all over the one side of the plane. I took the muffler off and installed a couple of hoses going right down thru the body oif the plane -- exiting straight down onto the ground. Worked like a charm. I started to do the actual MONOKOTE to the (I'm calling it the FORCE 1-60) acual body last night. Started with the inside of the prop cutout. Really time consuming stuff down there. more later marwen1
_____________________________
Definition of COMPLIMENT: Sometimes a matter of FACT -- More than not, a matter of TACT!
