YS80 won't settle into idle
Tower Hobbies
Logged in as Guest
  Printable Version
Saito FA-180 GK
Seller:  RCadmin
Details:   $375.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> YS80 won't settle into idle
Page: [1]
Login
YS80 won't settle into idle - 2/7/2003 6:25:52 PM
psawya
Status: offline
I have a Raptor with YS80, SB15 and a GV-1, I am running 8.45 to 1 for a gear ratio, TT680 carbon main blades at 1750 rotor rpm on 15% Cosmo fuel 23% synthetic oil. The problem is that when I try to bring the engine down from operating speeds it won't settle into a solid idle, it wants to overspeed. It gets the definite ping ping going as if it is too lean. My needles are currently Low 2 turns, Hover 1.25 turns and High is just shy of 1 turn. My hover and top performance is outstanding, it will maintain a constant rotor rpm at full stick, never bogs. Hover is smooth and steady, with a solid smoke trail. I have removed the carb and cleaned it. Tried an Enya #3 and #4 plug.
Any ideas?
Pete
_____________________________
Flyin' the ROK
       Post #: 1
YS80 won't settle into idle - 2/8/2003 9:14:37 AM
jmercer52
Status: offline
Sounds to me like it's still too lean on the low speed needle. Remember to that after adjusting the low speed needle, you will need to readjust the mid and high speed needles again. The low speed needle will affect the other needles.
Suptter
Who Said Maturity Comes With Age?
(in reply to psawya)
       Post #: 2
YS80 won't settle into idle - 2/14/2003 3:42:34 PM
psawya
Status: offline
Well, I finally got it after another gallon. I took the engine out yet again and completely disassembled it and cleaned everything. There must have been something lodged in the low speed needle path. And I went back to the Enya #3 plug.
It runs very cool, plenty rich, with this 28% oil fuel it has LOTS of smoke. I can run a half tank through it doing FFF and aerobatics after landing I can put my finger on the cylinder for a good 20 seconds without it feeling hot.
My needles end up at Low (just flush), Hover 1.25 and High .75 turns. Seems rich at these settings but is making good power and it's running cool.
Pete
Flyin' the ROK
       Post #: 3
YS80 won't settle into idle - 2/15/2003 7:12:52 AM
Geistware
Status: offline
Try to increase the regulator pressure.
Visit our site for YS information!
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU1
