spOon2410
BC, CANADA Status: offline
Ok yea it was the 1/16, didnt seem to fit at first, but i think thats because it has the black paint on it. Anyways, i got the shaft out and bent it back to the best of my abilities...The one from the CNC head was a lot harder to bend than the stock one. So I put it back on, and span up without blades, little vibration/movement, then with blades, and it all seemed good. I tried flying outside, but it was acting all weird, pitch, cyclic, everything! I tried to land and tipped over slightly, hitting the blades on the ground, with minor damage though. After inspecting the head to see if it was alright (i thought the gyro caused the problem at first, because I fiddled with the settings) , I noticed that the two tiny 1.2mm head silver bolts that hold on the silver pentagon-shaped part near the top of the main shaft were GONE! I had a look for them inside (where i span it up first) and outside, but so far haven't found them. I left them in the head loosely when I took it off, and just forgot to tighten them before i flew. The bolt that holds the flybar from spinning is the same size, so I took one of those out and put it in the missing spot. Do you think it will be alright to fly with one of the bolts missing from both the flybar, and the silver piece? I have the bolts done in pretty tight. I also looked through all my screws for something that might fit, but couldnt find anything. I might just have to order: http://www.cnchelicopter.com/servlet/the-CNC-300-helicopter-V2/searchpath/8098/start/17/total/26/Categories unless i could find something at my LHS.
_____________________________
spOon.
