gjsinke
[QUOTE]We included 3mm pivot balls instead of two 2mm, so he tried to tap them himself to 3mm[/QUOTE] WHO screwed up? [QUOTE]If this was a manufacturing defect or our screw up we would have no problem replacing the item in question, but it is not, this is someone who has a used helicopter with an unknown number of flights on it[/QUOTE] You have determined it is NOT a manufacturing defect...based on what? Here's an exerpt from the add, here on RCU, from the seller, who, BTW, has defended HHI outside this thread. But I suppose even your good customers 'might' lie. [QUOTE]Heli hovered 4 times never crashed [/QUOTE] [QUOTE]This heli package is only 2 months old and is in mint like new condition. [/QUOTE] If your policy is to warrant only to the original purchaser...then so be it...that's all you had to say. But to focus on 'not my fault' probabilities without any evidence, well, that just profiles your character. No one here has asked for carte blance never ending warranty policy. [QUOTE]As for an olive branch, he said that in fact this was just a test in the first place, no bearing is going to fix this. [/QUOTE] More than once through this thread, i have tried to keep the door open for you to communicate your position in respect to knowing there are always two sides to the story. I only mentioned the 'test' after the fact...not in the first place. This indeed was intended as another opportunity for you to explain your customer service policy. You were not set up to fall in a trap...you did it all on your own. [QUOTE]We have had people in the past send whole helis back, clutch assemblies, motor stacks and we looked at them, gave our opinion, and when need be fixed what needed it. [/QUOTE] You mean I'm not the Lone Ranger here with a few bearings that are destined to cause failure in time and possibly take out the other $2000.00 worth of stuff on this bird? I don't think so. If anything here Jon, I'm sure you guys aren't all bad, but maybe the lesson should be yours to learn. It might be time to look in the mirror and see how you are treating your customers. ALL of them. Sincerely, Jim
