NitroModel Low-Wing Trainer 60 - 71"
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> NitroModel Low-Wing Trainer 60 - 71"
Page: [1]
Login
NitroModel Low-Wing Trainer 60 - 71" - 2/13/2007 12:56:50 AM
sw1241
Status: offline
NitroModel Low-Wing Super Aerobatic Trainer 60 - 71" Nitro Gas Radio Remote Controlled Airplane, can any body tell me what air foil this one has? Flat bottom or semi? thanks in advnce
sw1241
_____________________________
I Buy I Build I Fly I Crash
I Buy I build I Fly I Crash
       Post #: 1
RE: NitroModel Low-Wing Trainer 60 - 71" - 2/19/2007 11:17:02 PM
nitrostaff1
Status: offline
Semi airfoil
Nitro Planes
--===www.nitroplanes.com===----
(in reply to sw1241)
       Post #: 2
RE: NitroModel Low-Wing Trainer 60 - 71" - 12/18/2007 4:29:13 AM
sw1241
Status: offline
sw1241 Date 2/13/2007 12:56:50 AM
sw1241
Date 2/19/2007 11:17:02 PM
Semi airfoil
Nitro Planes
So because of this post where nitro staff said that the super low wing trainer was a semi airfoil, my darling bride ordered for me for xmas, guess what, instead of a 71 inch semi,its a 69.5 flat bottom Explorer 60 L
Nitro staff, can i return this plane or can you exchange it for what i wanted?
(in reply to nitrostaff1)
       Post #: 3
RE: NitroModel Low-Wing Trainer 60 - 71" - 12/19/2007 6:41:38 PM
Mr67Stang
Status: offline
quote:
ORIGINAL: sw1241
sw1241
If you go to the NP web site and look at the specs on this plane it clearly says "flat bottom" airfoil. A fact that the company rep is apparently unaware of. The specs also say it is a 71 in wing or 1800 mm which converts to 70.87 in. if the wing has dihedral it can easilly be that you are measuring the wing from tip to tip (as I would too) and they are measuring each panel and multiplying by two. Below are the specs as copied from the NP web site.
http://www.nitroplanes.com/nilosuaetr60.html
quote:
Wing span: 71 in / 1800mm
Wing area: 900sq in / 58.1 sq dm
Flying weight: 7.2lb / 3300g
Fuselage length: 55 in / 1420mm
Airfoil: Flat Bottom
Engine Required: 2c 0.61 cu in
Radio Required: 4channels, 4servos
He who dies with the most toys wins!
       Post #: 4
RE: NitroModel Low-Wing Trainer 60 - 71" - 12/19/2007 8:50:31 PM
sw1241
Status: offline
#1 Stang, you are right, all the times I have looked at that page, I never noticed the "flat bottom" note, I really need to get my eyes checked, I did however measure the wing panels on the top side they are 34 1/2 inches exact, each. thaks again for pointing out my short sightedness.
Merry Xmas to all
(in reply to Mr67Stang)
       Post #: 5
RE: NitroModel Low-Wing Trainer 60 - 71" - 2/18/2008 2:24:10 PM
pjwright
Status: offline
I just received this model also ... something to bang around while building "real" models. The wingspan is less than advertised, and is indeed flat-bottomed. Bizarre that NP's own rep answered the question incorrectly.
The "Explorer" comes with no fuel-proofing in the engine compartment (raw exposed plywood) - I primed and painted with Lusterkote. The joint where the wing leading edge meets the fuselage also has exposed plywood. I fabricated a balsa fairing and glued it to the wing bottom to close this gap (see photo). Covering match is Monokote Sapphire Blue.
I also reinforced the wing joint with 9 oz. fiberglass, and replaced the under-sized steel wingbolts with 1/4-20 nylon and new blind nuts.
When I e-mailed NP about the correct iron temp to get rid of the hundred or so bubbles in the covering film, I was told "this problem had never appeared before" so they didn't know.
Hoo boy!
PJ
Click to see fullsize image.
Click for fullsize
       Post #: 6
RE: NitroModel Low-Wing Trainer 60 - 71" - 2/18/2008 8:04:12 PM
opjose
Status: offline
quote:
ORIGINAL: pjwright
Hoo boy!
PJ
I answered this on the other thread you started.
Build em'', fly em'', crash em'' and build more.
(in reply to pjwright)
       Post #: 7
RE: NitroModel Low-Wing Trainer 60 - 71" - 2/18/2008 8:06:01 PM
opjose
Status: offline
quote:
ORIGINAL: Mr67Stang
Yeah this is quite common. The measurements are crudely rounded.
I've had one or two wings turn out to be slightly bigger than stated, and a few slightly smaller.
I'm not going to worry about that .13" difference though.
       Post #: 8
RE: NitroModel Low-Wing Trainer 60 - 71" - 2/18/2008 8:16:26 PM
opjose
Status: offline
quote:
ORIGINAL: Mr67Stang
Maybe it's a "semi flat bottom airfoil" ?
The edges of the wing in the picture have enough shadow, that it seems that the edges are off the surface by a bit.
In lieu of more accurate descriptions I wish there were more detailed photos on the web site.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.770RCU1
