Need help with a warped / bent aileron.
Tower Hobbies
Logged in as Guest
  Printable Version
Fly Eagle F-15 ARF w/ L/G system - ARF
Seller:  mikedenilin
Details:   $1,100.00   |  8/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> Need help with a warped / bent aileron.
Page: [1]
Login
Need help with a warped / bent aileron. - 2/13/2007 9:08:53 PM
zoott
Status: offline
Hi I just brought home a mini pulse xt. The left aileron is warped. It doesn't seem to be twisted. It looks like it is just bent up on the inboard end of the aileron. When I try to set it neutral ,the bent part is higher than the adjacent part where it meets the wing. I guess this is better than if it was the outboard tip.
Is there anyway to fix this without removing the aileron or covering?
I need all suggestions or tips.
       Post #: 1
RE: Need help with a warped / bent aileron. - 2/13/2007 11:30:51 PM
ram3500-RCU
Status: offline
Couple things you can do. You can heat the side on the back side of the bow, while bending it that way. Tightening the covering on that side will often fix the problem. I bought a mini Yak that had a warped wing that needed this treatment. I used a heat gun on that because it was a larger area, and I could hold it between my legs while I twisted it. Smaller parts are a little harder to do with only two hands, I assume like most people, you only have two. Cheers. You can doooo it.
(in reply to zoott)
       Post #: 2
RE: Need help with a warped / bent aileron. - 2/14/2007 5:12:11 AM
SooprDink
Status: offline
Ditto what Ram3500 said....That method has worked for me as well. You may want to look into getting another set of arms surgically attached for this job. They can do all kinds of stuff with modern medicine...you may even start a new fad
(in reply to ram3500-RCU)
       Post #: 3
RE: Need help with a warped / bent aileron. - 2/14/2007 1:00:59 PM
MinnFlyer
Status: offline
Another ditto
Carefully bend it in the opposite direction while holding it over your heat gun (Wear heavy gloves)
_____________________________
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
(in reply to SooprDink)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.516RCU1
