RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER.
Page: <<   < prev  1 [2] 3 4 5 6   next >   >>
Login
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 7/6/2007 7:22:52 PM
3d Marky
Status: offline
You may have the MK1 version which had known issues with voltage stability. I spoke to a reseller in the UK that had a number of returns with the Mk1. Now he is selling the MK2's and has had no further problems.
LiPoly's should be charged to within 1% of each cells total voltage. If your charger is not doing this then there is a problem.
I recently got a Mk2 601 ( were available from mid March 2007) and i am currently testing it against the Mk1. The voltage of LiPoly's tested to date have been within 1% of each other.
(in reply to Niek)
       Post #: 26
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 7/6/2007 8:11:15 PM
Niek
Status: offline
Aha,
I've send mine back to rvmhop in HK
(in reply to 3d Marky)
       Post #: 27
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 7/17/2007 9:53:08 PM
samuelx
Status: offline
This charger is CRAP. I have 2. 601BC chargers.....Had 2. 601 BC chargers. First one broke in first day When I was Charging 5s1p 2000mah lipo in 2A current. Smoke was coming inside of the charger after second charge.
Second charger broke after 4. cycles when I was charging same kind of pack.
_____________________________
http://www.f3d.fi
Revver bro #170
(in reply to Niek)
       Post #: 28
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 7/18/2007 12:02:47 AM
samuelx
Status: offline
quote:
ORIGINAL: jvictorfc
Thanx GOD, you sent someone to help me! KKkK...
Friend, I haven't used my charger since I burned those IC, It's working like I said but without balance function. It's not funny, I read about your problem and I have some problem with my charger, when I'm charging in normal mode, without balance the Discharge goes down, until it charge everything. But it's faster than when it's charging and balancing. Those charger are very strange, have you tried to see the current potency on each cell if is really ballancing, I've tried many times when the balance function was working well but It was always unbalanced. So strange, here is good because we can exchange experiences like that. So, the picture is there and those IC's marked with red square are burned, I can change those if I have their reference but after burned I can't see. Please save my charger helping me. To open the charger is very easy you just need get of the screws beside and of the fan and a trick is get of also those blue pins wich we choose the function, get of then with the pliers. Please write all specification. I'll be very pleased if you can help me. Thanx a LOT!
IC= 4407
Manufacturer logo is AP or something like that
I am trying to find parts olso for my broken chargers...
< Message edited by samuelx -- 7/18/2007 12:07:34 AM >
http://www.f3d.fi
Revver bro #170
(in reply to jvictorfc)
       Post #: 29
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 7/30/2007 12:40:56 PM
Fade2Gray
Status: offline
Hi Everyone,
I just purchased this charger unit and are currently charging and discharging 2x IB4200 mAh battery packs using a Y series connector.
Seems to work ok, pity about the fan noise, l wish there was some way that the fan would automatically switch off once the batteries have reached their charge.
I have a question and was hoping someone could shed some light on my recharging problem. When l fully charge the battery packs, a day later just before l go off to race my boat (Super Vee 27) I recharge the same battery packs so they are fully charged to the optimum level. The problem is that 2nd time round this charger takes a long time to charge the battery packs (over 2 hours @ 1.5amp) - I would have thought that the second time round that it would not take this amount of time to charge up, especially as l have fully charged them the day before.
Has anyone else experienced this problem?
BTW: Does anyone have the link please for the Log View program? I can't find it anywhere.
Thanks in advance.
       Post #: 30
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 7/30/2007 6:59:19 PM
cmavr8
Status: offline
1. Fan noise: I hate it! I might mod it later and put a more silent fan...
2. I think I read somewhere "do not try to recharge an already charged battery". It should automatically detect it's charged, so why do they say that???
3. Looking for the program? Don't you have a cd?
Chris M.
(in reply to Fade2Gray)
       Post #: 31
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 7/31/2007 12:24:01 AM
Fade2Gray
Status: offline
Hi cmavr8,
The CD did come with the charger, however it is not the Log View program but some useless program that doesn't work - Does anyone have a copy of Log View program that they could upload somewhere for us please?
I would have thought with this charger that it would automatically detect the amount of voltage and only charge up to remaining amount required - At the moment it doesn't do this in which the charger treats the battery packs as new packs.
Do you charge two packs at the same time? I might try charging one pack at a time to see if that makes any difference.
Oh... that noisy fan, the wife complains about this constantly.
(in reply to cmavr8)
       Post #: 32
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/1/2007 1:11:46 AM
3d Marky
Status: offline
Charging two packs together is not advisable. The charger was not designed for this purpose. To charge multiple packs you should purchase a dual output charger. Try charging one pack at a time and I think your problems will cease.
The fan noise issue was a problem on the MK1's. A simple fix is to add a resistor in the + or - lead to the fan so reducing its speed. That’s all they did on the MK2's to silence it.
To answer why the fan does not switch off after charging... This is because you probably have the unit set for trickle charge. Disable Trickle function and the fan will stop once the charge is complete.
Hope that helps.
       Post #: 33
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/1/2007 2:47:53 AM
Fade2Gray
Status: offline
Excellent advice, l will try that...
BTW: Do you know the value the of resistor to attach to fan?
       Post #: 34
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/1/2007 10:42:47 PM
3d Marky
Status: offline
A fairly low value in the region of 50 ohms should do the trick however I would experiment. Let your wife be the judge
Fan should run nice and quiet at around 6-8 volts.
       Post #: 35
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/3/2007 11:12:01 PM
lk808
Status: offline
601BC manual (Acrobat format) available here.
< Message edited by lk808 -- 8/3/2007 11:22:43 PM >
       Post #: 36
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/6/2007 6:49:24 AM
Fade2Gray
Status: offline
Does anyone know the style of Lipo balance charge connectors used for this charger unit? I have noticed that there appears to be a couple of differecne TP connectors on some brands of Lipo batteries and knowing my luck, l will go out the purchase my first Lipo battery only to discover that it will not connect onto BC601 Lipo balancing conector.
Thanks again in advance.
(in reply to lk808)
       Post #: 37
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/6/2007 3:45:27 PM
jvictorfc
Status: offline
I don´t know about it, see if TP ballancer conector is similar to Hi model, if yes, it´s compatible! Anyway if is different you can switch the wires in the connector.
       Post #: 38
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/9/2007 4:05:13 AM
trackdog
Status: offline
I have seen different variations of this charger. Some say 80w circuit and have a black case, the blue ones say 50w circuit and have blue case. Also some seem to come with temp senor while others dont. Could someone clarify which one is the mosto date and how to use the temp sensor?
       Post #: 39
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/10/2007 6:39:28 AM
lk808
Status: offline
I received one of the blue "V2" units off eBay yesterday and it didn't include a temp sensor. I've also seen mention and pictures of the temp sensor, however there is no connector for it on the charger as there is on the Bantam charger. The 601BC's firmware lets you turn on/off the temperature cutoff and setpoint, but the external temp always reads 0C during operation. The manual mentions 801BC in at least one place, so I suspect that the 80W rating of the 801BC also got mixed in by accident.
Here's what I've noticed of my 601BC so far:
- When using the coax power input, the black input clip is automatically disconnected, however the red clip is live so be careful not to let it touch the metal case of anything that is grounded. The coax input is center positive. If I decide to keep this unit and void the warranty, I will probably desolder the wires from the unit and put a coax plug on the desoldered ends.
- The Inc button didn't work very well and requires a harder push or multiple pushes. I turned on the button confirmation beep to help. I can't tell if it's poor quality switches, poor button debouncing, the loose nut behind the button ;-), or a combination of these.
- There's a red LED inside the case and somewhere near the Start button. It blinks from time to time but it is somewhat difficult to see. The buttons are blue and somewhat translucent, so the red light isn't conveyed very well.
- The right side panel wasn't assembled correctly. The red banana jack was soldered at a slight angle and the assembler couldn't get it to go on flush, so s/he tightened the screws anyhow. There was a slight gap allowing the backlight to shine through which was annoying. I loosened the screws and realigned the panel.
- The CD contains Silabs CP210x v4.2 drivers and the monitoring software (interestingly, in a folder called "e-station" . I tried to download and install the WHQL-certified v5 drivers from silabs.com but the Silabs installer was unable to install on my system, so I used the CD drivers. It works on XP Pro. I can view various graphs as well as the charger settings.
I've been cycling various 7- and 8-cell Sub-C NiMH and NiCd packs, mostly new. I haven't tried charging lithium batteries yet. Here's what I've noticed:
- During charging and discharging, the charger starts at a high rate (but not necessarily the rate that I select) and gradually tapers down as it nears the end point. I've selected 2A discharge and the highest rate I've seen on the display is 1.3A discharge. The packs were partially charged, so I suspect that it starts at the rate specified for a particular state of charge.
- The case gets pretty hot during discharge. It has stayed cool during charges up to 3A. Although there is a finned heatsink on top of the case, it is interesting that the FETs contact the bottom panel and the power resistors don't contact the case and rely on the wimpy fan for air cooling.
- During charging, the current and fan will stop and start repeatedly. I haven't noticed a definite pattern, but during the first charge I thought I had a defective unit. I assume that it is trying to determine how full the battery is.
During the last 4 charge cycles, the charger reported Connection Break just as it neared the end of charge. This happened on 3 different packs and always towards the end. I'm using the alligator clips on wire leads to a Tamiya connector. I just reclipped the leads and I'm testing again to see if it was a bad connection.
(in reply to trackdog
