RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER.
Page: <<   < prev  1 2 [3] 4 5 6   next >   >>
Login
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/15/2007 12:37:17 PM
jvictorfc
Status: offline
I found this information just on the internet, I've looked everywhere in my city around but without success. Have you found in somewhere there in Greece?
(in reply to cmavr8)
       Post #: 51
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/15/2007 1:04:00 PM
cmavr8
Status: offline
Haven't looked, but I think the large microchip companies like microchip and maxim give out samples for free. Actually I had a chip delivered to me for free in the past...
EDIT: here: http://sample.microchip.com/Default.aspx?testCookies=true
_____________________________
Chris M.
(in reply to jvictorfc)
       Post #: 52
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/17/2007 12:33:45 AM
3d Marky
Status: offline
quote:
ORIGINAL: lk808
I received one of the blue "V2" units off eBay yesterday and it didn't include a temp sensor. I've also seen mention and pictures of the temp sensor, however there is no connector for it on the charger as there is on the Bantam charger. The 601BC's firmware lets you turn on/off the temperature cutoff and setpoint, but the external temp always reads 0C during operation. The manual mentions 801BC in at least one place, so I suspect that the 80W rating of the 801BC also got mixed in by accident.
Here's what I've noticed of my 601BC so far:
- When using the coax power input, the black input clip is automatically disconnected, however the red clip is live so be careful not to let it touch the metal case of anything that is grounded. The coax input is center positive. If I decide to keep this unit and void the warranty, I will probably desolder the wires from the unit and put a coax plug on the desoldered ends.
- The Inc button didn't work very well and requires a harder push or multiple pushes. I turned on the button confirmation beep to help. I can't tell if it's poor quality switches, poor button debouncing, the loose nut behind the button ;-), or a combination of these.
- There's a red LED inside the case and somewhere near the Start button. It blinks from time to time but it is somewhat difficult to see. The buttons are blue and somewhat translucent, so the red light isn't conveyed very well.
- The right side panel wasn't assembled correctly. The red banana jack was soldered at a slight angle and the assembler couldn't get it to go on flush, so s/he tightened the screws anyhow. There was a slight gap allowing the backlight to shine through which was annoying. I loosened the screws and realigned the panel.
- The CD contains Silabs CP210x v4.2 drivers and the monitoring software (interestingly, in a folder called "e-station" . I tried to download and install the WHQL-certified v5 drivers from silabs.com but the Silabs installer was unable to install on my system, so I used the CD drivers. It works on XP Pro. I can view various graphs as well as the charger settings.
I've been cycling various 7- and 8-cell Sub-C NiMH and NiCd packs, mostly new. I haven't tried charging lithium batteries yet. Here's what I've noticed:
- During charging and discharging, the charger starts at a high rate (but not necessarily the rate that I select) and gradually tapers down as it nears the end point. I've selected 2A discharge and the highest rate I've seen on the display is 1.3A discharge. The packs were partially charged, so I suspect that it starts at the rate specified for a particular state of charge.
- The case gets pretty hot during discharge. It has stayed cool during charges up to 3A. Although there is a finned heatsink on top of the case, it is interesting that the FETs contact the bottom panel and the power resistors don't contact the case and rely on the wimpy fan for air cooling.
- During charging, the current and fan will stop and start repeatedly. I haven't noticed a definite pattern, but during the first charge I thought I had a defective unit. I assume that it is trying to determine how full the battery is.
During the last 4 charge cycles, the charger reported Connection Break just as it neared the end of charge. This happened on 3 different packs and always towards the end. I'm using the alligator clips on wire leads to a Tamiya connector. I just reclipped the leads and I'm testing again to see if it was a bad connection.
These chargers seem to be a bit of a lottery.
Some seem to work ok, others are totally unreliable. The units are probably blown together in china for under $10 and the quality control is just not there.
It's a shame really as this charger is very well specified and would be a market leader if a few issues were addessed.
There are no other chargers on the market that have all these functions as well as balancing in one small field unit.
My mkII is still working at the moment with only a few occasional glitches however I always get the feeling I can't trust it. I certainly wouldn't go out and leave it unattended.
I can do this with my Pro peak constellation charger as it has never incorrectly charged a pack in over 300 cycles.
Balancing a 3 cell LiPo on my BC601 slightly overcharges the pack at 12.66V on average. (4.22v per cell) This equates to about 0.5% overcharge which is still within the normal 1% tolerance.
There is no temp sensor on this model.
The fan will switch off approx every 2mins as the charger stops to measure battery voltage drop during charge.
The led on the circuit board will also flash if you connect a battery to the output of the charger without a power feed connected. It appears to monitor some sort of process during the beginning of the charge cycle and switches off a few mins afterwards. This was not present on the mkI models.
(in reply to lk808)
       Post #: 53
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/17/2007 4:28:18 AM
Jeff_Green
Status: offline
If I had found this thread sooner I wouldn't have purchased this charger. I would have gone for one of the mid range BANTAM e-stations they have all if not more of the functions that the 601BC has. I think they use the same charging processor.
(in reply to 3d Marky)
       Post #: 54
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/17/2007 12:03:26 PM
3d Marky
Status: offline
This charger is really a copy of the Bantams with the e station 6 being close to the amount of functions offered on the 601. As you rightly said I also believe they share the same charging processor. The bantam probably uses higher quality additional components and has better QC.
(in reply to Jeff_Green)
       Post #: 55
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/17/2007 5:29:04 PM
jvictorfc
Status: offline
Friend, If is possible could you see if they send for free those IC's which we have talked about. Please just if is possible. I couldn't understand the website. Thx a lot.
       Post #: 56
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/18/2007 3:30:13 PM
cmavr8
Status: offline
quote:
ORIGINAL: Jeff_Green
I would definitely say they are mosfet's on the board all the gates drains and sources are connected but the part number is AP 4407. any 4407 mosfet should work. Having the same case will make it easer but it is not a must just get the g d s right. good luck.
Jeff (or anyone) could you give us more info on the 4407 chip?
We're searching for a sample but I don't know in which category to search...
Thanks!
Chris M.
       Post #: 57
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/18/2007 3:44:14 PM
Jeff_Green
Status: offline
here is a 4407 that has the same foot print as the one in the charger. this chip is a pnp power mosfet here is a data sheet for it. link
       Post #: 58
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/19/2007 6:26:19 AM
albx
Status: offline
Hi, I just recieved mine. It's the black version, I don't know why, but when i ordered it on ebay was a classic blue version. Tested charging a Pb 12V 7,5 A battery, it was ok, just stopped at the 5A limit. Charged a LiPo 800ma 2 cells, and the final charging was 3,80 for each element. Tried with NiMh, 1A max current, and what I don't understand is why it do this: begin to charge at 1A, then go down to 0A for 1 or 2 sec, then the current rise again for 2 minutes to 1A, then go down do 0A.. and so on.It's not random, the time elapsed from 1A to 0A is always the same.I would like to know if all those chargers do the same or mine have some problems? Is something to change in the setup? Thanks
       Post #: 59
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/19/2007 4:54:45 PM
Jeff_Green
Status: offline
My charger will do the same thing I think it is checking the voltage of the battery. l have had problems with it detecting the peak charge point of NiMh batteries. Make shore you have your safety settings set correctly.
(in reply to albx)
       Post #: 60
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/20/2007 1:48:52 PM
Zodrak
Status: offline
Hi,
Mine works with lipos ok but doesen't stop on delta peak on NiMh or NiCD batteries . This is the second one. The first one got on fire (lots of smoke) after the third charge.
Any sugestion for the delta peak problem ?
       Post #: 61
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/20/2007 4:39:32 PM
albx
Status: offline
Have you tried changing in the setup the NiCd and NiMh sensitivity? I use 10mV for NiCd and 7mV for NiMh, it works ok. Does your the same stop and start of the fan (for just about 2 sec.) during the NiMh or NiCd charging process?
(in reply to Zodrak)
       Post #: 62
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/21/2007 2:11:19 AM
unan
Status: offline
hi guys!
Im really having hard time to decide what charger to buy, i was planning to buy the x-power 601 untill fortunately i learned a lot from you guys about the charger. is it now practical to buy if its the new version now? i found it on RC-ypin on ebay. Im trying not to waste my money for a crappy charger coz of my budget issues, i just really need something to use ( or will the bantam would do better? ) where can i buy it if ever? thanks a lot in advance!!!!
(in reply to albx)
       Post #: 63
RE: RC-POWER 601BC BALANCE CHARGER/DISCHARGER. - 8/21/2007 2:28:59 AM
Jeff_Green
