Jims123
Joined: 9/7/2007 From: San Diego, CA, USA Status: offline
Hi All you Battery Charging Gurus, This is my 1st ever post on this RC Universe site.. What a great website.. Wish I had found this forum before taking the plunge.. have just skimmed thru these threads, Great Info.. Thanks! Couple really easy .. simpleton questions: I'm a nubie getting back into RC Sailplanes after years of non flying, I'd never heard of LiPo's.. and I bought this blue RC Power 601BC from a Hong Kong outfit assuming as i read the cryptic ad, that it would allow me to charge up to 14 of my current +8.4v 7XAAA 800 mAh NiMH batterys at once. Ha- Fat Chance.. I see now that the 601BC only charges one battery at a time, and I have also ordered a plane that has a Turborix 11.1v 12c 1300mAh 3Cell Rechargeable Lipo Battery...so want to use it for balancing later.. I guess that's why there are two connectors on LiPo batterys.. .. one with multi-pins to monitor the cells, and the other to feed the Motor and Receiver /servos right?.. Moreover, I see the 601BC has no DC or AC Input Power Adapter to feed it.. (or temp Probe) any tips on how to best feed the 601BC power Input so i can do two things.. Deep discharge, and then re-charge my NiMH Batteries.. in multiple cycles at Home plugged into an 110VAC source like a PC Power Supply's CD-ROM or HD drive DC connector.. can i hopefully connect a battery and walk away from it while it cycles .. How hot is too Hot while charging a NiMH , or a LiPo? or out in the field .. clipped onto my +12vdc Car Battery via Extension / Jumper cable or some other pre-charged up LeadAcid? battery i guess I'd lug around to get it near my home PC if its needed ? Is there recommended battery I can hike around up a hills and recharge with? or is buying the second LiPo and pre-charging it at home far better? And a final question.. I installed the USB driver s/w but was not sure if the 601BC needs DC INput Power available& ON and connected BEFORE I plug in the USB connector at the computer (so I didn't yet) .. or will the 601 interface run stand alone with a USB Input alone and still light up the LCD Panel and work (with nothing loading the DC Charge output ? The manual is so bad i really cant understand most of it.. and i don't think it addresses these fundamental questions at all.. Thanks In advance.. JimS
