DarZeelon
Joined: 4/9/2003 From: Rosh-Ha'Ayin, ISRAEL Status: offline
quote:
ORIGINAL: Hobbsy I dunno about that, common sense says a higher pitch presents a larger load and therefore more heat not less. Since heat is energy that is always trying to distribute itself evenly among any medium and air is a lousy heat conductor compared to an aluminum engine, changes in airflow velocity or volume aren't going to make big changes in engine temp, just like Brian discovered. Dave, You seem to have things a bit confused... Pitch and diameter are trade-offs. For a prop with given diameter and pitch numbers, there are other props of the same basic design, with the same load; that have either a larger diameter and a smaller pitch, or a smaller diameter and a larger pitch. If you take 10" diameter props, of course the 8" pitch prop will burden the engine more than the 6" pitch; and surely more than the 4" pitch, still with a 10" diameter. A 9x10 APC prop has a humongous pitch, but compared to a 14x6 prop that has a flatter pitch, it offers much less load... 10" pitch is less load than 6" pitch!?... So pitch is a load only if there is a diameter attached to it. What Brian is essentially trying to prove is that higher speed air-flow will not cool the engine better than lower speed air-flow. This is contrary to logic, so I disagree. As to heat conduction; air really is a lousy conductor of heat, at least when compared to aluminium. So, only the air which passes very close to the cooling fins gets all the heat <GGG>... So, what do you do to take more heat from the engine? Reduce the air-flow? Increase the air-flow? Stop the air-flow? If you measure the exit temperature of the cooling air; it is going to be hotter if the air-flow is slow, than if the air-flow is fast. But does that mean the slower air cooled the engine better? As the Δº between the cooling air and the cooling fins becomes smaller, heat convection from the fins to the adjacent air is reduced. The lower the relative temperature of the cooling air, the higher their heat absorption from the cooling fins. So, higher speed cooling air will absorb more heat from the engine, despite exiting at a lower temperature. This is because there is much more of it, compared to the slower flowing air.
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com MVVS - Jett - Nelson - Bolly - Mejzlik
