gkamysz
IL, USA Status: offline
quote:
Take a 2 round bowling balls one weighs 10LB and the other weighs 20LB , Dropped from the tallest building in the world they will both fall at the same speed and reach terminal velocity in a small amout of feet and will not fall any faster the farther they fall (even the heavier one). See the problem with this is the details. The truth to the above is that you are only correct when there is no atmosphere. Air drag is real and quantifiable. The 20LB bowling ball WILL have a higher terminal velocity. Depending on the height from which it's dropped and the timing equipment, the results might be within the error of the experiment and not obvious to the observer. If you take it to the other extreme and have a 20lb ball and a 1/2lb ball the assumption becomes obviously invalid, for the same reasons I just mentioned. The same is true of our discussion here. Each individual has there own set of details they are thinking provides the answer to the question. Yet we have only one test, and everyone except the experimentor thinks it's invalid. Edit- It would seem quite obvious why car engines have such huge heatsink heads on their engines. But then again a .21 makes something like 3HP today, so there is much more heat to dissipate. But compare the fin area on a CL Speed .15 to that of the typical sport .15 and you'll find significantly less area on the speed engine. Maybe velocity is a factor, no?/Edit I feel the test is valid. The results are real, unless downunder made a serious error in his methods, but that doesn't sound likely. I remember seeing the older MAN Engine Talk articles where the tests were done with load beams and fan cooling. I don't remember who the author was at the time, but certainly they could easily answer our futile discussion. Where is AJC? He has plenty of static and in-flight data of exactly what is being discussed.
< Message edited by gkamysz -- 2/17/2007 4:45:50 PM >
_____________________________
Greg
