pe reivers
Joined: 1/23/2002 From: Arcen, , NETHERLANDS Status: offline
Dave, DU, Dar, and all of you. After pondering a while, this pitch related cooling seems to follow a bathtub kind of curve with engine on test stand. There seems to be a quite broad range of pitches that cool the engine well enough, even to about the same level. @ HighPlains : Oil cooling is another myth. The oil contributes extremely little to cooling. There is just too little of it, and it does not evaporate. Very little heat is required to bring that amount of oil to Exhaust gas temperature. Methanol OTOH has a very high heat of evaporation, and there is lots of it. All must evaporate for the engine to reach best power, or the engine will start fourstroking. That evaporation, and air movement through the cooling fins is what keeps the engine cool. @ sport_pilot. IR measurement is good enough for our purposes, because it measures temperature (a value), and not heat which is a quantity. I take it the cylinder head was not shiny on that old ST DU used for the test. Shiny surfaces and IR temperature measurements do not agree so well, but in the hands of the same tester can still provide comparable results.
< Message edited by pe reivers -- 2/14/2007 10:38:46 PM >
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl There is sanctuary in analisys.
