RE: NEW NELSON Q-40
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> QM-40 Racing >> RE: NEW NELSON Q-40 Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: NEW NELSON Q-40 - 2/26/2007 11:49:52 PM
Ed Smith
Status: offline
Just lately, to preserve my sanity I have dispensed with the Coke!
Ed S
(in reply to garys)
       Post #: 101
RE: NEW NELSON Q-40 - 2/27/2007 1:19:29 AM
Tony Pacini
Status: offline
I have a unique perspective in that I broke-in and ran two of the LS engines last week (1 for me, 1 for my son). I started, needled, and maintained both for the whole weekend. We ended up running them as originally assembled (no changes to head or liner shims).
Know one thing for certain: I am NOT an engine guy. I am not a (wood) prop guy, either.
I would have preferred to run the 7.6 or 7.7 pitch props. One engine pulled the 7.8 and needled fine. The other, not so fine. Again, I am not an engine guy.
I'll figure it out eventually. I still need to pull them down and take some measurements to see why the two are behaving so differently. Maybe one is just a bit tighter than the other. When running the 7.8, there just wasn't enough margin to be able to back it off enough and still keep it on the pipe.
There is enough of a performance difference, though, that I personally would not want to race using the old motor (unless everyone else had to). I need all the help I can get, and the LS is definitely faster.
Once this prop issue is sorted out, I hope that all will be well again in the land of Q40.
(in reply to Jim Duda)
       Post #: 102
RE: NEW NELSON Q-40 - 2/27/2007 1:21:19 AM
bl10
Status: offline
As Gary said the LS engine has been in development for at least a year. I believe the “long stroke” is an offshoot of the FAI Nelson developed for the 2007 Worlds. The 7.6 & 7.7 props, on the other hand, are recent developments done independently of the engine. The 7.5 has been around for quite a while. One of the differences in the LS is the muffler. It’s got a shorter tuned length which would cause the engine to reach its HP peak at a higher RPM. My own LS would peak the 7.8 on the ground at 24.8 K. My best old style was 23.8. My engine would peak the 7.5 at almost 27K and the 7.6 was 26K or so. With the 7.8 the engine would run like crazy for the first 5 or 6 laps then start slowing down like it was going lean. The plug came out way lean. I was setting it over 2k down and it still did it. I believe the problem I had was different from the others. Dave took the engine to analyze what went wrong.
At this point, due to the prop issue, no one knows what prop will be best.
I don’t believe any rules were broken with the release of either the engine or props. This is racing and it’s pretty much the standard for new and better equipment to supersede the old designs. It’s also pretty common for a new weak link to show up.
This next part is just my opinion:
There were 73 entries from 8 countries at the PHX race. I firmly believe that without the APC props only half as many would have been there and I probably would have been one of the ones not there. I am hopeful this issue can be resolved in the near future without a huge impact on the Q40 community.
Take care,
Barry
(in reply to Ed Smith)
       Post #: 103
RE: NEW NELSON Q-40 - 2/27/2007 2:23:31 AM
BUDMAN27
Status: offline
No davin it was not me. To tell you the truth I have read all this stuff you guys are saying about the new nelson and I couldn,t make heads or tails of it all.
(in reply to bl10)
       Post #: 104
RE: NEW NELSON Q-40 - 2/27/2007 3:45:01 AM
daven
Status: offline
LOL
_____________________________
Dave Norman
klasskote.com
supertrc.com
(in reply to BUDMAN27)
       Post #: 105
RE: NEW NELSON Q-40 - 2/27/2007 1:30:44 PM
luv to race
Status: offline
Like I said earlier, my situation was just as Barry described. The only difference was I launched at about 2,200 down from peak and made it about 6 or 7 laps then went lean and basically melted for 3 laps. Then I watched my teammate Travis stay about 15 to 1,800 down and have not one problem. Very puzzling? Some might think it's a tank position thing? I flew the new GR7 which has the tank in perfect alignment behind the engine. if anything the tank is slightly above the needle, which would be better than having the tank below the needle. Some might think it's a break-in time issue? I broke mine in as much as the next guy.. about 15 tanks through mine before the prop switch.. Freeman Jr had the same problem as Barry and I... he flew a polecat? who knows.... What I do know is the only thing I changed between Thursday's practice day and Saturday morning was prop.
I think Dave Shadel is a great guy. He spent more than enough time with me, rebuilt my motor on the spot, came out and needled it once to see for himself... not too many guys go that extra mile. And I guarantee that he will adjust piston fits and find the sweet spot as the year progresses...
Lastly... Schmidty, Shadel, Seaholm, and I had a FREAKING BLAST at the drag races. And the wife is super excited that I got Ashley Forces autograph on my JR jacket. We will be going to Gator Nationals in Gainsville... we say 4.43, at 331mph... that's better than FAI anyday!
RB....
SuperT's caller...
(in reply to daven)
       Post #: 106
RE: NEW NELSON Q-40 - 2/28/2007 12:10:24 AM
burgster
Status: offline
could they be over compressed?
Jeff
(in reply to luv to race)
       Post #: 107
RE: NEW NELSON Q-40 - 2/28/2007 11:27:26 AM
BUDMAN27
Status: offline
It would seem like no one wants to answer your Q. burgster.
(in reply to burgster)
       Post #: 108
RE: NEW NELSON Q-40 - 2/28/2007 12:46:10 PM
luv to race
Status: offline
We played with that as much as possible. We all raised the head .003, .004, .005.. then back down again. My answer would be no.
RB
       Post #: 109
RE: NEW NELSON Q-40 - 2/28/2007 11:10:15 PM
burgster
Status: offline
Then must be a fit issue, maybe too tight. Had problems like that when I raced snowmobiles. Thing would run like stink then either haze a piston or lock up solid. i always thought it was a lean conditon or lack of oil, but it was a clearance issue. The piston would expand too much too quickly ie faster then the cylinder. I am sure that Dave will figure it out what ever it may be.
Jeff
       Post #: 110
RE: NEW NELSON Q-40 - 3/1/2007 4:29:55 AM
BUDMAN27
Status: offline
Sounds like everone is getting uptight over this new engine. life is to short to worry over such small things. If you can,t handle the presure than set on the side lines with me. Its not that bad from here. I get to watch a bunch of ritch guys fret over nothing.
       Post #: 111
RE: NEW NELSON Q-40 - 3/1/2007 4:48:17 PM
DHG
Status: offline
That's why I like football. Our millionaires can beat up your millionaires!
       Post #: 112
RE: NEW NELSON Q-40 - 3/1/2007 7:11:58 PM
BUDMAN27
Status: offline
Me too
(in reply to DHG)
       Post #: 113
RE: NEW NELSON Q-40 - 3/1/2007 8:08:58 PM
HighPlains
Status: online
Does the earlier tuned muffler still fit on the LS? Perhaps that would allow it to have enough torque to turn the 7.8 props.
Also, since the liner shims from the earlier Nelsons still fit, will the older P/S set and head fit into the LS for added displacement, giving something close to a .45 or more?
< Message edited by HighPlains -- 3/1/2007 8:09:34 PM >
In politics if you want anything said, ask a man. If you want anything done, ask a woman - Margaret Thatcher
(in reply to bl10)
       Post #: 114
RE: NEW NELSON Q-40 - 3/1/2007 8:17:01 PM
luv to race
Status: offline
The old muffler will fit. I watched Rusty helping Frank Wong in Phx... Frank accidently put the old muffler on the new motor. Would even hardly run, coughing rich in the air. Not sure about your next question... But I'm sure Dave tried all the combinations, before settling with this one.
(in reply to HighPlains)
