which covering to use
Tower Hobbies
Logged in as Guest
  Printable Version
Ziroli Stuka - laser lizard cut short kit - Kit
Seller:  laserlizard
Details:   $99.98   |  8/27/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> which covering to use
Page: [1]
Login
which covering to use - 2/15/2007 3:40:43 AM
10-300
Status: offline
HI guys
I need an opinon on which covering is better to use koverall or stits lite. I'm not sure which one I should use. I'm building a D-7 and I will be painting it. I like the stits covering and i have ordered some to test on a wing panel. But Koverall has come to mind as well. Also has anyone used the rib stitching tap from the guy in canada? and how do you like it? any help would be greatly appreciated.
Louie
       Post #: 1
RE: which covering to use - 2/15/2007 3:58:56 AM
US185Damiani
Status: online
Stits Lite for sure,
Coverall is the same type of fabric but Stits lite is a whole system almost identical to full size airplanes.
_____________________________
A good landing is one you can walk away from, but, a great landing is when you can re-use the airplane.... immediately
(in reply to 10-300)
       Post #: 2
RE: which covering to use - 2/15/2007 11:45:39 AM
10-300
Status: offline
Thanks, I was leaning in that direction. Where I get a little confused is, If i use there system I have to stay with there paints? problem is they don't have the color i need, I'm building a Fokker D-7 and the blue and red needs to be matched from the picture I have. Also the bottom of the sub wing is a funky turquoise, this color certainly need to be mixed. So do i just use the fabric and maybe the poly tac for attaching the fabric then go with a different paint like sigs dopes or another brand?
Louie
(in reply to US185Damiani)
       Post #: 3
RE: which covering to use - 2/15/2007 12:19:08 PM
US185Damiani
Status: online
Stits is a complete system, you'll have to use it through the Primer stage.
BUT I believe you can use Latex or urethane over top of their primer. What about using a lozenge pattern Fabric?
Check on the Scale models threads for info on it.
       Post #: 4
RE: which covering to use - 2/15/2007 1:32:37 PM
carlbecker
Status: online
I have read very good things about Solartex being better than Koverall. White Koverall is the only woven fabric I have used. You should check out threads on RCscalebuilder and maybe ask there also.
Carl
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU1
