RE: Echo BME twin    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  4/12/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: Echo BME twin
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Echo BME twin - 3/10/2007 6:09 AM
Antique
Score: 557
Last Login: 3/21/2012
Status: offline
My block is 3/4 thick, bolted to a 1" thick x 5 inches wide with 1/2" allen bolts..It's a T, with holes in one side for G38 size cranks and the other side for G62 size cranks..it fits in my Kurt vise on the mill table...Most lathe chucks are not good enough to check alignment within .001, so the block was the answer...It's about 12 years old.....
_____________________________
RC Ignition
Hide Signatures
(in reply to captinjohn)
       Post #: 76
RE: Echo BME twin - 3/10/2007 6:44 AM
captinjohn
Score: 247
Last Login: 5/21/2013
Status: offline
RCIGN1: Got a question. What is the best way to make this. Drill close... then finish bore with??? Also would high grade aluminum work ok in place of steel?? Thanks Capt,n
I never met a engine I did not like !
Hide Signatures
(in reply to Antique)
       Post #: 77
RE: Echo BME twin - 3/10/2007 7:49 AM
tim220225
Score: 100
Last Login: 4/17/2013
Status: offline
Hey Ralph, how about a picture or two??
Hide Signatures
       Post #: 78
RE: Echo BME twin - 3/10/2007 9:05 AM
Antique
Score: 557
Status: offline
Steel is best...The holes gradually get elongated with use...This thing is so old now that the holes are getting oval...Still works, but not as well as it did..pictures tomorrow, it looks pretty bad...
RC Ignition
Hide Signatures
       Post #: 79
RE: Echo BME twin - 3/10/2007 5:43 PM
captinjohn
Score: 247
Status: offline
It will be interesting when you get the engine together enough to use a dial indicator to see if both pistons come up to Top Dead Center at same time!! I hope she does. Capt,n
Hide Signatures
       Post #: 80
RE: Echo BME twin - 3/11/2007 5:43 AM
tkg
Score: 657
Status: offline
Don't need a dial indicator. Just shine a light in the spark plug hole and look in the exhaust port. If both cylinders go dark at the same time you got it. If not a feeler gauge will tell you how far off you are.
TKG
Too much power is just about right.
Hide Signatures
       Post #: 81
RE: Echo BME twin - 3/11/2007 6:26 AM
captinjohn
Score: 247
Status: offline
That assuming ports are identical height in both cylinders and base gaskets are exact ect...ect are exact. I like a dial indicator. Capt,n
Hide Signatures
(in reply to tkg)
       Post #: 82
RE: Echo BME twin - 3/11/2007 8:28 AM
tkg
Score: 657
Status: offline
Its the port timing that counts. The gasket and deck heigth will both effect the dial indicator.
TKG
Hide Signatures
       Post #: 83
RE: Echo BME twin - 3/11/2007 9:06 AM
Ralphbf
Score: 100
Last Login: 7/6/2011
Status: offline
quote:
ORIGINAL: tkg
I believe it will be the same exact port timing that counts.
Unless the port timing is matched the engine will not be optimized.
Deck height needs to be maintained so the compression raitos will be he same.
It should not be hard to do, it's just another small detail that needs to be taken care of.
Ralph
Hide Signatures
(in reply to tkg)
       Post #: 84
RE: Echo BME twin - 3/11/2007 8:10 PM
av8tor1977
Score: 665
Status: offline
I was thinking of making the interface between the crankshafts a shrink fit on mine, so that indexing could be checked and set before welding...
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to Ralphbf)
       Post #: 85
RE: Echo BME twin - 3/12/2007 1:16 AM
av8tor1977
Score: 665
Status: offline
Did that money order arrive for you yet airbornrc ?
AV8TOR
Hide Signatures
(in reply to av8tor1977)
       Post #: 86
RE: Echo BME twin - 3/12/2007 4:29 AM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: tkg
It seems like the base gasket and the deck heigth will also affect port timing and dial indicator. Most likely if ports are in time with each other....the top dead center will be very close too. Well if she runs good...thats all that counts. Well except for if its kinda heavy...thats not good!!! Capt,n
Hide Signatures
(in reply to tkg)
       Post #: 87
RE: Echo BME twin - 3/12/2007 5:02 AM
av8tor1977
Score: 665
Status: offline
Well, a twin will never weigh less than a similar size single cylinder engine at least in theory, but it sure is cool!!
AV8TOR
Hide Signatures
       Post #: 88
RE: Echo BME twin - 3/13/2007 2:58 AM
airbornrc
Score: 100
Last Login: 11/5/2012
Status: offline
av8tor. The money order has not made it as of Saturday. I am out of town till Wednesday.
Mark Anderson
Hide Signatures
       Post #: 89
RE: Echo BME twin - 3/19/2007 7:33 PM
airbornrc
Score: 100
Status: offline
Av8tor
I dropped off your parts at the post office This morning.
Mark Anderson
Hide Signatures
(in reply to airbornrc)
       Post #: 90
RE: Echo BME twin - 3/19/2007 7:51 PM
tim220225
Score: 100
Status: offline
Mark, have you been able to run your twin yet?
Tim
Hide Signatures
       Post #: 91
RE: Echo BME twin - 3/19/2007 8:07 PM
av8tor1977
Score: 665
Status: offline
airbornrc Thanks!!
I almost went out to the workshop to work on my twin last evening, but I was just too tired and lazy. I've been making myself leave it alone until I finish up a few other projects already in the works. One of these days soon...
AV8TOR
Hide Signatures
(in reply to tim220225)
       Post #: 92
RE: Echo BME twin - 3/20/2007 9:11 PM
airbornrc
Score: 100
Status: offline
I had to get some customer fiberglass work out and have not gotten the crank pinned. I also need to get an ignition.
Mark Anderson
Hide Signatures
       Post #: 93
RE: Echo BME twin - 4/7/2007 6:42 AM
aviatorplus
Score: 100
Last Login: 5/18/2013
Status: offline
where can i get one of the cases
Hide Signatures
       Post #: 94
RE: Echo BME twin - 4/7/2007 6:47 AM
tim220225
Score: 100
Status: offline
Just drop an email to Keith or give him a call. This thread has been idle for a while so he may still have some. By the way I wonder if Mark has gotten his running yet.
< Message edited by tim220225 -- 4/7/2007 6:48 AM >
Hide Signatures
(in reply to aviatorplus)
       Post #: 95
RE: Echo BME twin - 4/7/2007 5:54 PM
huey-pilot
Score: 100
Last Login: 2/11/2013
Status: offline
I purchased some extra cases and if someone needs one send me a PM.
Hide Signatures
       Post #: 96
RE: Echo BME twin - 4/7/2007 7:26 PM
tim220225
Score: 100
Status: offline
Huey-pilot glad to see you are back on. How did you do in the tornado? Many of us down here in Mobile chipped in with supplies and clothes for you up there.
Hide Signatures
(in reply to huey-pilot)
       Post #: 97
RE: Echo BME twin - 4/8/2007 6:16 AM
aviatorplus
Score: 100
Status: offline
HOW MUCH FOR A CASE AND HAS ANYONE GOT ONE RUNNING YET
Hide Signatures
       Post #: 98
RE: Echo BME twin - 4/8/2007 6:19 AM
tim220225
Score: 100
Status: offline
Read back in this thread. Airbornrc has his finished but don't know if it is running. When I get moved and settled I will be working on mine. Trying to move and reset 3 tons worth of machinery may take me a bit.
Hide Signatures
       Post #: 99
RE: Echo BME twin - 4/8/2007 5:17 PM
huey-pilot
Score: 100
Status: offline
I will sell two of my cases for the same price that I paid, $40 each plus shipping charges. Thanks for your interest Tim, the tornado missed my place and I only lost some shingles. We appreciate the supplies and other items.
Hide Signatures
       Post #: 100
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: Echo BME twin
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.266RCU1
