Is the aluminum upgrade worth the money?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> Is the aluminum upgrade worth the money?
Page: [1]
Login
Is the aluminum upgrade worth the money? - 2/15/2007 8:41:58 PM
zach8202
Status: offline
Hey all, just curious. Can someone fill me in on their experience with the aluminum upgrade for their Walkera? Is it worth the money? Thanks!
       Post #: 1
RE: Is the aluminum upgrade worth the money? - 2/15/2007 9:03:32 PM
NY Rebel
Status: offline
Which Walkera are you refering to?
22e ... I've been an advocate of the CNC head for quite some time...
quote:
ORIGINAL: zach8202
(in reply to zach8202)
       Post #: 2
RE: Is the aluminum upgrade worth the money? - 2/16/2007 2:34:17 AM
spOon2410
Status: offline
My experience with setup for 22E:
Bought the Sonix CNC V2 head. Spent about 10-15 hours installing it (ran into every problem possible). Finally got it set up, thanks to NY_Rebel's help.
And I couldnt be happier!!!!
Well worth the work if you ask me, great product, just a little hard to set up if you dont know what you are doing.
_____________________________
spOon.
(in reply to NY Rebel)
       Post #: 3
RE: Is the aluminum upgrade worth the money? - 2/16/2007 3:05:09 AM
NITRO_VEEDRIVER
Status: offline
as too your question as to is it worth the money... the answer is goin to have to be YES!!!!!! the aluminum frame is alot better then the stick frames that are out there.....
cheers
Andy
happy flyin!!!!!!!!!
Drive Dirty!
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN!
(in reply to spOon2410)
       Post #: 4
RE: Is the aluminum upgrade worth the money? - 2/18/2007 7:24:22 PM
zach8202
Status: offline
I have a 60, I messed up the tail and broke some of the plastic parts...the tail rotor met the ground. So if I buy the metal upgrade kit and the tail hits the ground (not crash really, just hit the ground while attempting to land) something else will break and not the metal parts? I just couldn't tell from pictures as to how sturdy or cheap the aluminum is. Any more comments would be great! thanks guys!
(in reply to NITRO_VEEDRIVER)
       Post #: 5
RE: Is the aluminum upgrade worth the money? - 2/23/2007 4:14:57 AM
ninegeorge
Status: offline
I tOO WOULD like to get a head upgrade, but i dont like having to spend $138 and 10 hours modifying it so that it will fit.
       Post #: 6
RE: Is the aluminum upgrade worth the money? - 2/23/2007 5:51:28 PM
NY Rebel
Status: offline
First...he's talking about DF60 parts, you're referring to 22e CNC head...
Second....the 22e CNC head doesn't cost $138 (the "Microheli" head does from some vendors...the "Sonix" does not)
Third...if you follow the install guide I did on the 22e Sonix head, you can complete it in about 2.5 to 3 hours if you use stock servos (less if you're using aftermarket servos)
quote:
ORIGINAL: ninegeorge
(in reply to ninegeorge)
       Post #: 7
RE: Is the aluminum upgrade worth the money? - 2/23/2007 6:40:22 PM
spOon2410
Status: offline
Yeah I took a little bit longer on the 22E head because a lot of it was figuring out what to do and how to do it.
Now that there is a great thread to follow it can be done in under 5 hours for sure.
spOon.
       Post #: 8
RE: Is the aluminum upgrade worth the money? - 2/23/2007 10:21:37 PM
zacko
Status: offline
On my 60 I run the stock plastic head and the CNC tail. I've upgraded both but found the CNC head hard to keep dialed in. The mixer levers that mount on the blade grips keep slipping and throwing off my blade tracking in flight. I get the screw as tight as I can and use thread loc, but it still does it. Never any problems with the tail.
A good friend will keep you out of jail. A better friend will be there beside you.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU1
